Question about Dual Electronics CECT P168 Cellular Phone
Can't multimedia message from sci phone how do i set up for at&t
Multimedia message won't download
  • 3 more comments
  • lickemgood Apr 20, 2009
    cant download multimedia message with sci-phone how do i set it up for t-mobile
  • Anonymous Apr 21, 2009
    thanks that was perfest! I worked!
  • amaris_moon Apr 22, 2009
    for att/cingular
  • Anonymous May 06, 2009
    i have the same problem but when i go under data account services it doesnt list the t-mo mms that i just created
  • dunderground May 11, 2010
    I need to know which Cellular service you are using so I can post the correct set up instructions. Example ATT - TMOBILE? Thanks
  • 193 Answers
Must be peformed exactly.
MMS Messaging:
1.) From the main screen tap the SMS Text icon.
2.) Tap MMS on the Messages menu.
3.) Tap MMS settings on the MMS menu.
4.) Tap Server profile on the MMS settings menu.
5.) Tap either SIM1 or SIM2 on the MMS settings menu, whichever SIM you are setting up
at this time for MMS messaging.
6.) Scroll down the list until you come to Profile 8. You can use any profile if need be, but
profile 8 is usually the first not already filled.
7.) Tap on Profile 8. Tap Edit profile.
8.) Tap just below Rename profile, then tap on the Edit button at the bottom of the screen.
9.) Clear the current text, then tap in the following text between the quotes
“T-Mo MMS”
Tap the Options button at the bottom of the screen.
Tap the Done button.
10.) Tap the area below Homepage, then tap on the Edit button at the
11.) Clear the current text except for “HTTP://”, then tap in the
following text between the quotes after the HTTP://
“216.155.174.84/servlets/mms”
12.) Tap the area below Data account, then tap Select at the bottom of
the screen.
13.) Tap GPRS on the Data account menu.
14.) Scroll down the list until you come to T-Mo MMS, the data account
set up under the Data Account Services section. Tap on T-Mo MMS
to select it.
15.) Tap the area below Connection type, then tap Select at the bottom of
the screen.
16.) Tap on HTTP, then tap on OK at the bottom of the screen.
17.) Tap the area below Proxy address, use the numeric keyboard at the
bottom of the screen to tap in the following numbers,
“216155165050”. The result should look like 216.155.165.050 under
Proxy address.
18.) Tap the area below Proxy port, use the numeric
keyboard again to tap in the following numbers
“8080” to replace the current 0 value. Then tap OK.
19.) The areas under both User name & Password should
remain BLANK. If they are not blank, select each,
and Edit them by clearing all text.
20.) Next tap the Done button at the bottom of the screen.
21.) A Save? question box should pop up. Tap the Yes
22.) Tap the Activate profile button on the T-Mo MMS menu screen, and you should be
taken back to the Select profile screen where a big green check mark will be beside the
newly saved T-Mo MMS profile.
Posted on Apr 20, 2009
  • 1 more comment
  • dunderground Apr 22, 2009
    MMS
    Select Messages --> MMS --> Message Settings
    Select Server Profile
    Select the first entry
    Select Edit Profile
    Edit Rename Profile to whatever name you would like
    Edit Home Page to http://mmsc.cingular.com
    Edit Data Account to the same data account you created for WAP
    Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
    Edit the Username to WAP@CINGULARGPRS.COM (UPPERCASE)
    Edit the Password to CINGULAR1 (UPPERCASE)
    Select Done or Save
    Make sure to activate the profile and you are good.
  • dunderground Apr 23, 2009
    For full help topics I have a cd available fo 10 us dollars. Has 100 of mp3 ringtones wallpapers, and java games. Guarenteed help on every question ever asked on these phones. If interested contact prestorse@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope.
    prestorose@aol.com
I cant download pictures messages
Here are a couple of things you can try:
You need to see if your MultiMedia Messages (MMS) are set correctly.
