Question about Black & Decker Garden
Everything seems to be working but has no pressure. cratsman 1900 pressure washer
    Problem Solver:
  • 15 Answers
This could only mean that the motor shaft that drives the pump is stripped take it apart and drill a small hole through shaft and drive and thread the hole and insert a screw through
Posted on Apr 19, 2009
Code 14 no start
error code 14
Faulty intake air pressure sensor hose
system; a hose is detached, causing
constant application of the
atmospheric pressure to the sensor;
or, the hose is clogged.
 Intake air pressure sensor hose is detached, clogged,
kinked, or pinched.
 Malfunction in ECU. 03
Jan 01, 2011 | Yamaha 1900 XV 1900 A Midnight Star
Have a Karcher 3000G pressure washer, low pressure. How do you remove the unloader valve?
Ask the professor. He knows everything about everything. I'm working on my degree now. Go to Youtube like he does. LOL
Aug 08, 2010 | Karcher 2500 PSI Pressure Washer
Water not filling.
r u using auto fill mode?if u r then try selecting high medium or low. check water pressure coming out of inlet hose, could b faulty valve not letting enough pressure thru.please reply if u need more help
Mar 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
Electric simoniz runs for a while than cuts off for awhile and st
Hello: Are you using and extension cord? You cannot, it will kill the motor. If this is not the problem it is the unloader valve sticking. This is quite a job to fix but can be done. Let me know.
Jul 01, 2009 | Honda Pressure Washer PSI 3000
Mi TM 2700 pressure washer has no pressure.
With the water on, to the washer and the unit running. Does the water come out at the same rate before the trigger as at does after the trigger (run test with spray nozzle removed). Its not impossible for unloader valve to be bad but it usually is a dependable component. Make sure the unit has the air purged from it properly before start-up, make sure there are no obstructions before the trigger, then the nozzle. The unloader valve just puts the pump into by-pass until the trigger is depressed.
Apr 10, 2009 | Mi T M WP-2700-4MHB Pressure Washer
Gas driven portable pressure washer no longer draws chemicals up
Picks up under low pressure conditions by adjusting wand or changing tip.
Mar 18, 2009 | Honda Garden
When my cratsman 2hp 4 gallon air compressor gets to full pressure (about 100lbs) it will kick off for about 5 seconds then kick back on for 5 to 10 seconds then off, then on. Just wondering what the...
If there are no major leaks and the pressure gauge shows no significant pressure loss yet the compressor cycles on and off every few seconds, then the air pressure switch is not set correctly. Go to http://www.generalairproducts.com/fireprotection/images/stories/Pressure-Switch-Adjustment-042705.pdf It shows how to set various pressure switches.
Mar 15, 2009 | Craftsman Air Tools & Compressors
Garden Logo
368 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
