Question about Mantis 2-Cycle Tiller
Pull cord stuck
I can't pull the cord. I removed the cover, I could pull the cord once it was release from it housing. The round black part (housing?) is what is stuck. I was unable to remove this part. The diagram in the manual wasn't much help. This happen after using the Mantis for only a few minutes. The tiller seemed very hot for being in use for such a shot time.
  • Anonymous Mar 17, 2014
    It is very hard to pull cord. will not make full revolution.
  • 398 Answers
It sounds like the recoil spring in the "housing" is jammed( or something is broken) youll have to take this apart without breaking it. you may have internal engine damage if it was unusually hot and the pullcord jammed. try using a richer oil mixture for fuel also if you fix the pullcord. hope this helps, keep me posted.
Posted on Apr 24, 2009
  • 20 Answers
Try seeing if the flywheel even turns, that could be a major problem.
Posted on Jun 04, 2009
Pull cord is tangled
Unusual, but it does happen. Probably should replace cord. Obtain new cord, can be found at almost any hardware store, then remove top engine cover (cowl), usually held on by 4 bolts,two in front and two in back.If your mower has a plastic cover on top of cowl, remove it first. Remove old cord by holding wheel (looks kind of like a pulley) so that it does not spin freely once old cord is cut. Cut cord anywhere outside of the housing as close to the housing as possible. Carefully release the wheel so that it can unwind. You will see where the old cord is tied to the wheel. use needle nose pliers and grab hold of the knot and pull old cord out. Now for the fun part. You need to "rewind" the spring by turning the wheel clockwise while looking at the inside of the housing. Once you have turned the wheel to a point where you might break the spring, back off one turn to be sure you have not over wound the spring. Usually, about 5 or 6 turns of the wheel clockwise is enough, use your own judgment. The tighter you can get the spring, the better the recoil will be when you let loose the cord when starting engine. You need to line up the hole in the wheel to the hole in the cowl as close as possible. Use a screwdriver or some other small sturdy object to "lock" wheel in place for next step. There is plenty of openings through the cowl in which you can lock the wheel to keep it stationary while attaching the new cord and to keep the holes lined up as close a possible. It can be difficult to "fish" the new cord from the outside of the housing and into the holes through which you need to pull the new cord through. I have found that if you take a flame to melt the end of the cord so that it will not unravel makes it easier and if you can bear the heat, while the cord is soft from the heat, twist cord in a spiral shape. This will make "fishing" much easier.Once accomplished, tie a knot as close to the end of the cord as possible and pull line back towards the outside with a little strength to "seat" the knot. Remove screwdriver and let the tension of the spring rewind the new cord into the housing. If the spring completely unwinds then pull on the cord from the outside so the wheel turns at a minimum of on turn so there is always tension on the new cord. Route the new cord through the eye on the mower handle then install pull knob. Pull excess line through pull knob, tie knot, then cut off excess cord. Should be ready to go.
Aug 25, 2012 | Mtd 22" Yard Machine Push Mower
How to thread pull cord on my Talon rotary mower
remove THE COVER THAT HOUSE THE PULL CORD pully. TURN THE WHEEL IN THE direction THAT IT GOES WHEN cord is pulled ( THIS TIGHTENS THE RETURN SPRING) hold this wheel tight..every turm it could spin back rapidly. turn wheel 6 complete turns. align the hole in the housing with the cord hole in the pully wheel. thread cord through both tie a double knot . slowly release now install cover. try it if too loose pull out to max , hold pully, remove knot , cord and turn 2 or 3 more turns, replace cord, double knots , slowly release. replace cover, crank it and cut that grass.
Dec 04, 2011 | Talon Rotary Lawn Mower
Replace starter cord
Undo the screws holding the housing of the starter cord & remove the whole thing.
Before continuing it may be wise to take a picture of the pulley & how its held on so you can put it together correctly.
Inside you should see a removable clip attached to a moving nylon peg thing, remove this, then a washer, then remove the round plastic pulley that holds the cord.
Remove the old cord.
Thread one end of the new cord (ensure it's the same thickness) from the outside of the pulley through the hole so it comes out in the middle as it was before.
Tie a knot in it, trim off any eccess cord & pull it back through, tucking the knot neatly into the place where the knot goes.
Wrap the cord 3 or 4 times round the pulley & thread the loose end through the hole in the housing.
Put the pulley back in the housing as it came off & replace the washer, peg & clip.
Pull the cord to make sure it springs back ok.
***Now pull the chord right out & slowly let the spring pull it back in. Now thread your pull handle on right up to the housing, put a knot in it a bit further than this point so the spring holds the handle tight to the housing and its not dangling loose.DONT CUT THE ECCESS OFF YET
Ensure youre happy with the length of cord when its pulled out
If its too short, undo the knot, leave the pulley in place, use a thin screwdriver to pull the cord into the housing to wrap it round the pulley one more time (theres normally a notch cut out of the pulley to get the cord round between the pulley & housing)
Now repeat from ***
Now screw the housing back in place.
It's easier to do than write!!!!
Sep 13, 2011 | Garden
How do I replace the pull start?
