Question about Toshiba Satellite A135-S4527 Notebook
Power problem - led shows the ac plug is in - battery does not charge - can not run laptop on ac adapter - what is causing this problem
When the ac adapter is plugged in the led shows it has power - the battery will not charge - if you remove the battery the unit will try to start but as soon as the hard drive starts to spool the laptop shuts down - when the battery had a charge the computer would run - i think it is a bad internal power supply but I can not find a schematic so i can test the unit - I can not even find out on line if the unit has a seperate internal power supply or if it is part of the mother board. Is there any repair books out there for these units? Any Ideas on what is causing these problems?
  • 385 Answers
The connection to the power supply inside the Pc is or has gone,
because your using the connection 1000 times a year, it faulters, and fails.
$150/$200 to get repaired.
Strip out the laptop solder connection back up,
rebuild, very common problem.
Regards
Richard.
Posted on Apr 22, 2009
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | HP Computers & Internet
Hi i need help plz, i've my laptop do not power when i plug the ac adapter ther' is no ligth
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
May 23, 2011 | Dell Inspiron 2200 Notebook
My AC adapter suddenly can't seems to be able to charge my battery. Please kindly advise
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced. Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
May 08, 2011 | Compaq Presario CQ40 Series Laptop Charger...
My advent battery would not charge so i bought a new one and it still wont charge having to run my laptop from the mains
Mar 12, 2011 | Advent Netbook
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
Its that the battery is not charging, and on the power meter icon its blinking four times orange and one time green. If I remove the battery, the laptop works with ac adapter. but if I reinstall the...
Check for a DC connector problem:
Feb 06, 2011 | Dell Latitude D610 Notebook
I bought new universal adapter for asus laptop and it charges batery just when laptop is turned off
Problem description: The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
Possible cause: 1. AC power adapter failure.
2. Battery failure.
Possible troubleshooting steps and repair solution: 1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
Reference: http://www.chargerbuy.com/blog/battery-charges-only-when-laptop-turned-off/
ASUS laptop AC Adapter
Jan 25, 2011 | Computers & Internet
Strange ac cord/power issues
Hello my friend, Try to check your battery if the is it working normal cause sometimes the battery itself has the problem its either lost contact or the battery is not charging or not normal. also try to see if the the the sensor or that links the battery to the software which is responsible to the update of charging energy is functioning normal but this is a rare possibility try to focus on the battery or the connector or power cord.
Hope this will able to help solve you problem. If you need more assistance just reply to this post. Thank you
Jonas
Apr 20, 2009 | Toshiba Satellite P15-S420 Notebook
IBM T30 - power issues
You might try cleaning the battery compartment. Makeing sure there are no damaged pins. Often times even a single messed up pin will cause this. Also this is a very good indication of adaptor failure. If you haven't allready I suggest getting another ac adapter specific to you machine. Even a substitute will casue the same issue you are now experianceing.
Jul 11, 2008 | IBM ThinkPad T30 2366 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
144 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
