Question about Motorola Mobility RAZR V3
Front Display and contacts
The front display on my phone (the screen on the outside) stopped working and only shows as a dark purple screen instead of showing the time and everything else. Also around the same time all my contact numbers and info disappeared except for the myfavs. This is driving me crazy because when I readd one of the phone number it disappears after I use it!
    Brigadier General:
  • 7,752 Answers
You should replaced the LCD to correct this issue
Posted on Apr 19, 2009
Sorry for disturbing...my sony ericcson k770i cannot display the image clearly...how to fix it...is it something with the IC LCD sir??...plz help me..:D
I assume your screen is blur or dark.
- Definitely there seems to be problem with your display. - Check display connector and Re-Hot surrounding components
Mar 07, 2011 | Sony Ericsson K770i Purple 3G Camera...
Laptop screen purple psychedelic visual and then screen blank
Sorry to hear that you are having problems with the computer display.
Per your description, I believe the display controller was damaged by the power surge. The laptop may need replacement of the display OR use it with an external display.
Nov 06, 2009 | Computers & Internet
Front display stays dark after boot sequence
you must forget to re install the magnetic piece which located in the lower left corner of the lcd frame cover try to check it
Jun 18, 2009 | Nokia E90 Cell Phone (Unlocked) - Black
Oem Radio installation
*** 91 park ave with delco bose =
black = ground
dark green = lights on input
grey = panel lights
pink = on input
yellow = power input
orange = battery power input
nca = shield ground
tan = left fr spkr +
orange/black = left & right spkr -neg
lite green = right fr spkr +
nca = shield ground
dark blue = right rear spkr +
dark green/yellow = right & left spkr - neg
brown = left rear spkr +
purple/white = display dim output
pink = vehicle speed input
**** 91 park ave without delco bose =
grey = left front - neg
tan = left front + pos
dark green = right front - neg
light green = right front + pos
black = ground
dark green = display dim signal
grey = panel lights
pink = power antanna
yellow = ign input
light blue = right rear - neg
dark blue = right rear + pos
yellow = left rear - neg
brown = left rear + pos .
there YA go
Dec 27, 2008 | 1991 Buick Park Avenue
BROKEN (front) LCD Display for LG Chocolate 3
Search for "chocolate 3 lcd" on Ebay. For ~$26 and a little technical work you can replace the outside & inside LCD module.
Dec 06, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Samsung u340's front screen is very dark
Probably need your brightness turned up. Go to menu, then settings, then display settings, then backlight, then brightness.
Apr 11, 2008 | Samsung SCH-u340 Cellular Phone
Razr display goes dark
yes i think that in the phone you go to option menu in menu settings in setting displays is the option there you have the option to either turn off the display or choose the interval like 1 minute or 2 minute.
Jan 11, 2008 | Motorola Mobility RAZR V3
Purple lcd display
Hello tonyj111, If your old pictures look fine on the display, then the problem is related to the ccd sensor itself. The purple color is displayed because of a problem in the signal transmision from the ccd sensor to the camera's main processor. This is done using 3 channels one for each primary color (RGB red green blue). If the connector to the sensor is broken, or got out of place (loose) because some mechanic shock or symilar, the data processing woun't come out right. It is purple because your camera's processor mess up blue and red signals therefore resulting same purple instead of blue or red colours. In order to fix this you will need to either send the camera to a service center to have those connections checked (if your camera is still in warranty you will want to do this) or ask me for further instructions if you wish to try to dissasemble the camera yourself. In either way the problem is fixable and in most probabilities a cheap fix will work. Good luck
Jun 01, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Display dies, although phone still functional
My razr V3 dropped from an astonishing 40cm to the floor, after that both screens stopped working. I opened the screen by removing the four tiny screws in each corner (t5 screwdriver which I didn't have but the smallest of my miniature screwdriver set just fitted), and popping it up carefully. There a two flatcables, one with a silvery color and a connector with a black piece of foam on it. I think it's the screen signal carrying cable. I removed it and put it back in place, pushing it firmly. After that the screens worked again. 10 minutes of work and a great deal of satisfaction. Further, the phone stinks. regards, El Rudo
Jan 15, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
110 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
