Vcr repair I have an Lg brand vcr not sure of serial number.The ac line input is okay buy the dc is having problems.could it be tha regulators.
Where can I buy a new rubber band for the vhs Go
Posted on Jan 16, 2008
    Novelist:
    Champion:
  • 254 Answers
If you have a voltmeter and some tech savvy, you could check the output voltages (voltages which run the VCR circuitry, motors, etc.). You should find a +5 volt, +12 to 14 volt, possibly a -35 volt (for the display if it has one). If these are missing, then the unit will be utterly dead. Check the fuse: If blown, check associated circuitry on the primary (line voltage) side. The fuse almost always poofs for a reason, and until the bad components are found, it will blow again, perhaps causing more component damage. The switching transistor may be shorted, plus nearby resistors/diodes/capacitors poofed/shorted/defective. In many VCRs I've worked on, a capacitor on the primary side will fail, and cause a dead condition, sometimes causing the noted transistor to short. A thorough check is highly suggested. It isn't fun to install new parts, only to have them poofed by a yet remaining problem somewhere. Common failures on the secondary side (where the voltages noted above are rectified, filtered), are the electrolytic capacitors. Common values here are 1000MFD/16 volt, 1500MFD/10Volt, 2200MFD/10volt or close. Many of the older VCRs pre-90's developed this problem.
Posted on Sep 19, 2007
Need to know input, polarity and voltage to ensure I have the right adapter.
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Jun 24, 2013 - If the device has a DC input of +12V / 5.4A, get an adapter that has a DC output of +12V / 5.4A. If you have a universal adapter, make sure it has the proper current rating ... Ideally, you'll have the same voltage, current and polarity on your ......or hdmi on my laptop .can you say what's the reason for the same.
How to select an AC to DC power adapter - ApogeeKits
www.apogeekits.com/power_adapter_selection.htm
An explanation of regulated versus un-regulated AC to DC voltage power adapters. ...voltage output power adapters and how to use this information to select the right one... Some (more expensive) DC voltage output power adapters have voltage ... Care should be take to ensure that the maximum input voltage of the load ...
AC/DC Power adapter ' Laptop Parts 101
www.laptopparts101.com > Laptop parts
Dec 26, 2008 - It's very important to use the right adapter for your laptop. ... Polarityon the new adapter's plug must be the same as on the original ... AC/DC power adapter voltage and amperage ..... I have purchased an non-hp dc-dc convertor (150W), 12Vinput, 19V output. .... So the cable component has to be replace.
Determining Proper A/C Polarity - Galen Carol Audio
www.gcaudio.com > Resources > How-To's
Jan 10, 2016 | Computers & Internet
Cobra 200 has no power and lights do not light up
Could be a number of things power related. Check the input cables to the radio and find a broken cable or jack. Otherwise check the regulator circuit of the radio internally. If the external wires are not providing DC than it is likely the cabling.
Feb 01, 2015 | Cobra Radio Communications
Display does not light up on PFAFF 1475 CD
Could be an electronic issue. Take it to your local Pfaff dealer for an estimate on repairing it. The parts may or may not be available.
Feb 01, 2015 | PfaFF Sewing Machines
Ampair increase slowlwey after start the ac and stop tha ac
If you have an LG inverter model, the amperage does slowly increase until the inverter compressor has "ramped" up to full speed.. If the power trips out, I would suggest that the power supply is underrated. You may need a licenced electrician to resolve this. Alternatively, there could be a problem with the compressor. LG have 5 year warranty. Check your date of purchase. Also Check the serial number... the first 2 digits reveal what year and month it was made.
Jul 14, 2011 | LG Heating & Cooling
How can I operate my LG 26LE5300 LED LCD TV in my motorhome the most direct way possible (i.e....without an inverter)? This low power (40-50 watts) TV has an external brick to convert 120 AC to it's...
1) You need to look at the output current rating (AMP) of this AC to 24dc adapter, this 24vdc adapter is a regulated switching power supply that will maintain 24vdc output up the maximum current rating and also has shutdown circuits if the over current draw is detect and also if the output voltage goes up beyond 24vdc to protect the load (TV).
2) To use 12vdc to 24vdc DC-DC booster, it should have the following spec:
A) The output current rating should be at least 20% higher than the load requires to give its head room.
B) It must have regulated output that will maintain the 24vdc when the input (12vdc) will vary from 10vdc ~16vdc or higher since your batteries will not maintain exact 12vdc all the time.
C) It must have good protection circuits that will protect it self from reverse polarity connections, shorted output protection, over voltage output protection.
D) It should provide AC ripple spec on the 24vdc output, it should be in the milli-volt range (you will always get AC ripple riding on top of DC when you rectify the AC into DC).
These are the minimum requirement for your DC to DC booster, which you need to protect your TV and your motor home from burning down.
I hope I explain it OK to you.
Please leave rating if it helps.
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 15, 2011 | LG 26LE5300 26 in. LCD HDTV
MY TV is LG 42 PG 60D , serial number :803KCBD35285
Sound like ur Tuner board have intermitint problems,it work awhile,than the old problems occur again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.Because this problems come and goes.
Apr 30, 2010 | LG 42LC2D 42 in. LCD HDTV
MISSPLACED AC POWER SUPLY FOR "MY BOOK" 250 GB USB.
THE ANSWER TO MY QUESTION WAS FOUND OUT BY MYSELF BY VISITING A REPAIR / SERVICE DEPARTMENT AND MAKING ENQUIRIES CONCERNING THE DC OUTPUT OF THE AC ADAPTER ASSOCIATED WITH THE WESTERN DIGITAL, MY BOOK 250GB USB. tHE VOLTAGES ARE THESE. : - AC INPUT = 100 - 240 VOLTS 50/60 HZ
DC OUTPUT = 12 VOLTS ( REGULATED ) 2 - 0 A
CENTER PIN OF 12 VOLT DC INPUT PLUG IS " POSITIVE "
THANK YOU FOR THE SPACE TO ASK MY QUESTION.
Feb 18, 2009 | Western Digital My Book Essential Edition...
My LG VCR has a child lock feature, it was activated via remote (this disables the buttons on the vcr until you deactivate it via remote) i have now since lost the remote... i have unplugged it in an...
something simalar happened to me a while back,i had to hol 2 buttons in at once to deactivate,I googled my problem,you need the serial no and brand,then just type
"deactivate child lock on LG model No ******",I'm sure you'll find it....
Rod
Jul 15, 2008 | LG Televison & Video
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
