Question about HP Compaq Presario V5015US Notebook
I have all the screws out of the back but still cannot get the keyboard to come off/out. Where did they hide whatever top secret release mechanisms???
I have all the screws out of the back on my compaq presario v5105us but cannot find what will release the keyboard for removal. any hints
Remove Battery--- Then Remove 4 Or 5 Screws In Battery Compartment----Open Laptop And On Top Of Keypad There Is A Cover Over The On/Off Switch That Must Be Removed. If You Press Down On The Top Row Of Keys You Will See Some Slots Where You Can Pry That Cover Up, Once Removed There Are 4 Screws On Top Of Keyboard To Remove. After Removal Lift Up Keypad Slightly To Unplug Strip From Computer And Remove Keypad
Posted on May 12, 2010
  • 4 Answers
To remove the keyboard you need to take the battery out and remove the 5 or so screws from there, and if I remember, the one just right of the battery slot next to the vent. Then open up the lid and carefully pop off the top button bezel and then you will find the 4 screws holding down the top edge of the keyboard.
Posted on May 29, 2009
  • Fety May 29, 2009
    looky what I found:
    http://h10032.www1.hp.com/ctg/Manual/c00...
    page 106. (section 5-22) Looks like it's only two screws under the battery.
    President:
  • 2,992 Answers
The top edge trim strip above the keyboard should come off once you've removed the screws holding it from underneath. It snaps in place and may be part of the hinge covers. Check for screws in the back edge too that may be holding the hinge covers. Once that trim is off you can lift up the back of the keyboard and unplug its cable at the front edge.
Posted on Apr 18, 2009
How d I replace the screen?
take battery off, take off keyboard, unscrew bottom cover (few screws under keyboard from top), unscrew whole screen (disconnect all cables), take screen cover off (screws may be hided) replace and put back together :))
Oct 07, 2014 | Gateway Computers & Internet
Keyboard Remove
Remove the 3 Phillips screws that secure the keyboard to the computer.
Turn the computer right-side up, and then open the display as far as possible.
Turn the computer upside down, and locate the keyboard release access on the bottom of the computer, inside the battery bay.
Insert a flexible tool into the opening, and then press inward to release the keyboard.
Turn the computer right-side up, and then lift up on the top and left edges (1) of the keyboard until the keyboard releases completely.
Component replacement procedures 416. Slide the keyboard back until its top edge rests on the display assembly .
Release the zero insertion force connector to which the keyboard cable is attached.
Disconnect the cable and then remove the keyboard.
Oct 17, 2013 | Computers & Internet
Remove toshiba keyboard
Remove the Power Cord, Remove the Battery. Look inside the battery compartment and see if any screws are there, if so remove them (the keys inside the battery compartment normally holds the strip that is above the keyboard). If you see a screw that has the icon of a keyboard beside it, then that screw holds the keyboard in place. Look along the bottom of the laptop for more screws that have the icon of a keyboard beside them and remove them. In fact you could just remove all screws from the bottom of the laptop just in case you have to remove the palmrest. Remove the screws from the covers that houses the memory and hard drive and check inside them for screws. Sometimes a keyboard screw might be inside them.
Turn the laptop over and remove the strip that is at the top of the keyboard by gently prying it off with a small flat head screw driver. Be careful because there might be a cable attached to it. If the strip above the keyboard is one big piece that requires the whole palmrest to be removed, then look along the sides and top of the keyboard for little catches that you can push to release the keyboard and it will come out without having to remove the palmrest.
if the you have to just remove the strip at the top of the keyboard, once it is removed there might be screws at the top of the keyboard that hide under the strip to remove. Once the screws are removed, gently try to lift the keyboard out. Small catches on the side might be holding it so you might have to work with pulling one side out first then the keyboard will come out. Be careful, there is a cable under the keyboard that plugs into the board. Remove the keyboard cable from the board then lift it all the way out.