1. Go to messages and click on Settings.
2. Scroll down to find Multimedia Message (MMS)
3. Set Auto Retrieve to OFF
If that doesn't work try this:
1. Go to Settings
2. Go to Mobile Network Settings
3. Click on Access Point Names (APN)
4. Tap on Menu - (lower left side of phone)
5. Click on Reset
Try both these things and that should fix your problem.
Good Luck
Apr 01, 2014 | Samsung Galaxy Cell Phones
Receiving multimedia messages
You may have multimedia messages turned off by your carrier, so they would block all in and put multimedia messages. You could try calling them and ask them to check your settings.
Jan 05, 2014 | Nokia 6070 Cellular Phone
I have a samsung a777. I cant receive or send text........it saids it successfully sends but My friends dont get my text and they said they try to send me a text and it sends but i dont receive it can you...
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://www.samsung.com/us/consumer/mobile/mobile-phones/at-t-phones/SGH-A777EGAATT/index.idx?pagetype=prd_detail&tab=support
Check out the section on Messaging page 65 in your manual:
Important!: When creating a message, adding an image, a sound file, or a video clip to a text message changes the message from a text
message to a multimedia message.
Important!: Adding an image, a sound file, or a video clip to a text message changes the message from a text message to a multimedia
message. This also changes the Options that appear in this menu.
Note: A multimedia message should only be sent to a phone which can
support the receipt and display of this message type.
Note: If you exit from this View screen, you will need to go to the Messaging ➔ Inbox screen, the Recent Calls screen, or you will need to dial your Voicemail contact to access your messages.
Note: Messages can also be accessed by navigating to your Inbox (Menu ➔ Messaging ➔ Inbox).
Messaging Settings page 72 in your manual:
You can set up various options for using messaging services.
1. When the Idle screen displays, press the Menu soft key,
then select Messaging ➔ Messaging Settings.
2. Select the type of message settings that you want to
change.
• Text Message
• Multimedia Message
• Voice Mail
• Push Message
• Broadcast Message (SIM card dependent)
3. Press the Select soft key or the key.
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
Oct 16, 2009 | Samsung SGH-a777 Cell Phone
How do I set an access point for my multimedia messages(NokiaN70)
access point setting doesnt cost u anything....neither receving a multimedia message...only if u sent a multimedia message costs u depending on operator tariff
u can set up an acces point by 2 ways
1.manually...if only u know ur access point..then u need to go in multimedia settings and enter access point
2. ask ur operator they will sent u the multimedia settings with access point..via text message n u can save that automatically
Sep 21, 2009 | Nokia N70 Cellular Phone
No sent box for text messaging
I have an I68 and have learned there is no sent box either. It works like this. When you send a text message you can go in settings and make it where it will give you a delivery report that the text was sent. Without that on is still easy. If the message does not send it will be posted in your "outbox". If there's nothing in your outbox then it was sent :P
Aug 17, 2009 | Dual Electronics CECT P168 Cellular Phone
I can't receive Multimedia Messages or Pics on my SGH-C166 Phone
Clarification: I'm a samsung user for almost 5 years now. I want to clarify if your mobile was properly set to MMS settings?
Clarification: Did you auto-download the settings from T-Mobile or not?
Feb 09, 2009 | Samsung SGH-C166 Cellular Phone
Gprs activation
i bought china mobile N 95. i m not able to activate gprs services can any one help with settings or advise thanks
Jan 16, 2008 | Nokia N95 Cellular Phone
Can't send or download any multimedia messages
check your service provider this is a pay service and they could be the problem not your phone
Jan 03, 2008 | Motorola Mobility RAZR V3
Nokia 6020- check multimedia settings problem
ok , i see that u must download a new software to this mobile
Aug 27, 2007 | Nokia Mirafone OP201 Phone
Dual Electronics CECT P168 Cellular Phone Logo
757 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
