Question about Dell Office Equipment & Supplies
Does not print. Does not read "READY" reads "DELETE"
Printer not printing. not showing "ready" reads "delete"
Basic, read the manual turned the computer add printer off counted to 30, started plugging things back in and bingo everything isworking AOK.
Thanks,Bob
Posted on Apr 19, 2009
Does not print
Click Start/Control Panel and look the Printer within the control panel. Open it and make sure you don't have the same printer installed more than once on your system. If you do then you can get the system confused and the queue backed up if you print to one that is not ready. If you have more than one then delete it.
Also open the printer properties and make sure you are using the right connection such as USB, LPT1, Wireless, TCPIP (Network).
When you open a document and get ready to print, rather than hit the print icon, click File, then select Print. When the print window opens you can click the drop down arrow on the Name to see if the same printer is installed more than once. You can also get to the printer properties this way.
If you have a printer icon at the bottom right near the time on your screen open it and delete all the documents that are backed up waiting to print.
Apr 14, 2012 | Dell Vostro 200 PC Desktop
Trying to print a picture from my dell computer. when i hit print on the computer printer does not print. what button do i push on the printer itself. when i go to view/print it just says to insert memory...
With the printer power on, unplug and then plug in the printer from/to the computer. This should force the printer to be reinstalled.
Check the printer status.
Click START>Control Panel>Devices and Printers>click on your printer. check the status for any error messages. On the printer status, delete all pending jobs. Once the printer status display shows that all pending jobs have been deleted, retry printing.
Let me know if printing is reestablished. Thanks.
Mar 15, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Canon PIXMAMX347 1. My Print and Fax Screen shows that the "Canon MX340 Series oOffline,Default". How to I get it back to "Idle, Default" which is the equivalent of "Online,...
right click on the printer driver and read through all the task you will see online then click on it if the problem persist Delete the printer driver then reinstall it back it will work and make sure you don't have more than one printer driver on your computer iF you does notice the one that is ready when you put on your printer then make that one your default printer driver if this confuse you delete all the printer driver and reinstall new one.
Jan 30, 2011 | Computers & Internet
Minolta Magicolor 3100 ... Printer sayes its online and ready to print. When i send a print job it spools it ok but when it goes to print it goes offline. I delete the print job and the printer is back...
Does the printer show any message on it's display ?
Most common problem with these printers is the driver setting (mostly media type/weight) conflicting with the settings made via the front panel menu's.
Jan 04, 2011 | Minolta magicolor 3100 Laser Printer
Printer loaded with paper. Printer window reads Out of Paper and wont print or delete current job. How to reset?
if computer says out of paper but printer is in ready state computer does not see printer (conection)
Jul 28, 2010 | HP LASERJET P1005 Printer
How do I turn it on
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look for Print Spooler in the list
highlight Print Spooler,
Click on STOP button then click on START
close the window and check if the print queue is gone.
Alternate method,
Click STart
Click RUN
Type Cmd ( or COMMAND ) and hit enter
In the black window type
NET STOP SPOOLER ( hit enter button )
Type
NET START SPOOLER ( hit enter button )
Repeat the Stop and START Command 4-5 times
End the Command with NET START SPOOLER
Open Printers and faxes folder - Refresh the Window - the printer will show STatus ready with 0 document
Jun 19, 2010 | Dell 926 All-In-One InkJet Printer
Document failed to print" message
Hi go into settings on you're printer & clear the pending queue it will not print till u delete them ..cheers
Jan 18, 2018 | Dell 1600n All-In-One Laser Printer
I attempted to print a 25 page document, with reverse pages. Only 9 pages printed. I cannot print anything now. and the message on the printer reads, DATA REMAINING. I have pushed every button...
It seems the printer buffer memory has overflowed. Cancel the print from the print Que and switch off the printer. Give your PC a reboot too. Now switch on the printer and make sure that there is no document in the print Que. If its still there, disconnect the printer and delete the pending job, i.e. print Que. After the printer shows it ready for printing do not release the entire document for printing at one go. Breakup the print job in 3 parts and for each part manually enter the page numbers and then give the print command. Repeat this till the entire lot is over..........................sodeep
Apr 14, 2009 | Brother Office Equipment & Supplies
Printer
Check cable is secure from pc to printer
Check printer can print a status page via printer keypad and is online/ready
If these are ok then it is a print driver issue
Turn off printer, Unplug usb, delete and reinstall print driver
Jan 11, 2008 | Kyocera FS-C5030N Led Printer
Printing test page
well as it seams u have given the order to ur pc to prin a test page before....but it wasnt responting so u keeped pressing the bottom..! so to fix that u can go to contro panel>printers and faxes and there u can find ur printers name...after that duble-click on ur printer and it shows a printer dialog...then delete ALL the documents that is ready to print...after that u r ready to print again!! but always remember that if u "say" to ur printer to print a page and it doesnt respont as soon as posible, it doesnt mean it wont print!! just click ONCE the print bottom the other time :)
dont foget to vote!! :)
Stratos
Nov 26, 2007 | HP PSC 1510 All-In-One InkJet Printer
37 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
