Question about Vehicle Parts & Accessories
Nikon Central Locking System Continous Beeping
Hi All,
My Maruti Zen has GENUINE company fitted Nikon Central Locking System. My problem is that it beeps continuously w/o any reason now. I am told that I need to reprogram the system but I do not know how do I do that? Any help in this regard. The workaround I've done now is to remove the control panel plate from the car to shut down the beeper but that has disabled my car's central locking completely. Any help in this regard is deeply appreciated!!
Regards,
Manish Kumar
  • 4 Answers
SOURCE: Central locking
RikA4
Rank:nonexpert_s.gif Apprentice
Rating: 100%, 2 votes
Hi g79radu.
The most likely cause is a faulty Central Locking Pump. I had this problem recently and it is apparently quite a common fault on the A4. When you use the key manually can you hear a kind of humming noise for about 20 seconds or so coming from the rear of the car? If you can it indicates that the pump is trying to open the doors but something is preventing it.It might just be a leak in one of the air hoses but more than likely the compressor wheel inside the pump has disintegrated. I posted a solution to this the other day so I will just copy/paste it here for you.
There are 2 ways of solving it. The first is to pay your Audi Service Centre £350-£550 to replace it for you and the second way is to do it yourself which will cost well under £100 (depending on ebay). Firstly check the Central Locking Pump to make sure the hoses haven't come off. This is located in the very back right hand corner of the boot so you will need to remove the carpet and internal trim and you will see a block of sponge. Carefully lift the top off this and you will see the pump sat inside it.
Actually there is a great set of photos online to help you and I will add the link for you at the end. If the hoses are still connected and not leaking it is very likely that the internal compressor wheel has shattered (quite a common fault). I believe it is possible to open the pump and replace this wheel (in fact there is one for sale on a very popular auction site at the moment) but my own preference was to simply buy a whole new pump and replace that (£16.00 + £8 p+p off the same auction site).
The most important thing for you to remember is that when you look to buy a replacement pump you need to find one with the EXACT same serial number. The one in the diagram shown is
8LO 862 257 N but I have a sneaky feeling yours might end in an A.
Anyway, I hope this is of some help and dont worry about the connections as both air connectors and all 3 electrical ones are different sizes and will only fit in one place each. Mines a standard A4 but I would imagine evrything would be similar for the Quattro.
Good luck.
Rik
http://www.audiworld.com/tech/elec131.shtml
Posted on Aug 29, 2008
SOURCE: Central Locking system blows 20 A fuse.
In response to your request I'd like to say that I have not solved the problem yet but intend to investigate the central locking relay in the engine compartment.
Also wish to say that I was led to believe that Fixya was a group of enthusiasts willing to share their knowledge. I did not understatnd that it was a for fee service.
Thanks for the reply.
les87
Posted on Dec 28, 2008
  • 45 Answers
SOURCE: Car alarm not activating central locking
It means that the remote is not passing the signal to the car . The alarm has triggered because the system has detected an illegal entry. Replace the remote batteries
Posted on Jan 07, 2009
jpk528
  • 95 Answers
SOURCE: keyless entry
trunk release wire goes to the trunk wire of the vehicle and the flash output goes to your parking lights. Now if the trunk release is a positive wire than you will have to put a relay in to make it positive and if your parking lights are negative than you will have to put a relay in to make it negative.
Posted on Mar 01, 2009
SOURCE: central locking on citroen xsara 2003
We have this problem too - can only lock the doors by shutting front doors - climb into the car via the back doors - lock front doors from inside and then manually lock back door. Boot is difficult to lock - takes about 3 or 4 attempts to lock it. Driving me mad!! Have been told it is probably worn or broken wires in the flexi hose in the door hinge. I may have to take it to the garage to get repaired.
Posted on Mar 08, 2009
How to connect aftermarket alarm with factory central locking Hyundai i20
What's the year, make and model of the vehicle? What alarm did you use, brand and model?
Feb 22, 2014 | Vehicle Parts & Accessories
Is it possible to fit a remote central locking system for my car?
Absolutley, no worries at all, you can get them at Super cheap for about 60 bucks and if you want to save time and hastle only fit the drivers door solenoid. You will have to probe the old system (key op) to find the sighnal wire to the other door solenoids and wire the new one to supply its signal there. Keep the leftover solenoids in case one failes in the future.
Nov 13, 2011 | Cars & Trucks
Where can i get arepair manual for a maruti zen 2002 16 valve engine
ebay or a book store. have you tried a a google search?
Feb 03, 2011 | 2001 Suzuki Swift
Central door lock system not working
CHECK THE DOOR LOCKS MAIN FUSE.
May 03, 2010 | 2000 Honda Accord
My Vauxhall Calibra central locking has locked permanently so that I am not able to get into the vehicle. I have a Cobra demobiliser/ remotely operated lock fitted which responds by flashing and beeping...
What else do you expect from a boy racer sunday mechanic system,rip it out and just use a crook lock ,Nothing but trouble these aftermarket stirling mose or halfords made in china junk .The chips used are poor quality and always go wrong.Also it wouldnt stop me for more than a few minutes to steal car just cut battery earth cable from below the lift car with tow truck.easy
Dec 07, 2009 | 1984 GMC Caballero
Maruti zen engine stops working when running on slow speed.
you may try replacing the clutch lining, it may be too thin. hope this helps
Jul 15, 2009 | 1996 Suzuki Esteem
Sep 10, 2008 | 2006 Mitsubishi Colt
Aftermarket installation of remote central locking on 2006 Nissan Navara ST-R
Doesn't matter, I have given up, the existing central locking components are completely different to that of the new kit, I think I will just have to put my tail between my legs and go genuine, getting a Nissan dealership to fit it for me.
Jul 20, 2008 | 2006 Nissan Murano
Maruti Zen 1996 model....spongy brakes
you should bleed the brake lines you probably got air in them or have the breaks preasure tested to see if theres fault in lines or hardware
Jun 13, 2008 | 1996 Suzuki Esteem
Vehicle Parts & Accessories Logo
196 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