Remove the four screws securing the starter houseing, with the starter removed, pull the cord out, tuck the cord into the cut a way in the side of the pulley and allow the cord to wind in slowley to let the tention off the spring, make sure all the tention has gone, now remove the centre screw, take away the pulley centre and the round spring from behind, note the hole in the pulley and the centre hub for the spring location, now carefully remove the pulley, be aware there is a large spring behind, remove the knot in the end and remove the starter handle, fit the cord back into the new pulley, refit the pulley into the cover making sure to locate into the spring behind, thread the cord back through the cover and reconnect the handle, knot the cord, re fit the round spring back into the locating hole in the pulley, re fit the pulley hub making sure the spring fits into the hole in the hub, re fit the securing screw, now put the cord back into the cut a way in the side of the pulley, wind up the spring, allow it to pull the cord back into the starter, only wind it enough to pull the cord fully back into the cover, re fit the starter.
May 01, 2011 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
Pull cord stuck
First. Remove the spark plug and see if any oil runs out.
Second, If the cylinder isnt flooded with fuel or oil. Make sure your blade brake is releasing properly.
Third. Remove the pull starter cover and consider putting a very light spray of WD40 onto the spring housing from the underside and work it around.....the recoil spring may just be rusted solid and a little lube and maybe a tap or too with a rubber mallet might just break it free.
I have seen all three conditions turn an otherwise working mower into something that wouldnt budge.
Good luck and be careful. Dont pull out the recoil spring as it under tension and could spring out and bite you or at least make a mess.
Jul 15, 2010 | Poulan "Poulan" Push Mower
Pull cord stuck to motor housing
Ok You have to release the engine brake. BY pulling down the bail to the handle as if you were going to start the engine. Hope that helps.
Oct 21, 2009 | Garden
How to sort broken pull cord on petrol strimmer
Hi Baz, i will tell you a generic way of doing this as i don't know the model of your strimmer.
on the pull cord housing you will have 3 or 4 screws to secure the housing to the motor body, undo these. the housing will lift away from the main motor body, underneath this cover you will see a spring canister, there may be a screw or clip keeping this in place or some are just secured with the outcover. remove this canister you should see a coil spring in the middle and a groove around the outside where the cord goes. you should see a knot inside the cord grove where the cord is threaded through to secure, remove thisand remove old cord. Now the trickky bit! some times it helps to have a helping had, you will need to turn the coil spring so it tights up to its full tightness, then thread the new cord into the secureing hole where the old cord was located, then when you release the spring this will coil the cord round the cord groove. replace the pull handle on the end of the cord so there is no slack and replace on to motor in reverse order. Hope this helps.
Sep 04, 2009 | Ryobi ZRRY30550 Factory-Reconditioned 30cc...
I need to rewind the spring and starter pull cord. I need to understand how all the parts fit together
I had the same problem. I had to take it apart and rewind it manually. To do this:
Step 1:
There are 4-bolts to remove on the orange plastic section the screw into the motor housing (one of them is hidden inside the orange plastic housing, you'll see an opening for it). There are also 3 screws in the black plastic exhaust housing that screw into the orange plastic housing, find those and remove.
Step 2:
Carefully remove the engine from the plastic housing. I didn't disconnect the throttle cable or the electric wires (points) just kind of worked around them.
Step 3:
The mechanism is kind of crappy. There are two black pieces with a spring in the middle, and a metal disc on the bottom with a ribbon coil on the underside of it. The top plastic piece is what turns the flywheel when you pull the cord. The spring in between connects the two plastic piece. This is probably what popped out. There is a piece sticking up on one end, which inserts into the hole in the top black plastic piece. If you remove the little guardrail things you can probably remove just that piece. KEEP TENSIONS ON THE PULL CORD. Once you remove that top black piece, it should start to recoil.
Step 4:
If it did recoil, put the spring back in the top plastic piece, and then put the plastic/spring combo back into the the bottom plastic piece, there is a little groove for the bottom of the spring to slide into. Then put the little guardrail screws back on. Make sure the big metal wire thing hasn't slipped down into the shaft of the weed whacker. That needs to go back into the motor, as it is what gets spun and in turn spins the strings. As you start to put the motor back in, you may have to pull on the pull cord a few times to get the flywheel and plastic piece to line up. Once you hear the motor start to catch, then you should be able to wiggle it back into place and put back all of the screws. Then give it a shot. If it pulls out again, you may have to drill a new hole into the top black plastic piece for that spring to slide into (this is the crappy design part).
Step 5:
If the pull cord didn't retract, you need to remove the other two pieces (lower black plastic piece and metal disc with ribbon). The metal ribbon has a nub on the outside that hooks onto a plastic piece in the bottom of the orange plastic housing. You'll need to wind it around once or twice to "charge" the ribbon, then wind the string back on the black plastic piece. The black piece should slide into the center of the metal disc and catch the inside of the ribbon. Once you get these two together, again, make sure the metal ribbon piece is wound once past normal and then you have to slide both parts together down into the housing catching the metal ribbon loop over the orange plastic nub. It's tricky, it took me a few tries. Once you get that you can try and test the pull cord, you'll see it pull out and feel it retract due to that metal ribbon. Then go back and do step 4, where you put the upper black plastic piece with spring back into place and replace the little metal guardrails.
This whole thing took a few tries, and the pull cord still gets stuck out. It's a major pain to say the least, but after the 5th time fixing it, you'll be a real pro.
Aug 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Replacing pull cord on weedeater
there is another t20 screw in the neck of the drum. once removed you will expose the drive clutch. soak it good with WD40 then unscrew it from the shaft. if you have all the housing screws out, you should be able to simply remove the housing to expose the pull cord assembly, screwed to housing.
Aug 06, 2009 | Ryobi Garden
Pull-cord will not retract.
If you put a longer cord on it , then it will not retract as far and get stuck.
Jan 24, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Mantis 2-Cycle Tiller Logo
1,038 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
