Question about Car Audio & Video
I put brand new Infinity Reference 6.5 two way speakers in my 2007 Chevy Silverado. They sound worse then the factory installed speakers. Could I have done something wrong?
    Problem Solver:
  • 13 Answers
You could have wired one of them out of phase (one of them is reveresed from the other one). This means you get a lot of the sound waves to cancell each other out and it produces poor reduced sound. or you could have got some bad infinity's but most likey one of them is just out of phase or it could be that if you are running them off of a stock head unit they are not getting enough power but still not very likely to produce worse sound than the factory
Posted on Apr 23, 2009
Dodge infinity
The Infinity system includes a CD/cassette receiver or a CD receiver in the dash, and a complement of 7 speakers: 3-1/2" speakers in the dash (left, right), a 2-1/2" center dash speaker, two 6"x9" woofers in the front doors, and two 5-1/4" speakers in the rear doors. You'll have to remove a section of the dash to install a new stereo, as you do with the non-Infinity system. You'll need a special adapter to connect a new car stereo to the Infinity factory amp http://www.crutchfield.com/p_120CHTO02/Axxess-CHTO-02-Factory-Integration-Adapter.html?tp=3486
Dec 25, 2013 | Cars & Trucks
Just removed stock front speakers from 2000 Jeep Grand Cherokee with premium sound. Speakers were working, but my son wanted new ones. Installed Infinity 9632cf speakers and we're barely getting any...
A lot of companies are using 2 ohm speakers for stock speakers. This means they are more efficient (sounds strange that a stock speaker is efficient). The stock amp may not be able to put enough power out for these to sound good. You may end up needing a new system.
Sep 01, 2011 | Infinity 9632CF 6" x 9" Coaxial Car...
I'm installing an aftermarket audio system in a chevy silverado using 2 amps. how would i get sound to the factory speakers from an aftermarket amp?
The best way would be to run the wires from each amp straight to each speaker. Just be careful with the amps. Most amps for full range mode are set for 4 ohm speakers. In a silverado they will probably be a lot less which could cause a short in the amp. Good Luck.
Aug 17, 2010 | Car Audio & Video
What kind of wire do I need to install Infinity reference series 605cs with a JL Audio 10" sub and a Alpine Flex 2 amp? Can I use my factory head unit?
You can use the factory speaker wiring for the Infinity speakers you should purchase a amp kit which will give you everything to install the amp. See site below
http://www.sonicelectronix.com/item_18428_Raptor+ISPKBL4-BG+by+Metra.html
Well that all depends on the current audio system you have now is it just a basic or a premium factory system with a factory amp. Honestly you would get a better and cleaner sound if you change the factory head unit to a after market one which has preamp feeds and the higher the preout volt the better. Just make sure it is compatible with the amp volts input (Example 4v to 250mv) If you use the factory headunit you would have to by a high to preout adapter it connects to the exsiting radios speaker leads, but like I said before change the head unit you won't be sorry. Do not forget if you change the radio you need a radio install kit and the wiring harrness which converts the two radio plugs so you don't cut them so down the road you can remove the after market radio and just replug the factory right back in.
Apr 16, 2010 | Infinity Reference REF 605CS Car Component...
What size are the door speakers in a 2007 Chevy Silverado 4 door?
  • Front: 6-3/4"
  • Rear: 4" x 6"
  • Front door: 6-3/4"
  • Rear side panel: 4" x 6"
Oct 16, 2009 | Metra Chevy Truck 88 94
2005 chevy silverado stereo wiring diagram
Are you trying to install a new stereo? If so will need to re-wire all your speakers because of the bose system.
And if im not mistaken your year truck might need a really expensive harness to install the radio. Here is a link to it.
http://www.crutchfield.com/p_120GMOS04/GM-Factory-Integration-Adapter.html?tp=3486
You should look into this too! http://www.crutchfield.com/p_120GMOS04/GM-Factory-Integration-Adapter.html?
May 22, 2009 | Car Audio & Video
Infinity ERS640 speakers impedance
Your speakers are acutally rated at 4 ohms. Your connection will be just fine. No need to worry.
Here is the manual for your reference.
Jan 19, 2009 | Infinity Audio Players & Recorders
Alpine mrp-f300 cuts sound off when volume is turned up.
the problem when someone become a car audio fanatic is, we want to hear BOOMS but we are not sure how many watts the amplifier can handle, besides that theres one very important thing that most of the installers don't know. its called ohms law (not a joke) that law tells you everything about how to measure the ohms marked on the speaker labels and also the way that you connect the speakers (theres two models; serial circuit and parallel circuit)
every single movement that you make on the connections tells a different story, and if you over load the amp it will auto protect.
i suggest you to set the level at least at 60% so you don't make any damage to the internal components, and don't forget to study ohm's law because a really professional installer knows it and well, they do the matt to get the best performance.
Dec 11, 2008 | Alpine MRP-F300 Car Audio Amplifier
Stereo wiring diagram needed
well if it doesnt work pull it out rewire and put it back in. its gonna be a very easy problem that lies right infront of you. just gotta find it.
worse case senario thro those factory speakers away and put in new component speakers.
Aug 04, 2008 | 2000 Chevrolet Silverado 1500
Car Audio & Video Logo
53 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
