Lanier 5245 it has an error code SC329-00, - Office Equipment & Supplies
  • Wildekent Apr 22, 2009
    yes it was a *** teck induste trubel removed laser and reinstalled it solved by sp code 2109 1and 2 i think 4or 5 moor coides yes i got it runing this was i job interview thanks
    kw
Did this happen after the machine was serviced? this is typically when it would occur...."LD pitch error"
Perform LD pitch adjustment with SP109-3, and SP109-4 (400dpi & 600dpi) or the ribbon cable on LD unit is blocking proper movement of the unit.
Posted on Apr 22, 2009
Service code sc301 on a lainer ld0105
http://copierquestions.messageboardchat.com/post/ricoh-savin-and-lanier-error-codes-3442638
Looks like it's a Charge Corona Output Error 2 - Charge Current Leak
Lanier is now owned by Ricoh (Savin and Lanier) ... you should contact them for repairs if you are not qualified to repair it yourself. Remember, there are very high voltages in there and you can do serious harm to your printer ... or worse, YOU.
Mar 01, 2014 | Office Equipment & Supplies
Funtional code SC101-00 appears on Lanier 5245 copier when turned on. Exposure lamp is burning.
Hello!
There you are. You asked the question but you already know the answer.
The exposure lamp are burned so... this error code appears in the display.
You need to change the exposure lamp
Sep 10, 2011 | Ricoh Aficio 450 Copier
Lanier 5635 error code displaying a SC320
sc320 on the Lanier 5635 is a laser unit error code. Often if you power cycle the machine (turn it off with the orange power switch on the left side of the copier, wait a few seconds, then turn it back on) the code will clear and the copier will resume normal operation. If the error code comes back or doesn't clear, you'll probably need to replace either the entire laser assembly or the polygon mirror motor inside the laser unit. These are best done by a professional -- contact your local Lanier service company if the problem persists.
Oct 15, 2010 | Lanier 5222/27 Laser Printer
Lanier 5245 scanner light does not come on
Could be the exposure lamp or the lamp control board. You will need a service call or find some place to buy used parts and just swap them out.
Dec 14, 2009 | Lanier 5235 Printer
Lanier Model #7320 Copier SN 826255. Has a wrench
Press "clear/stop" and "8" at the same time. An error code will be displayed in the copy quantity window as long as those two button are held down. What is the error code? Each code is specific to different areas of the copier. I will be more than happy to assist you in resolving.
Sep 23, 2009 | Lanier Office Equipment & Supplies
I have a Lanier 5245. I am getting an error when
Your duplex is the big box on the right side of the machine push the back side shut against the machine and try again
May 08, 2009 | Lanier 5235 Printer
Lainer 5245 cs code 329-00
I believe that model is a Richo in a disguise.... To get into service mode, first press the yellow C/A botton, then the numbers 1 - 0 - 7, then press and Hold the red C/Stop botton for a few seconds and the display will change. Then you are in the Service Mode... Good Luck
Apr 18, 2009 | Lanier Office Equipment & Supplies
Error code SC302
From the Ricoh-Lanier Error Code Sheet:
SC302: Charge Corona Output Error 3 - Grid Voltage error - Charger Roller Current Leak.
I would suggest replacing first the charge roller and if that doesnt fix it, the HIgh Voltage Supply Board.
Mar 19, 2009 | Lanier 5222/27 Laser Printer
231 people viewed this question
k24674
jasbo
jasbo
