Question about Heavy Machinery
Can't start Chipper
I cant get the flywheel to turn on Sears 5 HP chipper shredder. I pulled the starting cord once and the flywheel spun and now it seems to be locked-up? Help? Will from Kentucky
Unplug the spark plug wire FIRST.  DO NOT SKIP THAT.  Then, WITH THE SPARK PLUG WIRE UNPLUGGED AND DISCONNECTED AND NOWHERE NEAR THE PLUG TIP, get a good sized stick, and try to turn the cutter wheel assembly in reverse.  I suspect you have a piece of wood stuck in there, and it won't come loose unless you turn the thing backwards.  You have to disconnect the spark plug because the engine could fire when you turn it.  Even if it doesn't start, one good kick could hurt you pretty seriously.  So, go unplug the spark plug and do your thing.
Posted on Apr 19, 2009
Balde wheel is engaged while trying to pull start making the task extremely difficult. is there a clutch mechenism that is not dissengaging?
No. The blade is like a flywheel and is connected directly on the motor shaft. However, these usually have separate choke and throttle handles. I have found that they start easiest if the throttle is set pretty low and the choke is closed. Once it starts to fire, then slowly open the choke - allowing it to pick up a bit of speed before you open the choke all of the way. Then wait a few seconds before turning up the throttle. On the other hand, if you have debris in the machine making it hard to turn, you will have to clean some of it out before you start it. Good luck, Al K
May 22, 2011 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Will not crank. will turn once , then lockup. have to turn the flywheel backwards and then cord will pull only once.
From your description sounds like the spring is broke. It is secured at both end may have slipped past retainer on one end or the other. If this is the case may be able to fix without buying new spring.
Sep 28, 2010 | Troy-Bilt Chipper Shredder
Need owners manual for 2001 yard machine chipper schredder model #24A464B131
I have a operator's manual for 24a 463b129 5.5 hp. I also have an operator's manual for the engine (Tecumseh). I purchased the chipper new from Home Depot back in 2002. I think you will be disappointed at the lack of information. If still interested, e-mail me your e-mail address, and I can send you a PDF copy of these manuals. (wchan@bushbros.com)
Mar 27, 2010 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Sears craftsman 6hp chipper-shredder FLYWHEEL.
Go to Lowe's they will found the part for on the computer and will tell you where it is at in the store!!
Oct 12, 2009 | Craftsman Gas Mini - Tiller/Edger
I have Chipper/Shredder model 47321, 10 HP. I have
try changing spark plug, if unit sits outside rain can rust the coil but I would try a new spark plug first and make sure it;s gaped correctly
Oct 03, 2009 | Troy-Bilt Chipper Shredder
Difficult to start chipper while gears engaged
The drive belt may be the wrong size if there is no play in the clutch. I have a 10 hp, but there is a common manual for the 10 and 8. My belt is a 4L380.
Jul 12, 2009 | Troy-Bilt Chipper Shredder
10 hp Troy Built chipper pull start frozen
If a branch was already being chipped when it ran out of gas...you must clear the hopper of any chunks of wood in it. Pull the plug wire and use a metal pry bar to dislodge any pieces of wood. when the flywheel runs free, put the plug wire back on and the choke on. Try it now!!!
Jun 14, 2009 | Troy-BiltĀ® Briggs and Stratton Chipper
Chipper won't start
what engine do you have im guessing a briggs & stratton was it running previously or sitting awhile it can be a few things the flywheel key could be sheered or the points are bad or the flywheel & coil are rusted check flywheel & coil to see if rusted if so take coil off mild sand paper like 80 grit i beleave clean both to get the right gap between flywheel & coil turn the flywheel alittle bit so the magnets won't touch coil or if coil still of set flywheel to where it will touch magnets fat peice of sand paper not folded but flat sand paper about .020 gap between magnet & coil if you place sand paper against the flywheel magnet then set coil against sand paper & magnet that should give you 0.020 gap & it should start if not e-mail me i will guide you through everything to get it started
May 11, 2009 | Heavy Machinery
New MacKissic chipper, wont start
it sounds like it is jammed up, take off the plug wire and look inside discharge chute for any debris.
Apr 04, 2009 | Heavy Machinery
5 HP troy bilt chipper sherdder will not rev up under load
Either or do one of two things if the motor runs pretty well Start the engine and run it full throttle. Once there if it has a high speed jet turn the screw in to start with until the engine stumbles a bit and then turn it back about a half turn. When you turn it in you should here the engine peak out. .If it is blowing black smoke out the exhaust it means the high speed screw is to far out so turn it in until it smooths out.If the engine smooths out then you have cured the problem. Good luck.
Mar 18, 2009 | Troy Bilt 24b - 060f766 5hp Chipper...
Heavy Machinery Logo
360 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
