Question about Echo 30.1CC Chainsaw With a 14 In.bar and Chain
Chainsaw won't start
I have an Echo chainsaw. Used it a couple days ago... worked fine. Now it won't start. Absolutely nothing is happens when I pull the starter cord. It isn't even "grabbing". It just pulls, free and easy, then retracts, with no results.
  • 62 Answers
Time to get out your trusty tool kit. Remove the side cover assembly and look at the recoil assembly. You should see a pair of fingers that when you pull the cord move toward the center. If the fingers are there and not broken, make sure they move when you pull the cord. clean them if dirty or have foreign objects (like sawdust) around them. If the fingers are broken, replace them. You should be able to purchase them from your local saw shop.
Posted on Apr 18, 2009
Echo chainsaw ran fine a few weeks ago. Today it won't turn over. The recoil is fine. The flywheel won't turn.
Pull the spark plug out of the saw and put a little cutting oil in the cylinder and try to turn it over.
Dec 08, 2016 | Echo Garden
Stihl 180c runs wide open all the time.it has a new carb on it, linkage is fine
Stihl MS 180C Wont Run ' Arboristsite.com
www.arboristsite.com > Forums > Equipment Forums > Chainsaw
Aug 14, 2011 - 10 posts - ‎7 authors
I have a Stihl MS 180C that i cannot get to run. I used it all last year and went to use it a few months ago and it didnt seem ... it is not under warranty and i have pulled and pulled with choke on and throttle wide open and still wont start. ... Depending on the carb, some times you can just go for broke and get a ... Stihl ms 180 running rich
Jun 5, 2015
Echo cs-370, they actually work
Oct 12, 2010
More results from www.arboristsite.com
Stihl Chainsaw Troubleshooting Guide · TEK Indoor · Disqus
https://disqus.com/home/discussion/tekindoor/stihl_chainsaw.../newest/
Stihl
Dec 15, 2015 | Stihl Garden
Echo Chainsaw keeps cutting off
does it start and run for a min or two then die try and remove the muffler and run it if ok open the muffler and clean the screen off
May 25, 2012 | Echo Garden
Chainsaw won't stay running
You must have dirt in one or more of the carb jets. Remove the carb and clean it with carb cleaner spray and compressed air (compressed air is a must).
May 10, 2012 | Echo 30.1CC Chainsaw With a 14 In.bar and...
I have a echo cs5000 chainsaw. What is the coil to flywheel gap.
It is close 0.125 (one hundred and twenty five thousandths.) I have used an open match book as a gap guide on flywheels for 40 years... all make all brands and it works like a champ!
0.12 to 0.16 is acceptable.
Thanks for choosing FixYa,
Kelly
Aug 15, 2011 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Echo cs-370 chainsaw wont start. running fine the day before. good spark. fuel wet at muffler. plug always wet.
Check air filter- is it clean?
Some plugs are without cilinder ok but if in place dont work. cahange the spark plug.
Mar 17, 2011 | Echo Garden
ECHO CS 3000 chainsaw-while idling, shuts off if held on an angle
The idle speed screw may be set too low--adjust so that the chain stops moving, but the engine keeps running. Drain the fuel tank and see if the filter falls to the lowest point of the tank whatever the position. If it doesn't, replace the fuel line hooked to the filter as it may have lost flexibility. Hope this helps!
Apr 11, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Chainsaw starts fine, but dies mid cut?
Immediately after saw quits, while everything is still hot. Sometimes ignition modules quit working when hot.
Ignition Coil Test
SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode.
Loosen fuel cap when it starts to die, If that fixes it it has a fuel vent problem.
If you did nothing to the carburetor adjustments, are using a fresh (3 months or less) fuel mix with the same oil/fuel ratio, and are operating at the same elevation there is a reason your saw is acting up.
It sounds as though there may be a fuel delivery problem. Check the fuel filter on the free end of a hose in fuel tank (manufacturer recommends an annual replacement). Check all fuel delivery lines especially at fittings and bends for cracks and holes. If those are good then the likely cause is internal parts of the carburetor. HTH
Lou
Oct 12, 2009 | Echo Garden
Echo 30.1CC Chainsaw With a 14 In.bar and Chain Logo
885 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
