Dropped toshiba hard drive no longer recognised by laptop
I have a Toshiba 1TB USB 3.5" external hard drive and it was recently dropped, less than two feet off my bed and landed on the floor. Since then when turning it on it has been making a strange noise and is not recognised by my laptop. I don't particularly want to send it off as it has personal data on there, what can i do?
    President:
  • 2,992 Answers
If Windows doesn't see the drive, the problem may simply be a connection that's come loose inside. A short drop might cause mechanical problems in the drive and make it unreadable, but the computer should still see it as a drive. You can try opening the case and checking that the cables to the drive are properly seated and that the interface circuit board hasn't been damaged. I'm not familiar with the Toshiba external drive, so I can't tell you how to open one. Some brands and models simply have screws. Others have snap-together designs or hidden clips that need a safecracker's skills to open.
Opening the unit will probably void any warranty it still has. Since you're concerned about sending it away with your personal data, you may just have to absorb the loss.
Posted on Apr 18, 2009
    Sniper:
  • 133 Answers
That clicking/knocking or squeal is the read/write heads touching the platters inside the hard drive. They should hover over them. Play TAPS!!!! Once those heads crash into the platters inside....its gone! Some companies charge big money ($100+/HR) to remove data from crashed hard drives. Take it outside and smash it with a sledge hammer.....at least no one will be able to get your data. Here is a company that does this type of work....good explanation here
http://www.datarecovery.com.sg/data_recovery/hard_disk_head_crash.htm
mtg
My Toshiba v63700-c 1TB external hard drive worked great in Window 7. My v63700-c does not like Surface 3 Pro. Do I need a new cable?
Somewhat depends on what "does not like" actually means. So far, I've not found any USB item that works differently on my Surface than on my laptop or desktop, Windows 7 or 8.
Is there an error message? What does it say?
Apr 14, 2015 | Toshiba Computers & Internet
Why do I get a clicking sound from my external hardrive?
My Seagate 1TB started doing the same thing before it died. My brother managed to get it working again long enough for me to move all of the files to a Toshiba 1TB solid state external drive. A couple of nice features to the Toshiba are that there is no power adapter (powered by the USB), there are no moving parts, and it is very compact. I slid mine into the space under the laptop stand. You might want to back up all of your data to another location just in case yours is getting ready to die.
Nov 03, 2014 | SimpleTech SimpleDrive Pininfarina 320GB...
Toshiba 1TB external hard drive does not show on menu
Open the file and cick save as. In the window that opens, select the external drive in the list.
or, right click the file and click copy. Open the external drive in my computer and click paste.
Mar 16, 2014 | Toshiba Computers & Internet
Cant see my passport external drive on new windows 8 laptop
Try unplugging from usb and plugging it back in. Also, you may need a SAS driver for your computer to recognize the drive. Some drives have internal encryption and require a driver before the computer recognizes them. Check the Mfg website to see whether this drive requires one.
Jan 03, 2014 | Western Digital 1TB My Passport Essential...
Toshiba DWC120 2TB Harddrive not recognised
Before connecting anything to an USB port you need to install the software for the device. Then you can connect it.
But when you have an old laptop it could be it can't handle the 2 TB.
First install the software that came with the drive. Then see if the laptop can handle the 2TB.
Dec 20, 2013 | Toshiba 2TB Desktop External HDD Hard...
My toshiba external hard drive is not being recognised
This problem occurs when the external drive is removed from the computer before the host computer has finished writing to the drive. This can cause the drive to fail and require formatting. When using a plug in drive you need to allow the system write to complete before removing it. This goes for Flash memory sticks/cards and hard drives.Try restarting the computer with the external drive plugged in and switched on, this may cause the fault to be fixed. Good luck.
Aug 07, 2012 | Toshiba E05A100PBU3XS Canvio 1TB USB 3.0...
I accidentally plugged in my 19v toshiba laptop adapter to my 16v 1tb external hard drive it started up but then i plugged it out soon is it possible that the hard drive will work or is it dead, if no
The electronics in the hard drive is damaged and cannot be repaired by us mortals.
There are companies that can recover data from damaged hard drives BUT it will cost you an arm and a leg for their services.
May 12, 2012 | Western Digital WD My Book Essential 1TB,...
500 MB data error(cyclic redundancy check) external hard drive is not accessible
1. this ( cyclic redundancy check) is the computers way of saying " i don't recognize the data check-sum.
2. This issue could be due to the data controller on the USB drive being defective.
3. try purchasing a new case with a new controller board.
4. Check to see if your 1TB USB drive is compatible with your pc.
Jun 13, 2011 | Toshiba 1TB Canvio for Mac USB 2.0...
I recently bought a Toshiba Satalite laptop to replace the one I dropped which was also a Toshiba Satalite. I had taken out the old hard drive and installed it in the new one but now it wont do anything...
Yes it does matter. XP was configured for the old Toshiba and this will only work if both Toshiba laptops are exactly the same model.
To get your new Toshiba operating, put the new hard drive with the Vista operating system back in the Toshiba laptop.
To transfer your data from the old hard drive, purchase a USB adapter hard drive case and place the old hard drive inside this case. This will then be an external USB hard drive.
Plug this USB hard drive into the new Toshiba's USB port and it will detect it as an external storage/hard drive. You can then open the various folders and files and copy the data files to your new Toshiba.
To free up disk space on this USB hard drive, delete the Windows folder, Program Files folder and other folders that are no longer needed.
Use this hard drive as a backup hard drive etc.
Sep 11, 2010 | Toshiba Computers & Internet
I have a Toshiba 1tb external hdd (px1396-3t01) and when i connect it to my laptop i see a blue flashing light..The disc is not recognised by the laptop! what can i do..???????
How old is your laptop? Are you running at least Windows XP Service Pack 3? If so, Right-click My Computer, then left-click Manage\Storage\Disc Management. Do you see your 1TB HDD listed? If so, is it described as Unallocated Space. If it says that it's Unallocated, then right-click in the black area and choose format, then follow the prompts from there. You should probably format it as NTFS. Be careful not to accidentally format a drive other than your 1TB HDD. If you don't see your drive listed in Disc Management then double check your connections. If all is connected well, then you should probably return it to wherever you bought it.
Nov 30, 2009 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
Computers & Internet Logo
211 people viewed this question
David Payne
David Payne