May 15, 2012 | Toshiba Satellite M45-S331 Notebook
HOW TO REMOVE THE SONY VAIO VGN-N365E HARD DRIVE
This was a real pain because Sony doesn't and won't release a hardware maintenance manual. You have to take all the screws off that you see on the bottom with the little arrow next to them. Slide out the optical drive and remove the 3 screws hiding behind it. Remove the battery and take out the 3 screws behind it. Now look at the bottom of they keyboard below the row of keys with the space bar in it. There are 4 tabs that have to be pushed toward the touchpad to release the keyboard. It should swivel up now. Be careful as there is a ribbon cable behind it. Gently slide the dark brown bar away or to the right from the beige connector in the keyboard. That will release the ribbon cable. You can now see the last screw holding the top cover in place. Unscrew that screw and then you can remove the top cover. Gently pop up the edges of the top cover and work your way around. You will have to swivel the screen as far back as it goes to pop up the cover. You can just lift and move the top cover toward the screen now and reveal the hard drive. The touchpad has a smaller ribbon cable so you can choose to disconnect it if you want, but you don't have to. There are two long screws near the SATA connector that you have to remove. After taking them out, you can gently slide the drive out to the loft, caddie and all. I suggest labeling all the screws as you take them out or taping them in similar positions on a piece of paper so you can put them back in.
May 01, 2010 | Sony VAIO VGN-N365E/B Notebook
Have new keyboard for aspire 3500 how doI remove old keyboard
Usually, all you have to do is carefully pry off the plastic trim piece that is in front of the keyboard, and over the hinge covers.check the back of the hinge covers to make sure they dont have screws in them. Once the trip piece is off, there are 2 or 3 screws holding the top of the keyboard in place. Remove those screws, and carefully lift up on the keyboard.
You then need to release the ribbon cable for the keyboard by popping the darker colored plastic strip carefully up or back. Reverse the process to install.
Dec 10, 2009 | Acer 91.63X07.001 Keyboard
I want to know how to replace a keyboard on an Acer Aspire 5520-5912 laptop
Hi;
Swapping out the keyboard is pretty straight forward:
Remove the battery and unplug the AC Adapter.
Very carefully, pop loose the piece of plastic trim that is below the LCD screen, and on top of the keyboard. It covers the hinges as well. Sometimes there are additional screws on the back of the hinge covers.
Once you get that piece off of the laptop, then remove the screws that secure the top of the keyboard. The keyboard should be able to be lifted up and back, to expose the ribbon connector. You will have to lift the release strip from the ribbon connector to release the ribbon . It is a brown or black part of the connector, and it lifts up about a 1/16 "
Install by reversing the process
Nov 20, 2009 | Acer Computers & Internet
How do I remove keyboard?
Most dell keyboard are "released" from underneath, turn your laptop over and look for the screws with a K next to them. Sometimes there is also a samll removable panel at the top of the keyboard hiding 2 screws.
Sep 25, 2009 | Dell Latitude E6400 Laptop
How do I reomove the top of a Toshiba Satellite P25-S670 in order to check the display connection
Goto tools then select audio and video options first will be audio option hence click next on top select whatever web cam you have. If it is not shown there then you will have to remove the driver for you web cam restart your computer and re-install the drivers only after autodetection. and then follow the proceedure above. Your webcam will start working. Under any type of difficulties just comment back.
Aug 10, 2009 | Office Equipment & Supplies
Cannot remove rear panel of Zanussi FJR1454 W
At the bottom on eacvh side there is a small round plastic plug which is hiding the other screws.
Please post back if any further assistance needed.
Thankyou for using Fixya.
Jan 18, 2009 | Zanussi F1045W Front Load Washer
Samsung Q40
Having the same issue here but not finding a solution, I thought I'd post the answer after testing it out myself!
On the underside of the Q40 are seven screws which are marked with arrows (if you look in the centre of the underside one is marked with the letters KBD so you know what you're looking for).
Before you remove the keyboard, be aware that there is a ribbon connector underneath it, which can be removed, but is stiff and isn't very easy to get back in by hand. You don't need to remove it to upgrade the RAM as it should be long enough for you to be able to work around it, but just ensure that you are careful when you do remove the keyboard as ribbon connectors are easily damaged.
Remove all of these screws to release the keyboard. Open up the screen, and GENTLY lift the keyboard free working from the side closest to the touchpad. Once the bottom is free, slide it toward you and away from the screen to release the two metal tabs securing the keyboard at the screen side.
Now the keyboard is free, jiggle it around until you have access to the memory slot. Ping out the memory by releasing the two tabs either side, and pop in the new chip.
To reassemble, slide the keyboard securing tabs at the top back toward the monitor, lay the keyboard flat, close, turn over, and put the screws back in.
Hope that helps!
May 13, 2008 | Computers & Internet
HP Compaq Presario V5015US Notebook Logo
143 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
