Question about Gateway 310S (2900621) PC Desktop
Can the 310S PC Desktop Use HDDs running at 7200 RPM?
This is a simple question. Can the Gateway 310S Desktop PC use IDE Hard Drives running at 7200 rpm?
  • 62 Answers
If there are unused connectors on the hard drive ribbon cables, and unused molex power plugs, then yes. Be sure to securely mount the drives in the case. Also check the jumper settings for all drives.
Posted on Apr 18, 2009
How do I copy the files on a Simple Tech 250GB USB2.0 External IDE Hard Drive to a new 500GB USB2.0 IDE External Hard drive?
If you have them hooked up to the same machine, you should be able to drag and drop easily. Just find them under "Computer" like any other external drive
Nov 16, 2012 | SimpleTech 250GB USB2.0 7200 RPM External...
Simple tech 320 gb not spinning
Try a new usb cable or a different usb enclosure.
Also try and remove the drive from it's enclosure and connect direct to a sata port on a desktop pc.
Aug 23, 2012 | SimpleTech 250GB USB2.0 7200 RPM External...
I HAVE A GATEWAY GT5026E DESKTOP , MY HARD DRIVE IS SHOT WHAT HARD DRIVE CAN I USE TO REPLACE THE OLD ONE AND WHERE CAN I GO TO GET A NEW ..
This model Gateway is installed with a
250 GB 7200 RPM Serial ATA hard drive
You can install any make of SATA hard drive you wish, you may like to install a larger capacity SATA hard drive.
These SATA hard drives can be purchased over the Internet or at any computer shop.
Mar 06, 2012 | Gateway GT5026E PC Desktop
I need the dc power supply for SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Your solution is a 12 volt 1.5amp chord. With a negative outside/ positive inside plug tip polarity. Simple Tech model and part number: SYS1298-1812-W2
Jan 08, 2012 | SimpleTech 250GB USB2.0 7200 RPM External...
How do i use it?????
This hard drive come with a cable. The cable is a USB Cable Its simple to use!
Connect the hard drive to USB Cable and other end connect to your computer's USB port.
If you have Laptop computer these USB ports are on the side or back of the computer and if you have desktop computer the USB ports are mainly in the back!
Sep 08, 2011 | SimpleTech 250GB USB2.0 7200 RPM External...
Can this take a 7200 RPM HDD?
The only compatibility issue for a hard drive with your laptop is the interface, whether it's IDE/PATA or SATA. Seeing as it's an old laptop, it's probably IDE, and I don't think you'll find many 7200 RPM laptop IDE hard drives. All the 7200 RPM laptop hard drives I know are SATA. So, probably not. If you need more help with your laptop repair, contact me through my website.
Nov 04, 2009 | Toshiba Satellite M35X-S109 Notebook
Simple tech problem
windows 2000 detects the driver for plug n play drives for it self and if it doesnt then try driverguide.com for drivers of the disk.
Nov 08, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Does simple tech 250 drive need an external power source?
Yes, you need a power supply. I have several USB peripherals that, in a similar way, APPEAR to be on when you plug them into USB. But that interface cannot supply enough power to actually run the machine. The maximum is 0.5 A * 5 V = 2.5 W. The wee portable drives can run on that power, but a normal desktop drive, such as is inside a full-size desktop external enclosure, use ~ 8 W.
So you need a DC power supply! I bet SimpleTech can tell you what the correct current, voltage, and polarity is. Good luck.
Sep 04, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Gateway 310S (2900621) PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
