Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
I'm trying to take apart a kitchenaid dishwasher door model KUDP01ILWH0 to replace the dispenser assembly. I removed all the torx screws holding the outer and inner door panels together, but they don't want to separate. Anyone know what the trick is here? Thanks
  • bonnstuff Apr 19, 2009
    It's a mastic assembly... front and back panels glued together at the styrofoam interface. You have to break this glue joint.
  • Anonymous Mar 20, 2014
    When opening door the upper part where the touch pad is located begins to separate
  • 718 Answers
You can get assembly diagrams of your system. Go to;
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=503880
Click on the diagrams in the left-hand side. You will see how the parts go together.
Posted on Apr 18, 2009
Stripped screws on dishwasher door
Take a couple of the screws to your local Ace Hardware store, or a Lowes, or a Home Depot, or a Menards, and explain your problem! They will fix you up with replacement screws that will grip.
May 11, 2017 | KitchenAid Dishwashers
The door on my machine won't shut?
Hello
You will need to adjust the dishwasher door latch to fix the door if it will not close. The door latch can come out of alignment from use. Adjusting the latch assembly is a straight forward process on most models of dishwashers. First, remove the securing fasteners for the inner door panel. It is a good idea not to remove the inner door panel completely, just enough that you can access the door latch assembly.
Turn the dishwasher circuit breaker off inside your home electrical panel. Open and close the door and watch where the strike plate makes contact with the door. The strike plate is usually on the front top center of the dishwasher. If the strike plate is out of alignment, it will hit the inside of the door.
Pull the dishwasher out of the counter enough that you can access the strike plate securing Torx screw. You may need to open your dishwasher door and remove the two screws that secure the dishwasher mounting bracket to the bottom of the counter with a Phillips-head screwdriver to pull the dishwasher away from the counter.
Loosen the Torx screw that secures the strike plate to the washer tub with a Torx driver. Adjust the strike plate so the plate will engage the door latch. Retighten the Torx screw and push the dishwasher back under the counter. Secure the brackets to the counter if your dishwasher uses retaining brackets.
Adjust Door Latch
Open the dishwasher door and remove the Torx screws securing the inner door panel to the outer door panel with a Torx driver. The retaining screws are usually around the side edge and top edge of the dishwasher door.
Lift the inner door panel enough that you can loosen the two securing bolts on the door latch with a wrench. You only need to loosen the bolts, not remove them.
Carefully raise the dishwasher door to align the door latch with the strike plate. Hold the door latch with your finger tips when you align the latch. Lower the door and tighten the door latch securing bolts.
Install the inner door panel retaining screws and tighten all screws with the Torx driver. Close the dishwasher door and turn on the circuit breaker.
Sep 12, 2011 | Indesit 18 in. D41 Slim-Line Free-standing...
My kitchenaid fills with water just fine and drains just fine; however when I run it it makes this horrible buzzing/grinding sound. Could it be the food grinder or the pump? How do I clear the grinder to...
You need to remove the lower spray arm, then the water volute that runs up the back needs to get disconnected by removing it from its rear clip (center of tub almost behind upper rack, next twist volute connector clockwise until you can pull the connector and upper supply volute tube apart. Remove connector from top of pump and then remove 5? torx screws to remove top of pump (filter plate) then look inside front section of pump sump area and locate two more torx screws to remove (on right) first sump inlet cover. The screw on the left is for the macerator (grinder assembly) cover. Pull straight up on the cover to expose the chopper assembly. Try not to disturb the chopper screen from it's location as it connects to the pump impellar shaft and is difficult to re-install. Clean any and all debris from the now open areas and re- assemble the pump.
Jun 12, 2010 | KitchenAid KUDR01TJ Dishwasher
Soap door not opening
u need a new dispenser assembly.....u kind find the part at searpartsdirect.com by entering ur model number which is inside on the tag, to replace it u must turn off power at breaker, open door and remove screws around door to seperate dooors and replace the part.. hope this helps
Jun 07, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Whirlpool dishwasher adp 962 - rinse aid/soap assembly
Hey- Tag should be visible with door open, left side. MOD.   Let's go over replacement instructions. Turn off power The door panel is held together by T20 torx screws. Remove screws, unplug the wires, and take off panel. Door is spring loaded, so place some weight on it to keep it down. Four 1/4" screws hold dispenser in place. Replace and re-assemble. Not too tough- just beware sharp edges! Let me know if this info helps- have more if needed- Thanks- Ed
Mar 17, 2010 | Dishwashers
I am trying to replace the soap dispenser on my Kitchen Aid dishwasher. I have removed the toe plate and 10 screws on the inside and cannot get the cover off. HELP!!
As I look at the pictoral, it seems there are twelve screws that hold the inner door to the outer door. Youmust remove these and then separate the door parts. Then you will see the screws that hold the dispenser in place from inside the door.
Apr 17, 2009 | KitchenAid 24 in. KUDP01DLBS Free-standing...
Kitchenaid dishwasher - door will not latch
The latch needs to be replaced. Kitchen Aid has made two updates to this latch. I.E. 2-revised latches. I just replacd the latch assembly and the dishwasher works fine now. Do a search for kitchen aid repair parts online and hav them shipped to your home. The repair takes five minutes. Un-screw all torx bit screws on door and the latch is under neath. One electrical dip switch held on by another screw and a two prong tab to undo the old latch. This seriously took me five minutes to repair and the parts were $40.00 online shipped.
Hope his helps.
Dec 16, 2008 | KitchenAid 24 in. KUDP02CR Built-in...
Kitchenaid dishwasher leaking from door
Check the screws on the pump cover under the lower spray arm (the spray arm is easy to remove, the screws are torx - maybe a torx 10 or 15, so a regular screwdriver wont work). They come loose on ours every 6-12 months and spray water at the door, causing it to leak all over our wood floor. I routinely tighten those screws now before they come loose enough to cause the problem.
Apr 29, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Removing the detergent dispenser
I have the same problem--mine is about 10 years old. To disassemble, looks like you will need to disassemble the complete door--screws around the inside edge of the door. At that price for a replacement dispenser, I will either try to fix or replace the blue arm, or replace the dishwasher. I don't believe its worth putting that kind of money in an old dishwasher.
Lew
Dec 10, 2007 | KitchenAid KUDS24SE Built-in Dishwasher
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
593 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
