Question about Tech Solution TS-4500 Shredder
Shredder Problem The paper sensor switch on my Tech Solutions TS4500 is not working properly. In order to get the paper to shred, I have to press the switch all the way in with a pencil while the paper is being shredded. Is there anyway to fix this? Thanks. The motor does not operate. Switches are OK.
  • melndana Apr 20, 2009
    It seems that the motor commutator is badly warn and will operate only when manually moved and re-powered. It will run continuously and may not re-start after being stopped. When it runs, there is a lot of sparking between the brushes and the commutator. The commutator is quite scored and full of brush residue. I see replacement of the motor assembly or replacement of the entire unit as the only solution. What do you think?
    Top Expert:
  • Tech Solution Master
  • 79,865 Answers
They don't service this part other than in a complete new shreder head assembly, U might as well replace the shreder.
Posted on Apr 20, 2009
    President:
  • 2,004 Answers
This item is designed in a way that if there's a defect, you replace.
Manage it or get a new one.
Rate this
Posted on Apr 18, 2009
My Tech Solutions TS4500 paper shredder will shred approximately 1/2 page of one or several sheets of paper. But at that point it chokes and will not shred any further. It will back the unshred portion...
My experience has been that when a shredder chokes it usually is trying to tell you the bin is full but a cross-cut shredder is less susceptible. I do have a heavy duty cross-cut shredder that gets rather wonky when suffering from indigestion. Check whether the amount of bin content is affecting yours.
Jul 14, 2017 | Winsource Tech Solutions TS-4500 Cross-Cut...
Tech Solutions shredder Only powers in reverse w/ green light
Their are sensors on top and bottom of cutter asm. Good chance one or more are dirty, blocked with paper shreds or just bad. Clean with compressed air and lightly moistened cotton swab.
Jun 01, 2009 | Tech Solution TS-8000 Cross-Cut Shredder
My shredder keeps running and won't stop in on/auto mode
UNPLUG THE SHREDDER.
If this model has electronic eyes (optics) to control the auto-start/stop function and you oil the cutters, chances are the optics are contaminated with shredder oil. Take a cotton swab with a little alchohol and clean and dry the optics.
If you removed the top cover, it is a possibility that you disconnected the wires from the PC Board.
Mar 01, 2009 | Royal VF1012mx Shredder
Need wiring diagram/info for Tech Solutions TS2550 Paper Shredder
Thank you so very much for going into so much detail about my shredder that wouldn't pull paper thru it. You were SO NICE to do all that & I sincerely wish I could send you a picture of the wiring. HOWEVER, I threw it away months ago when I got no answer to my problem. Guess I'm not patient enough :-) I sincerely appreciate your reply and wish that I could help you out. If I still had it, I'd just mail it to you :-)
SWALynn
Jan 03, 2009 | Tech Solution TS-2550 Shredder
It sounds like you may have a gear with a broken tooth you should contact the manufacturer to get more info. Usually when this is the case it will shred good for only a few revolutions and then reversing backs the gear up to a position that allows it to turn the cutters until it once again reaches the area where tooth is missing.
Mar 11, 2008 | Winsource Tech Solutions TS-4500 Cross-Cut...
Shredder Problem
Replace the paper sensor switch
May 27, 2007 | Tech Solution TS-4500 Shredder
Paper shredder
The only solution with respect to safety is to order a new switch from the companuy that manufactures/sells this shredder, and mount it according to the manufacturer/sales company's instructions.
If you want to bypass the safety of the machine, just keep the cables (should be 2, + eventually a ground cable) open, or shorted, depending of the machine's configuration. Remember that this is on your or your collegaues own risk!! A shredder can easily bite your finger off!
May 19, 2007 | Tech Solution TS-4500 Shredder
Does the shredder have the electronic eye to sense paper? Sometimes dust will collect on the sensor causing it to keep running.
Apr 07, 2007 | Tech Solution TS-4500 Shredder
Tech Solution TS-4500 Shredder Logo
73 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Michael Galve
Michael Galve
quennie732
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
