Question about Nokia 6600
Nokia 1100 My Nokia 1100 starts torch light when I insert a Battery in to it. It is not even switch-ON.
  • Anonymous Mar 19, 2014
    My Nokia 1100 is turn off suddenly during call even battery is full.
Yap! it was damaged with moisture and was grounded.
Posted on Sep 20, 2007
  • 63 Answers
Hi There, When this happens it's a sign that u r phone got water damaged and the section for the torch light is shorting out. You need to get it to a repair personel to have it cleaned up . Sam !
Posted on Sep 19, 2007
Nokia 1100 shows battery empty while calling even if it is full charged
This is your battery problem. Just do the step below hope it will solve a bit. get fully discharge and let automatically switched off. then connect to charging but do not switched it on after showing full charge, disconnect charging and switched your phone on. initially do dis 4-5 time a week. After that do 1-2 a week. This will increase your battery strength.......
if not then change your battery.
Apr 21, 2011 | Nokia Cell Phones
Tip
Flashlight Battery and Bulb Installation and...
FLASHLIGHT
BATTERY INSTALLATION FOR TORCH:
Open the Torch Battery Door located on the bottom of the Torch.
Insert 4 “A A” (1 .5V UM-3) (not included) batteries (alkaline
batteries are recommended) into the torch compartment. Be sure
the polarity (+ and
-) matches, as marked inside the battery
compartment.
FLASHLIGHT:
Slide the Torch Function Switch to the “FLASH” position, the Torch will light. To turn off, slide the Torch Function Switch to the “OFF’ position.
FLASH/BLINK FUNCTION:
Slide the Torch Function Switch to “FLASH/BLINK” position, tha Torch will light and thc bulbs on both sides of Torch will blink.
BULB REPLACEMENT:
Rotate the Torch Cover anticlockwise to hear “click”
then p
ull out the cover, remove the old bulb. Then pull
out the torch cup, remove the blinker’s
old bulbs and
reinstall new bulbs. Replace the torch cup, then reinstall
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
Nokia 1100 Calls have started cutting out after less than a minute. New battery inserted but problem persists. Texting OK
Hi. The best thing you can do is take it in for a replacement, this sounds like a hardware problem which only the manufacturer would be able to fix.
Mar 01, 2011 | Nokia 1100
MY NOKIA 1100 SHOWS INSERT SIM EVEN IF I INSERT WORKING SIM
This can be caused if the sim slot in the phone is loose, this can be fixed very easily by taking it to a repair shop and having them change the sim holder.
Hope this helps, Joe
Feb 19, 2010 | Nokia 1100
Nokia 1100 shows battery low even after full
your mobile battery is dull check battery first by using another mobile
Jan 18, 2010 | Nokia 1100
1100 SHORT POSITION TORCH LIGHT TAKING ON
Hold on the C (cancel) key.
Oct 04, 2009 | Nokia 1100
Nokia 1100 sim not valid
nokia 1208 sim not valid plz solve my problem
Apr 09, 2009 | Nokia 1100
INSERT SIM PROBLEM TO NOKIA 1100
HI,
Insert the sim card firmly to avoid this message.
Thanks
Mar 24, 2009 | Nokia 1100
Nokia 6600 Logo
98 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
Laxman Bisht
Laxman Bisht
