Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Water flow decrease on refrigerator dispenser
When a glass is put up to the dispenser, water initially comes out well. After about two seconds, the flow reduces to a slow trickle. I have checked the line and it does not appear to be kinked, and the filter has been replaced consistently. There are no leaks in the water supply line. What else can I do to fix this?
  • 1 more comment
  • special_ed06 Apr 18, 2009
    Thanks for the advice and quick response! I will try your suggestions.
  • horne5018 Apr 19, 2009
    My ice maker works; so I am getting water to the refrigerator. My water dispenser at the door does not work at all. When the handle is pressed there is no sound and not even a drip of water. The model number on the data panel says 10659292993, man date is 9/2000. It is a side-by-side.
  • Anonymous Mar 21, 2014
    cold water trickles out. no flow.
    Problem Solver:
  • 11 Answers
You might have calcium deposits in the supply line.You can unscrew the line from the fridge and turn on the water to see if you have good flow. Have a bucket or pan handy. Let it run for a minute. If it checks out ok then the problem might be in the line attached to the fridge. Those usually come off fairly easy. If so take that off and see if its clogged. You can also check the valve where the feed is connected to the main water.
Posted on Apr 18, 2009
Bought a new Maytag side by side. Will not put out water. Tried the 5 sec on and 5sec off to flush the air out, still didn't work. What next?
Hi and welcome to FixYa, I am Kelly.
First off you need to make sure the freezer door is CLOSED and water filter is properly installed in the filter housing. Without a model number I can not tell you the exact location of the filter. There is a water lock out function of the water filter housing that will prevent proper water flow until the filter is installed correctly or removed completely. Also... there is a water tank / reservoir that has to be filled completely with water before you will see any water at the spigot. Please pass your model number so I can better assist you or call the Maytag Sercive Center so they can walk you through the initial set up procedure of your refrigerator. (They will also need your model number) Go to http://www.maytag.com and register your appliance before making the call.
1 (800) 344-1274 U.S.
1 (800) 688-2002 Canada
Before making the call check out this information about troubleshooting:
http://maytag.custhelp.com/app/answers/detail/a_id/110/kw/Water/session/L3RpbWUvMTI5ODY4MTEyNi9zaWQvam9CYWV5bms%3D
- After connecting the refrigerator to water source or replacing the water filter, flush the water system. Use a sturdy container to depress and hold the water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat until water begins to flow. Once water begins to flow, continue to press and release the dispenser bar (5 seconds on, 5 seconds off) until a total of 3 gal. (12 L) has been dispensed. This will flush air from the filter and water dispensing system, and prepare the water filter for use. Additional flushing may be required in some households. As air is cleared from the system water may spurt out of the dispenser.
- Make sure the dispenser is not locked. Some models have a lock feature that deactivates the dispenser levers and control buttons. The lock button is on the dispenser front cover. This feature controls unintentional dispensing during cleaning. Press the Unlock or Locked button to reactivate the dispenser levers and allow dispenser function. You may need to hold the button for 2 to 3 seconds.
- If there has been a recent power outage or the power supply has been off for more than one hour, the power outage indicator (on some models) will disable the dispenser function. The dispenser display will read "PF" to indicate power failure. To use the dispenser, press and hold the "Reset" button for 3 seconds until you hear the beeps.
-A clogged or incorrectly installed water filter will reduce the water flow to the water dispenser. Check for a problem with the filter by removing the filter and operating the dispenser. If water begins to flow, then the filter is either clogged or incorrectly installed. A clogged filter will need to be replaced.
If the filter is clogged and you are not able to immediately replace it, leave the filter out so the water system is in bypass mode. With the filter removed, the water system will continue to operate, bypassing the filter, and the clogged filter will not cause slow water dispensing. However, in order to have filtered water, you will need to install a new filter.
All Genuine Maytag Water Filters retain beneficial fluoride and are NSF Certified for drastically reducing chlorine taste and odor, particulates, lead, mercury and cysts.
