Question about Radio Communications
Blaupunkt ARC3231 car stereo not working
My blaupunkt ARC3231 is not working at all. I left it disconnected for a few days - then reconnected - It worked! for few days and went kaput. Any suggestions -other than buying a new unit. many thanks
  • selfcontrol Sep 21, 2007
    Thank you for your suggestion . will look at it.
    many thanks
  • 150 Answers
It's obviously a power problem. If I were you, i would take the head unit out and rewire your harness to ensure it;s not a wiring problem. Sometimes a wire can chaff in your dashboard and cause this type problem. If it turns out it's not a problem with the wiring i would invest in a new one. Good Luck hope this help L8R
Posted on Sep 18, 2007
Unlock stereo code for holden vectra 2000 model
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Holden service centre and get them to enter this code for you.
Mar 22, 2013 | Blaupunkt Car Audio & Video
I have a new code for my blaupunkt car stereo. Do I detach the car battery, reattach and type in new number?
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your vehicle manufacturer's service centre and get them to enter this code for you.
Feb 22, 2013 | Car Audio & Video
Hi i have a blaupunkt radio in my peugeot 206 and it is locked and i do not have the code, that numbers i can see on the radieo r, 863513268807, st02-z-275-na, these r on the top of the stereo, n...
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Peugeot service centre and get them to enter this code for you.
Dec 09, 2012 | Car Audio & Video
Radio code
Sep 11, 2012 | Blaupunkt Car Audio & Video
Problem for Blaupunkt Bermuda MP36 Car CD Player. I was getting the error CD error when I use to insert the mp3 cd in the CD player. I complained and was asked to reset it by disconnecting the battery...
The fault was explained earlier, please check your MP3 format. play a normal cd to see if it detects, if so try with another recognised MP3. if not clean your head after opening the set. try again or it is possible that your optical is faulty or the RF signal processor IC is defective. Check this out. Good day
Jul 12, 2010 | Blaupunkt Bermuda MP36 Car CD Player
Blaupunkt stereo
try to unplug the ground on your car battery for a few seconds then try again with the correct code if you have it.
Oct 04, 2009 | Car Audio & Video
Six cd changer with 6 cds stuck inside, none will play and message appears no cd, or cd error,or eject error in a 2004 ford escape
Ok this may seem barbaric but it worked on mine.......Hit the top of the stereo a couple of times and see if it corrects the problem.
May 30, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
2000 Astra Blaupunkt Stereo
Leave SWITCHED ON...UNDISTURBED for a couple of hours
Apr 07, 2008 | Blaupunkt PCA250 Car Audio Amplifier
Car audio security code
pin is on the metal frame of radio on left or right side and on sticker starting with the letters BP- then your 4 dig pin also the radio code after the pin write it down to. swich your radio off press hold the AS button while holding AS button down press power button it will automaticaly ask for security code enter security code then radio code
Feb 22, 2008 | Blaupunkt PCA250 Car Audio Amplifier
Cd-changer Blaupunkt IDC-A09
The solution is to disconnect the head unit and the cd changer from each other and from the car itself, leave it for ten minutes. reconnect and turn the ignition on but not the car itself, enter radio code if has one and all should work.
Sep 24, 2006 | Blaupunkt IDC-A09 5-Disc CD Changer
Radio Communications Logo
91 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
