Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
A "loud" noise eminates from the motor only on the actual wash part of the cycle all other works ok, ie fill, drain, dry etc. Checked for any debris etc but did not see any, any help would be appreciated, thx.
  • Anonymous Dec 01, 2007
    I have the same proplem. Dishwasher works fine, but there is a loud vibrating noise when I first turn it on and again during the wash.
  • mardigras Dec 28, 2007
    We have a similar problem with our Frigidaire Gallery FDB636GFR1 dishwasher. There is a loud noise like a screech that begins during the wash cycle and continues to the end. It gets stuck at the end of the wash cycle and overheats. Needless to say the dishes are partially cleaned. How can we fix it?
    Genius:
  • 1,003 Answers
CHECK DRIVE MOTOR OR BELT OR TIMER
Posted on Jan 18, 2008
Pulsating
If you select the Normal Cycle, twice during the cycleyou will hear the wash motor going on and off at amuch different cadence. The pump will pulse severaltimes, repeatedly turning on for less than a secondand off for 10 seconds. This allows it to drive soils off the filter and into the drain while using very littlewater. If, after selecting the Normal Cycle, you select either the Sanitize or Hi-Temp Wash options your dishwasher will understand that a stronger wash is needed and it will not use this pulsing routine
Jul 25, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Won't drain completely at the end of a washing cycle
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Aug 07, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire fdb1050rem2 dishwasher will not drain during was cycle
Checked water temperature at water heater. It was at 110 degrees. Turned water heater up to 125 degrees. Dishwasher works perfectly now.
Mar 30, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire 4000 series dishwasher error code
This is likely an indication of a problem with the circulation pump motor under the dishwasher like maybe a bad circulation pump motor but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Feb 03, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Not cleaning and leaving soap residue
make sure that your unit is getting enough water. the hose may have gotten pinched some or your pump may be going bad.
Jan 22, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
NEW DISHWASHER REPEATS THE WASH CYCLE FOR OVER AN HOUR 7 HALF
Dear Customer
please perform the follownig checks
please rate this,thank u.
Dec 16, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Wash Cycle Not Working
Either the wash motor plug is loose or the motor itself is bad.
Dec 11, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Will not cycle past wash
Replace the timer.
Please Rate this !
May 29, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Door panels for frigidaire dishwashers
sure its possible,stainless steel door 154538305 approx $100
Dec 24, 2007 | Frigidaire 24 in. FDB1050REC Stainless...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
313 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Archie Ferrarini
Archie Ferrarini
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
