Question about Dryers
Dryer keeps running
I have a maytag neptune dryer. It dries clothes OK, but does not shut off. The dial just keeps going around!!! Once the door is open, the dryer does stay shutoff. Thanks, Dale
  • 62 Answers
Your timer needs to be replaced. This is not a hard job, provided you can find the parts.
Go here and check for your parts: http://www.repairclinic.com/
Posted on Apr 18, 2009
Clothes are now taking much longer to dry. I have cleaned the dryer vent & vent hose. ( all the way to the roof as I did once before that rectified the problem then.) Wet lint is around the door and...
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Dec 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
It takes hours to dry the clothes. The dial moves
sounds like a bad timer. if it sticks every time replace they are expensive
Mar 25, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer takes a long time to dry clothes
your timer is the problem if its not moving
which can be expensive
60-80.00 dollars Dryers are cheap enough to buy a good used one
Jun 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Matag NeptuneDryer MD5500AWW - intermittent heat - not drying
this is joyce
It is as you guessed your sensor. it is usually located in door but some models are in back of machine on inside, go online download document papers go to maytag.com put in model# and then download your model # and it will show you where your sensor is located, it should be simple to replace. I had the same problem with my dryer.
I am glad you said you checked the dryer lines because if these get clogged up they will cause the dryer not to dry the clothes correctley. very smart....if you need me to help let me know.
thanks,
joyce
Feb 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag gas dryer runs, doesn't dry
Check in the hole where the screen goes for blockage. Many times debries falls in there when removing screen. It cant make it out of the vent so it builds up and clogs the vent.
Dec 01, 2008 | Maytag Neptune MCG8000AW Gas Dryer
Maytag Nepyune not drying completely
There is a cheap PDF repair manual on eBay for this model. It is item number 200258764242.
Premmy
Oct 14, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryer not drying clothes
your dryer is a 220 plug check the circuit breaker first
one 110 runs the heating element and the other 110 runs motor and dials
this is usually the cause of dryer malfunctions
heating elements are simple big mesh of curled metal wire like a toaster but more of it
it would take alot to knock out the heating element
check the dials too these could be sticking or worn dials you dont have to run dryer to check dials
Jun 02, 2008 | Maytag Neptune MDG5500AW Gas Dryer
My neptune dryer
the wire my be off the sensor , but when you say it worked after cleaning vent makes me think the vent needs more cleaning, the dryer is designed to run until the clothes are dry if that takes 4 days it will run 4 days, if the vent is not good it cant dry, remove the vent and run a load see what happens with out any vent on it
Apr 30, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
96 people viewed this question
Top Dryers Experts