To ensure glass after glass of clean, refreshing ice and water, change your filter yearly or whenever the system light indicates.
about the filter:
http://assets.whirlpool.com/files/usr/animations/ANM000085.htm
The information above should get your water working. If not please listen for a solenoid buzz as you actuate the water in door function. No buzz either the dispenser is locked off or.... you have a valid warranty claim.
Thanks for choosing FixYa,
Kelly
Feb 26, 2011 | Maytag Refrigerators
Please tell me how to replace the water filter and reset the "change filter" light on my Maytag Refrigerator MSD2756GEB. My light stays red after I change the filter. Thanks
The filter status display will help you know when to change your
water filter. When the display reads 10%, order a new filter. It is
recommended that you replace the filter when the display reads 10% OR when water flow to your water dispenser or ice maker decreases.
The filter should be replaced at least every 6 months depending on your water quality and usage.
Step 2
Press the eject button to release the filter from the base grille.
Step 3
Pull the filter straight out.
Step 4
Turn the cap counterclockwise to remove it from the filter. IMPORTANT: Do not discard the cap. It is part of your refrigerator. Keep the cap to use with the replacement filter.
Step 5
Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
Step 6
Remove the protective covers from the O-rings. Be sure the O-rings are still in place after the covers are removed.
Step 7
Push the filter into the base grille. The eject button will pop back out when the filter is fully engaged.
Step 8
Flush the water system. Use a sturdy cup or glass. Depress and hold the
water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat this process until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever. Hold down for 5 seconds and then release for 5 seconds. Do this on/off process for about 2 minutes. This will flush air from the filter and water dispensing system.
Take care......
Aug 13, 2010 | Refrigerators
How to change water filter in this refrigerator
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Hope this helpout.....
Aug 13, 2010 | Kenmore 57029 Side by Side Refrigerator
How do I replace my UltraEase water filter?
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Hope this helps...
Aug 12, 2010 | Whirlpool Refrigerators
Want to know when and how to replace water filter on a ge side by side refrig
The water filter status light or indicator, present on some models, will help you know when to change your water filter. The light, or indicator, is located either on the temperature control panel in the refrigerator compartment or on the dispenser control panel on the freezer door.
The indicator will be one of two styles.
If the indicator is a light or series of lights, the light will change from green to yellow. This tells you that it is almost time to change the filter. It is recommended that you replace the filter when the status light changes to red or when water flow to your water dispenser or ice maker noticeably decreases.
If the indicator resembles a stack of bars, the bar height will decrease and the status display will change from "Good" to "Order." This tells you that it is almost time to change the filter. Replace the water filter cartridge when the water filter status display changes to "Replace" or when water flow to your water dispenser or ice maker noticeably decreases.
If a filter status light/indicator is not present, the filter should be changed at least once every 6 months. Your filter may need to be replaced more frequently depending on your usage and water quality.
If the water flow to the water dispenser or ice maker noticeably decreases before 6 months have passed, you may need to replace the water filter cartridge more often. Decreased water flow is a sign that the filter is clogged and needs to be replaced.
If the filter is clogged and you are not able to immediately replace it, remove the filter so the water system is in bypass mode. With the filter removed, the water system will continue to operate, bypassing the filter, and the clogged filter will not cause slow water dispensing or low ice production. However, in order to have filtered water, you will need to install a new filter.
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Hope this helpout in changing the water filter......
Aug 10, 2010 | GE Refrigerators
Water dispenser makes noise
sounds like your problem is a drop in water pressure on the water department side. is your facuets good? have water company come out (should be no charge if city water) and put a pressure gauge on outside of house.
Jun 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Water dispenser will come on at random times
are you talking about the lever where you put your glass to get water or the ice compartment if it where you put your glass to get water it could be that if the pressure is not strong enough to close the valve after you have taken a glass of water or a defective solenoid vavle thanks from gilles
Jan 17, 2009 | GE GSS20IEP Side by Side Refrigerator
Water Dispenser
does your refrig have a built in water filter? it may need replacing. if thats ok try checking your water supply to be sure that there isnt a kinked water line. if both of those check ok you may have a bad fill valve.
Dec 11, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
501 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
