Question about Kenwood KAC-9152D Car Audio Amplifier
Amp turns off for a bit and back on when it hits hard
Ok so my amp is screwed into the back of my box
I have a 1000w Kenwood amp with 2 1200w subs that all came packaged together.
well when im bumpin the amp just seems to turn off for a bit(red light goes out) then it comes back on and visa versa
checked my ground and its not that
Also have 8 guage power cable if that helps anyone
please help
  • 47 Answers
You need thicker power wire. 8 guage will only kick out max of 400watts rms.
look into getting atleast 4 guage. this will sort out your problem and it will be cheaper then getting a power cap. also you will not need a 5 farad cap 1 or 2 will be more then enough :)
Posted on Apr 23, 2009
You do not have enough power coming from our car battery, your alt. may be going out. Look into a 5 farad power cap to store more power...
Posted on Apr 20, 2009
My sub kenwood excelon KFC-XW1200F is making vibration noises against the box and i have tightened all og the screws over and over. its not hiting the back of the box and i cant think of anything else.
Its blown. Maybe not completely but youve done some damage. If your sure its not hitting the box anywhere and its tight, then thats what it is. Youve burnt the voice coils a little. They regulate how far the sub goes in and out. I have two kicker L7 12s that have bad voice coils. And thats what they do. Theyre in my trunk though so its not to noticeable and they still hit super hard.
May 09, 2011 | Kenwood KFC-XW1200F Car Subwoofer
My red light on my 1000w amp wont turn on to power my subs. the blue one is the one one to turn on can anyone help me
make sure that you have a good ground, make sure you have the right amp turn on wire, and your power wire is fused, best solution is to have it professionally installed! Amp install is very basic if you are having a hard time with that, I wouldn't attempt to try it or have one of your buddies install it! FRIENDS DONT LET FRIENDS INSTALL!
Sep 11, 2010 | Kenwood KAC-7203 Car Amp
My kenwood kac-929 1000w amplifier is not powering my sub
unless you are a technician do not mess with the amplifier.
it takes years of school to learn electronics. unless it is a blown fuse or something simple,you will never fix it.
i did kenwood warranty for 8 years and the amplifiers are difficult to repair.
Aug 19, 2009 | Visonik V117SX Car Audio Amplifier
Help needed
Maybe, but my question would be will the truck alternator carry the load without frying. Also you will need one hell-a-chous size of battery and ground leads in order to feed that much power from the front of the truck to the amps in the trailer in back. I would think that some really big boost capacitors placed at the amps would be in order too. Also, you didn't mention how many amps you were using and what amperage they would draw. That is criticial information before you can figure out every thing else. Good luck.
Nov 21, 2008 | Kenwood 1000W Class D Bridgeable Mono...
No sound
good day, check your spkr impedance, if 4oms use a posive spkr dividing network. if stills blows up replace a higher amperage of your fuse. ex.4A raise it up to 5A. the your amps consume higier current if more spkr wattage.
May 29, 2008 | Kenwood KAC-5203 Car Audio Amplifier
On then off
THE AMP IS DRAWING TO MUCH POWER WHAT SIZE WIRE ARE U USING?
May 11, 2008 | Car Audio & Video
Kenwood KAC-6201 AMP
The Kenwood KAC would be 2 ohm stable.
I ran my sub's in parallel and the amp did not shut off and hit pretty well for long periods of time.
If you are running two dual voice coils.
Bridge amp, run pos and neg to pos and neg outside of box.
neg and pos to one side of sub
The other side of the sub run to the next sub
the other side of the sub to the inside of the box pos and neg.
pos and neg outside of box to the other outside terminals to create a complete loop.
If this isn't a good description post back and I'll email you a picture of it.
Apr 03, 2008 | Kenwood KAC 6201 Car Audio Amplifier
Car Audio (amp over heating)
The problem would be if you had it switched around. The 1200W subwoofer only means that it can handle 1200w of power the 1000w amp means that it can deliver 1000w of power. What you may have is an impedance mismatch. My question is what is the resistance rating on the sub woofer and what is the minimum resistance rating of the amplifier. These are actully the important issues at hand. the rating of the subwoofer resistance in Ohms should never be lower then the minimum resistance rating on the amplifier. in fact the resistance rating on the amp should match the resistance rating on the subwoofer.
Sep 09, 2007 | American Pro VS-2043 Car Audio Amplifier
Plz Help - unknow problem
Sounds like a short circut protection on the amp kicking in. It sences the power going to the drivers and cuts itself out before damage is inflicted on the subs.
Mar 18, 2007 | Kenwood KAC-7252 Car Audio Amplifier
Kenwood KAC-9152D Car Audio Amplifier Logo
118 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
