Question about Yamaha HTR-6130 Receiver
I have a cable box, a ps-3 and a westinghouse hdtv
Model sk-32H-240S. I am having a hard time connectiong all three, I really want to run the ps3 and the cable through thr hbmi, i also have an optical audio cable which I want to use with my surrond sound
  • 6 more comments
  • robert3984 Apr 19, 2009
    Ok tahat
    Ok thanks that worked for the video portion and i appreciate the help, i still have to run the audio through the tv. I can't get to work through the receiver. The tv is a westinghouse 32 inch hdtv model sk32h240s, the cable box is scientific alanta, the receiver is yamaha htr-6130. Thanks again for your help and swift response.
  • robert3984 Apr 21, 2009
    Ok once again thanks for all your help. Here is the setup
    Cable Box Scientic Atlanta
    HDMI to HDMI on Receiver
    Optical Audio To Optical Audio (3) CD on Receiver
    PS-3 HDMI to HDMI on Receiver
    Optical Audio To Optical Audio (2) on Receiver
    Receiver HDMI out to HDMI on Westinghouse TV
    The problem is that in I can get either audio or a picture running through the receiver. If I get both than when i change channels it seems to lose the input to the receiver. Should I be using a different setup with different cable (example either composite red and white or yRB) I do have connections for both and if so which is better and how do i do the hook up. Once again thanks both for your expertise and time
    i am so sorry i obviously hit the wrong button is there any way i can get you back?
    Ok i will try that will that still allow me to run the sound for all devices through my receiver?
    Ok so what is the right connection? I will try when I get home and wait for your answer. If possible tell me all connections for all components. Thanks for your help and fast response.
  • robert3984 Apr 22, 2009
    Ok thanks again. As for composites which are best YWR or YBG and will I still get the benefit of HD.
  • robert3984 Apr 27, 2009
    Ok I have tried or thought i have tried all the solutions. The problem is that I still can not get all the components to work. I have every conceivable cable, I have three HDMI cables. Now when I put the hdmi out from the cable box to the hdmi in on the receiver, then i connect from one of the hdmi outlets on the receiver to the hdmi on the tv. I often lose the signal when i change channels are try to use another feature such as watching movies that i have recorded on the dvr. The cable box has a built in dvr. I still have not been able to connect the ps3 and i am afraid that when i do i won't be able to watch the movies in 1080 or 720. I am getting very frustrated and think that I keep missing something. BTW the site needs to be checked because it keeps telling me that i am reposting when i do reply.
    Thanks Again
    Sergeant:
  • 254 Answers
YWR is always the best.and yes you will get the benifit of HD in YWR.that is confirmed.
you can get the required at
www.radioshack.com
thanks.
please do rate the solution.
thank you for using fixya.
Posted on Apr 22, 2009
  • ssolved Apr 27, 2009
    then the other option is to get all the other external components with another tv.if you dont have another tv get it checked at the tv repair shop .if all the other components work with other tv at the tv reparing shop that means your tv has some setting problem.but if same problem at the another tv that means some cable is missing or faulty.
    keep updated.
  • Yamaha Master
  • 19,396 Answers
Remove the optical audio connection and use HDMI only, HDMI already carries audio with digital quality that is the same as optical audio.
Always turn off all devices and possibly cut power when plugging and unplugging cable, HDMI connections are very sensitive.
Posted on Apr 21, 2009
  • Ginko
    Ginko Apr 21, 2009
    If you use only HDMI cables you will still control the sound from the receiver. The previous connection was wrong , that is not the way it is supposed to be.
  • Ginko
    Ginko Apr 21, 2009
    Here is the Yamaha backpanel
    Unplug all devices first.
    Connect the HDMI out from HTR-6130 to TV.
    The cable box may not have HDMI, if it is like one below has only RCA, component video, coax and DVI. In that case use Component video cable to connect to the Yamaha on the component video input at the left, the one saying dtv-sat. Component video are the red yellow gray.
    After connecting the cable box out, connect dvd and PS using HDMI to the HDMI plugs at the top odf receiver called DVDE and PS ot dtv-cbl
    If instead the box has hdmi, then the best choice would be connecting the PS to composite, since your Yamaha has only 2 HDMI inputs.
    Let me know if you need further help.
    Please , do not forget to leave us feedback afterward.
    Many thanks.
  • 10,594 Answers
Please connect HDMI in Receiver's HDMI OUT and hook it in TV's HDMI IN port.
Now connect Cable and PS3 HDMI cables in Receiver only. Turn ON all things and TV will recognize PS3 and Cable Box HDMI via Receiver.
