Question about Panasonic PT L711U Multimedia Projector
PT L711U + all my black colors are blue
I have a Panasonic PT L711U, the back ground color is blue and the color bleeds over any image. Also all the blues are black on the screen. Also after you pull up the main menu or if attach a laptop to it you will see a light burn in of that screen.
  • petersonc Apr 18, 2009
    The last time it was serviced was 2003, and the lamp has 1300hours on it.
  • Maurice B Thomas
    Maurice B Thomas May 11, 2010
    Your projector requires service in the form of an alignment, perhaps.
    How long has it been in service in terms of number of hours?
  • 371 Answers
Your projector needs to be aligned and serviced, normal occurrence
after 6 years since service.
Posted on Apr 19, 2009
Color Wheel
I'm pretty sure if the color wheel spins with no vibration that it's not the colorwheel. I would have to say that your cable is bad. If it has been bent repeatedly near the connection that the wires could be breaking down. Try a brand new cable.
May 06, 2010 | Panasonic PT-D4000U Projector
I have a panasonic pt-60dl54, the sound works but green picture
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens.You will need to replace the DMD board. Have a blessed one!
Apr 13, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Poor image
check the menu for color convergence option try that
May 15, 2009 | Panasonic PT-50LC13 50" Rear Projection...
PANASONIC PTK-4077S PROJECTION
You need to adjust screen drives on Red Green Blue tubes ,does all 3 of them light up? Focus/screen control box is in front of TV behind front panel Turn color off then adjust all 3 tubes to where you have a black and white looking picture, now turn color back on.
Dec 27, 2008 | Panasonic PT-51HX42 51" Rear Projection...
Pt-52lcx65 52 in.
call panasonic customer service....open a claim....problem is most likely that the eprom needs to be reflashed.....i contacted them several weeks ago, told them my problem which was 5 baseball sized colored spots, 1 red, 2 blue and 2 green. they had me perform a couple of tests using a dvd. when i reported the results they set up a service call with a local authorized repair shop. results were amazing. reflashing the eprom took about 4-6 minutes. in addition my brilliant color returned to the set as well as another problem of neon images going away. this was paid for by panasonic. my set was 2 years over warranty. panasonic has issued a service bulletin on this and are backing up these units.
pt-61lcx35
hope this helps, i am quite satisfied with what was done.
Dec 18, 2008 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT-53WX52F Color blue adjustment
most likely the two convergence Ics need to be replaced. They are STK392-110 you can get replacements at the following link with free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Jul 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic pt l711u power will not stay on
That used to happen to my PT 711U until I put in a new air filter. After that, no problem.
Dec 28, 2007 | Panasonic PT L711U Multimedia Projector
Dark picture
do you get all three colors? red, blue and green?
Dec 16, 2007 | Panasonic PT-51G44 51" Rear Projection...
Panasonic PT-AE900U displays black and white only
sounds like bad cables, or wrong setting on projector you may have it set to compoent instead of composite,, you don't tell how you are hooking it up. (what type of cables you are using)
Oct 25, 2007 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT L711U Multimedia Projector Logo
263 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
