Question about Sony PlayStation Portable (PSP) Console
How do i change my psp icons - Sony PlayStation Portable (PSP) Console
  • Anonymous Apr 20, 2009
    How do you get custum icons to your psp
    Problem Solver:
  • 8 Answers
You need to install a new theme. =D
Posted on Apr 19, 2009
My umd icon is not showing up how do i fix it
Hi there. Try doing this;
1. Turn off your PSP (long press switch). 2. Press and hold "R" while switching on your PSP and you'll boot into Recovery Menu 3. Scroll down to "UMD Mode" and press "X" until the value changes to "S0NY NP9600" 4. Go back and exit to boot your PSP in game mode...
I hope this helped...
Jun 08, 2011 | Sony PlayStation Portable (PSP) Console
Tip
How to install Firmware on your Sony PSP
<li> <p>Visit the sony PSP website by going to: http://www.us.playstation.com/Support/SystemUpdates/PSP/PC.html<br /></li> <li> 2 <p>Click the Download Now button, which is located under Step 3 under the "Download Procedure."<br /></li> <li> 3 <p>Verify that the file will be saved with the name "EBOOT.PBP" and save it to your desktop.<br /></li> <li> 4 <p>Connect your PSP to your <a href="http://www.ehow.com/computers/">computer</a> via the USB cable. When the cord is plugged in, select "USB Connection" under the Settngs menu on your PSP.<br /></li> <li> 5 <p>Let the PSP window open up on your desktop. This will take a minute, so be patient. From the window, select "View Files."<br /></li> <li> 6 <p>Select the Games folder from the open window.<br /></li> <li> 7 <p>Select and save the file into the Update folder. If there is not an Update folder already made, make one by right clicking your mouse and selecting "New Folder." Save the folder with the name "Update."<br /></li> <li> 8 <p>Safely remove your PSP from your computer by right clicking and selecting "Safely Remove" from the green arrow icon in the tray on the bottom left of your computer's screen.<br /></li> <li> 9 <p>Use the right arrow key on your PSP to highlight the Game icon from the PSP menu.<br /></li> <li> 10 <p>Scroll down and click on the "Memory Stick" icon. This is usually the last icon in the list.<br /></li> <li> 11 <p>Click the PSP Update icon and follow all of the instructions that it tells you to follow. You will now have the latest version of firmware on your PSP.<br /></li> <br /> <span>Tips & Warnings</span> <ul> <li> After the new firmware has been installed, you can delete the update from your PSP to free up space.</li> <li> None of your saved files will be deleted from updating firmware versions.</li></ul><br />
on Jan 04, 2011 | Sony PlayStation Portable (PSP) Console
Tip
Psp tips on: backround colour, file images, car stereo system.
The PSP is the hottest little handheld around right now. The PlayStation Portable Handheld system is very impressive and plays great games, music and movies. Additionally, the system does have a few tricks as well. Here are a couple of things you can try, some are fairly simple. Please note you must be careful with some of these tricks and they will be marked by a * before the “how to” area. Due to the price and the sensitive LCD screen always use caution when trying anything below.
Jam to Tunes Using Your Car Stereo System Speakers * Use the following instructions to play your PSP games and movies with your cars audio system. You will need a FM modulator, a cable with a male stereo 1/8" headphone connector at one end and split left and right RCA connectors at the other. The red wire with the 'in' line fuse goes to your car battery or switch. The ground wire grounds to the frame. Set the car's CD or tape deck to the FM frequency that is on the modulator. The frequency is usually 88.7 or 89.1. Plug the RCA connectors from the cable into the RCA jacks on the modulator. Plug the headphone end of the cable into the PSP. Turn on the PSP with the volume set at half way.
The PSP's sound goes through your car's antenna. No extra wires are needed nor are any other adjustments. Your games, music and movies will now play through your car's stereo speakers. Please note: take care when trying this and make sure you know how to use the modulator and know the right way to hook up the wire to the fuse box and ground wire. If this is not done right, this can damage or even short out the PSP. This one is for parents!
Changing the Save File images * Whenever you save a game, one or two pictures are created on your memory stick: ICON#.PNG - the 144x80 icon displayed when you select your saved file. The #, normally 0, may be higher if a game places multiple saves in one folder. PIC 1. PNG - the 480x272 background that's displayed when you cursor over your save or game disk. Knowing this, you can customize your save icons and backgrounds by simply replacing them with new . PNG files. However, make sure that you keep the new file less than or equal to the original file's resolution, or the PSP will cut off sections to make it fit.
First Connect your PSP to your PC. Then locate the save file you want to change. All saves are located in the PSPSAVEDATA folder, divided into separate sub folders to keep necessary files together. Once you've found the save icon you want to change, add .ori to the end of the file name, in case you ever want to change it back to the original. Resize the image you want as you're save icon to 144x80 and save it as a .PNG named ICON#.PNG - “where # was the number found on the file you renamed”. Then move the new picture into your save folder.
Now, whenever you see your save files on your PSP, its icon will be the picture you changed it to. Use the same method to change PIC 1.PNG files to your own custom pictures, but remember that the resolutions must be at most 480x272. *Please note this is a bit complicated and could result in losing all saves if not done correctly. This tweak is really for those who have knowledge of using these types of files. Please use caution when attempting this or have someone that knows how to work with these files help you.
Choosing a Background Color and Keeping it the Same The PSP will change colors of the background screen every month automatically. You can pick a color that you like and have it stay that way. Simply go into the settings and select the month that has that color, when it changes, reselect the month. Note: Your date will always be wrong, but if color and style is your concern, this simple tweak does the trick.
on Jan 06, 2010 | Sony PlayStation Portable (PSP) Console
The UMD icon ony PSP is not displaying?
the umd icon does not show on my psp?
Jan 01, 2010 | Sony PSP (Piano Black)
Umm i my psp can't play songs. i select the music icon then it freezes. this happened right after i changed the original theme and the xmb wave. here are my psp specs: psp model 1001 custom firmware...
hardboot your psp and hold r then you should see recovery menu go to plugins and turn cxmb.prx off okay and then delete the theme from your mem stick and then reenable cxmb.prx
Feb 24, 2009 | Sony PlayStation Portable (PSP) Console
PSP DOWNLOADING PICTURES
just format your memory stick using the psp format option.after that hook it up on the pc and wallah!!! you have six folders available on the menu including music,photo,psp,etc...hope it helps
Dec 15, 2008 | Sony PlayStation Portable (PSP) Console
Cerfer39
ok here is how this is fixed, first you start with turning the psp on let it start and all that. Then you have to scroll all the way where you see like a tool box its all the way to the left or just use the left button. ok so after that just just click all the way up so the very first icon (two arrows making a circle) is shown. Ok starting from the two arrows scroll or push the down button four times where you'll get the psp icon. Click on that once. and then once more or it should be the second icon from the top. So if you do that you'll get the language menu and just click on English or any other language you wanna choose. Let me know if need more help regarding this problem
Oct 02, 2008 | Sony PlayStation Portable (PSP) Console
Psp icons
you can download different things to change your psp icons.
go here. http://pspslimhacks.com/ptf-psp-themes/
Jun 06, 2008 | Sony PlayStation Portable (PSP) Console
PSP problems
what firmware is your psp?
Feb 28, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