Hit "add a comment" button for further query / info. Please intimate TV and receiver model numbers in reply.
Thanks.
Posted on Apr 18, 2009
  • Shahid Electronics
    Shahid Electronics Apr 19, 2009
    OK, you are watching TV with PS3 and Cable picture via receiver through HDMI. Great!
    Now you need to get sound from receiver. Let me know do you have 'Digital Out' ports in receiver, cable box and PS3?
    If yes, then hook Digital Optical Cable in PS3, cable box and insert it in correspondence input of receiver. you will get digital sound of PS3 and cable box from Yamaha receiver.
    Thanks.
    Shahid Electronics Apr 21, 2009
    Very good,
    You re-posted your problem so I have lost connection with you to assist you any more.
    I was said to use "hit a comment" button to reply but it was not used.
    Good luck.
Vertical color lines wont stop running while audio is good.
Westinghouse SK-32H240S Problems Anyone? - AVS Forum ' Home ...
www.avsforum.com/.../1143881-westinghouse-sk-32h240s-problems-an...
May 2, 2009 - 30 posts - ‎18 authors
I have owned my Westinghouse SK-32H240s for about 18 months now, and I ... Youwon't be certain if you are getting the right firmware or the complete firmware. .....makes it stop for a while, the same as it may with a weak antenna signal. .... would just go nuts and display a bunch of colored bars vertically.
Roku Forums • View topic - Westinghouse LTV-32W1 HDMI problems
forums.roku.com/viewtopic.php?f=28&t=27628
Apr 28, 2010 - 15 posts - ‎8 authors
I have a Roku HD box and a Westinghouse LTV-32W1 tv. ... Any idea on why it won'tconnect to the roku correctly? ... This does nothing to stop evil people from stealing movies, but does make ... but it is just a bunch of lines and colors all stretched every way. .... all running wireless on a actiontec C2000A.
Westinghouse LED TV LD-4655VX Fix - YouTube
? 24:48
https://www.youtube.com/watch?v=N_zPWgEitjE
Aug 7, 2013 - Uploaded by TipsNNTricks
Your Westinghouse TV Parts Here: http://amzn.to/14ETOTN ...LED LCD TV FIX, How To For Samsung Double Image, BlackVertical Lines, Screen ... Samsung TV Won't Turn On - How to Repair Bulging Capacitor for ... Problem with Westinghouse LTV-32W6 - Duration: 5:09. by toddalex4 20,284 views.
Dec 19, 2015 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Starts randemly flipping through tuner channels and won't stop
While it is stable, enter ''menu'' and check ''channels'' menu. Make sure (if you have no antenna) that it is set for ''Cable'' or ''Satellite''.
If problem continues, try unplugging for a _full_ 24 hours, and then do the above.
Ps... If you _do_ have an antenna, set it for ''antenna'' and then select ''scan for channels.'' Do not interrupt process. Allow it to finish on it's own.
May 18, 2015 | Westinghouse 32" Flat Screen Lcd Hdtv,...
Lost channel 3 to watch tv on uverse
you need cable box on when you search so the tv can find it
Feb 16, 2015 | Westinghouse SK-32H640G 32" LCD HDTV
Does sk-26h590d have HD connection
It might have a built-in HDTV tuner or it may require installation of an HD converter box. If you see decimal channels such as 3.1, 29.2, etc. you have an HDTV tuner. If you see channel numbers without decimals such as 3, 29, etc. you will need to install a converter box
Dec 27, 2012 | Westinghouse Electric SK-26H590D 26 in....
They did not include the cables in the box bought from overstock Westinghouse 26" LCD HDTV SK-26H730S where can I get them?
Cheapest place to buy cables would be from monoprice.com
If you would like I can give you a list of suggested cables to use for the best picture/sound. I'd just need to know what the make and model of any other equipment you are trying to hook up to the TV is. i.e.
Sony DVD Player: DVP-D2700
Denon Reciever: AVR-391
Jan 07, 2011 | Westinghouse Televison & Video
I pressed the menu button on my remote control went to channels went to antenna scan and lost all my channels how do I rectify this problem?
go back to the menu and do a channel scan for cable or if you have a cable box connected change to the input the cable box is connected to with the SOURCE or Input button
Dec 06, 2010 | Westinghouse SK-26H520S 26 in. LCD HDTV
Ps3 won't display on hdtv via dvi
Re-Set the PS-3, by pressing and holding down the power button (front panel) this hard re-sets the unit and yo can then reconfigure via the composite video cable it came with, back to HDMI / DVI
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
Yamaha HTR-6130 Receiver Logo
113 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
