Question about Compaq Presario 1700 Notebook
Nic card could be causing inability to log onto dsl
I have a Compaq Presario 1700 and just got an internet modem..it's not working, at & t said it's probably the nic card...what is that? and how can I fix it? thanks
Integrated ethernet card on Compaq Model SR1650NX apparently failed. What is best inexpensive PCI Ethernet Card to use, if any?
you can buy just about any PCI NIC card from ebay or even walmart and they should work. make sure they are compatible with your OS. it will say on the box.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jun 11, 2012 | HP Compaq Presario SR1650NX...
Tip
Want driver compaq presario 2540ap for WindowsXP
I want driver compaq presario 2540ap for WindowsXP, Thak you for help.
on Oct 28, 2008 | Compaq Presario Modem/NIC Combo...
I have a compaq presario sr1850nx hooked uo to Comcast broadband modem Motorola SB5100. Everytime I start or reboot my computer my connection dies. I use the comcast tool to diagnose my connection and it...
no operating system stated, wow, 14 windows and zillion linux. and PS2 OS. even freedos.
I have no idea at all what you have there;.
is this wifi or
Ethernet cable lan connected. tell helper wired or wireless.
then be more accurate as to what is there.
card, what network card, name it, model, and number.
its a desktop and as all desktops vast things can be fitted here.
NIC card PCI, LAN
Wifi card PCI, WLAN
Nic USB dongle
Wifi USB dongle.
we cant see what you have there, a photo works or words.
my guess is wifi dead, as most post here, due to complexity of wifi.
if not say so please.
Sep 09, 2017 | HP Compaq Presario SR1850NX (ER925AA) PC...
Compaq Presario 5220 Desktop Windows 98 internet: Dial-up Can a DSL card be installed or would I need to go with a wireless USB? And would wireless USB work on Win98?
You can install a network card inside the computer. You will need a PCI or an ISA card. (I know PCI network cards are easy to find at most of the computer shops.) See this site for how to install a card: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07111&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=93139 . However you should open your computer and check the space between the devices in the slots in the computer. There is an AGP slot with a video graphics card, 1 PCI/ISA slot with a modem (default specs), one free ISA slot and one free PCI slot. However depending on the graphics card one of these slots may be blocked by the card. You'll either need to get a card that fits the available slot or remove the modem and use that slot.
Here are some PCI 10/100 network cards: http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=587&name=10-100%20Ethernet%20PCI/ISA . Most of these are compatible with Win98. I'm not sure if there are any gigabit NIC with Win98 drivers.
Wired and wireless USB NIC adapters exist. However, you will be limited to the USB speed. If you have USB 1.1, that will be really slow. Most likely your computer will require a reboot anytime the connection is lost.
I hope this helps.
(who recently removed an internal modem to put in a PCI gigabit card in a newer desktop than yours. The procedure was straightforward and improved network performance in the household immensely. The failing on-board NIC was tying up the router for everyone.)
May 12, 2011 | Compaq Presario 5220 (388098-003) PC...
Modem name is Data Fax Softmodem with SmartCP attached to COM3. It is on a router so I can get on Internet without dial-up. Lighting hit the router and I received a new one from AT&T but my modem...
Compaq Presario Modem/NIC Combo (212786001)
we have no idea at all what you are running there at all
NO PC stated
NO OS stated (xp,vista/w7/8/10, why?)
An AT%T what? what modem exactly so they did not set it up for you ? no way they would not do that after all its' their modem and you run it from them as a service.
does your unstated PC use Ethernet cable Cat5/6 to the At&T modem or router? that is the fast way to get internet
fastest, most easy, and just plugs in.
your post lacks all key facts,
sorry.
Feb 02, 2018 | Compaq Presario Modem/NIC Combo...
Cannot connect to the internet wireless or wired.Tools show that it is disabled and I tried everything to enable it but it will not change. The blue wifi indicator light is orange and has been since it...
If the problem is there both wired and wireless, the problem is then narrowed to your computer's modem/nic device. Speak with a Laptop repair tech about replacing this bit of hardware. When did you lose connection with Internet? Recently or long ago?
Nov 25, 2009 | Compaq Presario Modem/NIC Combo...
Compaq presario 1700 LCD issues
i have the exact same problem. try connecting the laptop to an external VGA screen. if it works, then the problem is most likely a loose cable (connector). It turns out that the connector (which connects the motherboard or gfx card to the LCD screen) on my laptop is torn and cut. see if u have the same problem. this link might help u check out ur problem:
http://www.laptopparts101.com/lcd-screen-video-cable/
Nov 21, 2008 | Compaq Presario 1700 Notebook
Can I add a NIC card to my compaq presario pc sr5250nx? I keep loosing my internet connection every five minutes and have to reboot the computer to reconnect
you should be able to
http://h10032.www1.hp.com/ctg/Manual/c00840496.pdf
if your system is still within warranty I would think twice about opening the case yourself to installing a new network card.. you will be voiding your warranty.. so think about it
another thing i would try before deciding on going for another network card is to check your onboard network adapter has updated drivers... or you may want to reinstall the drivers for that adapter.. either one of those may probably fix your issue assuming is not a hardware failing given that your system may not be that old.... make sure you check the windows update and look for any new hardware driver for your network adapter that may be avaliable through windows update.
before you install your new network pci card you may have/want to disable the one on board going into your bios for that. so to ensure there's no resource conflicts when installing the driver for your new card (it may not be a problem even if you don't but if you run into problems while installing the new card consider this suggestion)
Oct 02, 2008 | Compaq Computers & Internet
Compaq presario A75206OM
hi friend u need to contact 24 hour hp chat technision support
Jul 10, 2008 | Compaq Presario Notebook
Compaq Presario 1700 Notebook Logo
42 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
