Question about Lanier Office Equipment & Supplies
Lainer 5245 cs code 329-00
Also how to get in to sp mode
laser??
  • Lanier Expert
  • 1,326 Answers
I believe that model is a Richo in a disguise.... To get into service mode, first press the yellow C/A botton, then the numbers 1 - 0 - 7, then press and Hold the red C/Stop botton for a few seconds and the display will change. Then you are in the Service Mode... Good Luck
Posted on Apr 19, 2009
Reset code printer ricoh sp c232dn
Service mode or maintenance mode:
turn off machine
Hold stop/start & escape and then turn on power
press OK
Mar 08, 2017 | Ricoh Aficio SP C232DN Laser Printer
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
How do I factory reset my Ricoh Aficio SP C811DN?
Go into SP mode. Saw it there once when I was just fooling around in SP modes at work. Enter SP mode with pressing the yellow clear all button, then 107 and holding down the red stop button. .
Jul 17, 2014 | Ricoh Aficio SP C811DN Laser Printer
Error code sc546
sc546 is a fuser ready temp problem.
it requires a reset procedure: enter SP mode.touch Copy SP..touch SP DIRECT then press 7807# on the keypad then execute...turn power off and then back on
Jan 29, 2014 | Ricoh Aficio 1027 All-In-One Laser Printer
Jumpers Serttings on Quantum HD
CS = Cable Select
DS = Master
SP = Spare (Slave)
Nov 10, 2013 | Maxtor Computers & Internet
How to make reset for sc 542 for richo aficio 410 printer
That code requires going into the SP (Service Protocol) mode. If you have the service manual, it will tell you which buttons to press to enter it and to exit service mode. Once you enter service mode, power down the printer. If that doesn't reset, you have to go back into service mode, go the the SC/Fuser reset SP and once executed, power down then restart. Hint: you have to go to "SERVICE" then 1 will display. Press the right arrow key until you reach "5" then press the OK button. You can then right or left arrow until you find the reset SP. Good Luck.
Oct 24, 2013 | Ricoh Aficio SP C410DN Laser Printer
Clear ricoh 5510L error code 0544. I can get to SP mode by user tools, #, 1-0-7 then start but what do I do from there?
try executing sp 5810
if there is no 5810 just turn machine off while in sp mode using the red on/off switch
This should clear the code
however if there is a problem with your fuser the code will come back.
Caution dont reset multiple times in a row or you will do damage to the machine or fuser from it getting too hot
Apr 06, 2010 | Ricoh FAX5000L Plain Paper Laser
Cs546
The problem in the fuser unit.Check and clean the rollers ,thermistors,thermofuses.
Aug 10, 2009 | Lanier 1205 Copier
SC322 on Ricoh Aficio 2035
forget the laser unit your developer is shot... machine cant detect vsp and vsg... therefore gives a laser error... replace developer run developer initialization in sp mode copy sp drum... should solve the problem
Feb 16, 2009 | Ricoh Aficio 1035 Copier
Copier problume.
return SP1-902-1 to 0. Then, the SC will
be cleared.
Sep 23, 2008 | Ricoh Aficio 1085 Laser Printer
97 people viewed this question
Top Lanier Office Equipment & Supplies Experts
Adorjani Laszlo
Anthony Karuku
George Mclaughlin
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
