Question about Reebok 8050 ES Treadmill
Reebok rx3000 treadmill. panel lights up fine. 2 of the 10 speed buttons will not imput and the start button will not start the treadmill. checked the power panel. led lights to voltage light up fine, but the pwm and tach light do not. i think its the power board itself, but i could use better advice than my own.
    Habit-Forming:
  • 115 Answers
It is two items in this case. The light on the PWM will light if you force the belt to move. I would start with a lower board replacement. If it works fine then you need a new console. I have seen this when people use the heart touch bars on the treadmill and get a static shock. this can ruin the console.
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Posted on May 01, 2009
SOURCE: Need a Reebok treadmill repairman.
I can fix it for you. Just post it to me in London. Hope this was of help!
Posted on Mar 02, 2009
SOURCE: distance screen on treadmill
It's in Miles The treadmill goes a max of 14km an hour - if you increase the speed it only goes to 8 - 14km per hour is 8.4 miles per hour and I've been running between 5.5 and 6.5 and covering 3 miles which would be about right :) Hope this helps
Posted on May 27, 2009
  • 64 Answers
SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
Posted on Jun 08, 2009
SOURCE: How do I oil my Reebok i-run treadmill?
I have a problem with my reebok i walk i run treadmill. The belt does not move on the lower speeds and after using it there is a burning smell even though it is working fine once I get past the first two speeds. I have had it 2 years but have never oiled it as I am not sure how and where.
Posted on Sep 24, 2010
Reebok edge 2.2 stuck on full speed
Ouch, well I am assuming it doesn't start the walking belt until the Start button is pressed, then speeds up to Max? Uncontrolled speed, or what manufacturers dislike, Runaway, is a sign of a failed (shorted) FET on the motor control board. Reebok is an Icon Brand and you might find a replacement or repair thru jatinah electronics who services all styles of controllers and has some exchanges available for as little as 75 and a returned core. Good luck!
Feb 07, 2015 | Reebok Exercise & Fitness
RBTL67708 Reebok 6.80
LUBE the deck belt with silicone. and try again. However readjust the speed sensor see the diagram and tight the connector very well.
Jun 02, 2013 | Exercise & Fitness
Hello - when I turn on my reebok treadmill, the only buttons that work are start and incline (incline works most of the time). All of the other buttons do not work. Its a Reebok Vista RBTL13305 model...I...
Let me know if you find a solution. I am having the same problem and cant figure it out. It turns on and will start but none of the other buttons work. Its so frustrating.
Aug 14, 2011 | Reebok Vista Treadmill - RBTL13305
The treadmill will sometimes start and most times will not, even though there is still power. Then I will be on and the belt will stop turning. I can move the incline level but that is all.
With the motor cover off and the power on, make sure there is a red light/led lit on the controler, if yes then press the start button then press #3 on the speed side. If not lit, you dont have power to the controller. If you had a red light, and pressed the speed button, the light should start flashing just before the walk belt starts to move. If the speed button is pushed and the light on the controller does not flash, you have a problem in the console. This is only fixed by replaceing the controler.
Sorry.
Hope this was at least helpfull, Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Dec 30, 2010 | Reebok Acd1 Treadmill Motor Control Board ...
How do you shut this thing off . the lights on the display stay on. reebok 8700es
Hols the stop button and the speed decrease button down while inserting or attatching the key (magnet). There should be a "d" on the screen, press the incline down button and it should go away. As soon as it disappears, your done. Just pull the key off and your display will shut off.
Hope this helps
Nov 06, 2010 | Reebok 8700 ES Treadmill - Silver Service...
No motor output to drive the belt
If speed ctrl LED is flickering and no DC output on motor spade then the motor control board is defective and needs to be replaced
May 14, 2010 | Reebok Rt1000 Treadmill Walking Belt
Sounds like that there is a short in the control board.
Mar 23, 2010 | Reebok Rt1000 Treadmill Walking Belt
My console does not allow me to change the incline, speed, etc. The control panel does not acknowledge the buttons pushed. I've turned it off and on.
my treadmill is doing the same thing. the only buttons that work are the start; incline up. 4 incline; 8 incline; and 11 incline.
Sep 26, 2009 | Reebok 8700 ES Treadmill - Silver Service...
Reebok Vista Treadmill issue
Have a 2 year old Reebok treadmill. Control panel was replaced right after we bought it. Now, again, the upper half of the panel works but we are not allowed to start anything. Does the whole panel need to be replaced again or is there a fuse or something small that we can do.
Jun 07, 2009 | Reebok Vista Treadmill - RBTL13305
Reebok 8050 ES Treadmill Logo
655 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
