Question about Microwave Ovens
Ceramic hook on broiler unit is broken
In cleaning my Kitchen Aid convection/microwave oven, I broke the ceramic hook that hols the broiler element in place. Can the ceramic hook be replaced.
MicrowaveSvc
  • 9098 Answers
SOURCE: Kitchen aid microwave oven not working.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I'd say you have a contaminated or failing keypad or possibly residue on the boar dor where the keypad connects to the board.
Is it possible that some spray cleaner got into the controls?
I always recommend that users instead spray cleaner on a soft cloth then wipe the control panel.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 26, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Microwave/Convection JVM 1090 oven won't reach temperature
You probably have a bad thermistor.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
(At that site, that part is misspelled as "thermister" for your model).
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components for testing will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Jan 03, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Glass Tray replacement needed
Those model numbers are not correct. That's likely why you're having trouble.
For model number JVM1790SK01, the part number is WB49X10114.
That's available here.
Posted on Mar 06, 2009
ghost4548
  • 776 Answers
SOURCE: GE COMBINATION MICROWAVE CONVECTION OVEN JVM1790BK CONVECTION OVEN DOES NOT GET HOT
change the tube/heating element
Posted on May 26, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: How do you replace the fuse in a microwave oven.
Be sure the oven is unplugged or the breaker is off.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Let us know if we can help further.
Posted on Jun 06, 2009
Kitchen aid kemms308sss04 plastic insert on turn table broke how do you replaace
That may be called the turntable coupler or turntable support or roller ring assembly.
You can find helpful exploded views and part numbers at the link below, by replacing XXX with the full model number found on the tag on your microwave (not on the service manual).
XXX&siteCd=WHRCOM&userType=Consumer">http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=XXX&siteCd=WHRCOM&userType=Consumer
My preferred place to order Whirlpool parts is from the Pro here.
Feb 16, 2014 | KitchenAid Microwave Convection Oven
Ge microwave ceramic element
The service manual is here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Dec 27, 2013 | GE Microwave Ovens
Kitchen aid microwave will not heat
first check the fuse if cutoff, replace it. if ok, then check for any broken wire. if all connections are intact, then test the heating element for continuity, if no continuity, then the element is bad and needs replacement. try these steps
Jun 11, 2013 | Microwave Ovens
Installation instructions for Kitchen Aid KEMC378KSSo3
Hello, John. Hereis a link you can use to find manuals and parts list for your unit: http://bit.ly/bOwwxbI hope this information is helpful.
Sincerely, Melanie.
Apr 09, 2012 | KitchenAid KBMC140HSS Convection/Microwave...
How do i remove the halogen light in my micowave
I have a similar Kitchen Aid model. The little light inside my unit also went out. I called Kitchen Aid and they scheduled a tech to come out to change it. He said the only way to get to it is to pull the unit out from the wall (it's a built in unit). $150.00 bucks later I had a light for about another year before it burned out too. Needless to say, the heck with it, I don't need the light that bad.
Nov 16, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
GE Profile PK916, Convc. elements stays on high
he is right in what he says the heating element is feed from the main control board
Oct 24, 2009 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
129 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
