Question about Sony SPP 935 Cordless Phone (SPP-935)
SPP-935 Cordless Phone
My cordless phone will not allow me to dial out. Once I pick-up the receiver, I get a dial tone but it will not let me dial a number. I can dial from the base but occasionally it will just hang-up on me during my conversation. I have tried to disconnect both the power and phone line and wait for a few minutes before reconnecting. I hoped to reset the phone, it continues. I have two (2) set and both are doing the same thing.
pnevai
  • 48 Answers
SOURCE: Sony spp-900 cordless phone
Go to the sony website and down load the user manual at this link. http://esupport.sony.com/US/perl/model-documents.pl?mdl=SPP900®ion_id=1
Posted on Jun 29, 2007
SOURCE: how to program speed dial on sony spp-a946 cordless phone
  1. Press 'PGM'- "program" button.
  2. Press "speed dial" button.
  3. Select "station # " i.e. any button from 1-9 for speed dialing.
  4. (make sure to make a note of this selected # against the corresponding tel # and /or the person's name)
  5. Dial the complete (incl. 1 for USA or country code for other country tel. #s) telephone number to be stored for the selected speed dialing station #.
  6. Press "PGM" button again to complete the storing of the tel #.
  7. Test, after dial tone, by just pressing the selected station #
Posted on Mar 17, 2009
SOURCE: GE Cordless 25952EE1 A Cordless wont register in base base flas
After talking with Thomson Inc today your best bet is to get rid of the phone. I found out today this phone has a real problem as I see it. I can use my handset on other bases. So that means anyone with this model handset can access your line. Thomson agreed today that this is possible. All I got was a SORRY!
Posted on Mar 27, 2009
daves944
  • 1050 Answers
SOURCE: DOWNLOAD MANUAL FOR Sony SPP AQ600 Cordless Phone
Right here:
http://esupport.sony.com/US/perl/model-home.pl?mdl=SPPAQ600&LOC=3
Posted on Mar 31, 2009
SOURCE: Cordless phones display searching for base.
Same problem: registering base ID on cordless get T23 PD error and subsequently, Searching for Base
Posted on Sep 29, 2009
Hi, I have a Panasonic Cordless phone with 2 bases. I have moved one from upstairs to the phone jacket downstairs. Our third phone worked fine until I switched two of them around. Now only the plugged...
You could plug your non-cordless phone into suspicious phone jack to see if you have dial tone-if you dont have dial tone, the line maynot be connected and you should open the jack to see if there is more than 1 cable attached. If there is more than 1 cable attached and you dont have dial tone at other end of cable the cable might be cut or shorted somewhere inbetween. You can test continuity by tying 2 wires together and test with a multimeter on resistance to see if it is open circuit or maybe even short circuit. To test for short circuit, untie the cables and you should not get a reading. If you do have dial tone when you plug in non-cordless phone the distance might be to far for receiver to pick it up(ie..greater than 10 metres). I hope this has been helpful.
Aug 26, 2011 | Panasonic Lands Phones
Replaced battery in handset. Got a dial tone and all was well. Picked up handset later in the day and it was dead. Unplugged and reattached everything - no luck.
Try taking batteries out, but also unplug base station. The aim is to disperse all power in the phone so that it resets itself. I would leave everything unplugged for 24 hours and then reassemble and see if the problem has gone. Its worked for me loads of times with different electrical appliances. Hope that helps.
Apr 23, 2009 | Sony SPP A1050 Cordless Phone
How to program speed dial on sony spp-a946 cordless phone
Mar 13, 2009 | Sony SPP A946 Cordless Phone
Handset
I guess its time to get new batteries
Sep 23, 2008 | Sony SPP AQ600 Cordless Phone
Dial Tone Appears and Disappears
Any store offering phones will have replacement cables for low prices; replace this first. Your wall jack could also be damaged although the ones used by installers is generally very long-lived.
Aug 01, 2008 | Sony SPP IM977 Cordless Phone
Uniden TCX805 Cordless "loses" dial tone
Sounds like the switching mechanism that creates the link is stuck. When you answer your phone, you allow the voltage to complete it's path and you either answer the phone or you hear dial tone. If that switch is stuck closed, even though you hung up the phone, the connection is still alive. When you try to pick the phone back up later, the connection is still closed, but your phone has already passed it's "if you would like to make a call" message and you hear no dial tone. Unplugging the power to the phone resets this switch and all is good again.....that is until it gets stuck again. I have seen this problem with phones after a near lightening strike at the house. Sounds like you need to get a new phone as I don't think this is repairable.
Dec 30, 2007 | Uniden Cordless Phone
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Jun 28, 2007 | Sony SPP 900 Cordless Phone (SPP-900)
Sony SPP 935 Cordless Phone (SPP-935) Logo
Top Sony Lands Phones Experts
Are you a Sony Lands Phone Expert? Answer questions, earn points and help others
