Question about Microwave Ovens
Whirlpool otr microwave
I bought a used whirlpool microwave, When you turn it on, it makes a rubbing or thumping noise in the microwave fan... also the turntable will not turn ( we have hit the button to turn the turntable on and off). The whole thing is rather greasy. They must have really fried alot and it is over the oven model. It sounds like the fan (this is not the vent a hood fan) is rubbing the shroud around it, but i guess it could be a bad motor. The turntable just does not move. I can turn it with my hand, but i noticed once when i hit the turntable on/off while it was heating that the light and fan pulled down a little.. Thanks
Once i opened up the microwave, I found that some kind of capacitor or something (had two wires going to it) had fell down on top of the fan. I had to rig the plastic mounting bracket and re-attach it to a panel inside. That took care of the rubbing noise. It turned out that some one had unplugged the wire that powered the turntable. That took care of that. it seems to work fine now. Steve
Posted on Apr 19, 2009
Brand new otr microwave won't heat and carousel won't turn. Control panel does work and its not in demo mode. No buzzing or noise coming from it other than the recirc fan out the top. Advice?
cabinet out of alignment , if this is over the range adjust the way you have hung it, the pawls on the door are not contacting the switch in the unit
Nov 20, 2015 | In Microwave Ovens
Can it be used without the fan?
If you want to get anymore useful life out of it, stop operating it without the fan.
Aug 18, 2015 | Whirlpool Microwave Ovens
Whirlpool microwave fan not working
I would unplug the oven for 2 minutes to do a hard reset and try it again, just in cause there was a glitch.
Without knowing your full model number from the tag on the oven, I would wonder if it has a separate internal cooling fan from the hood vent exhaust fan. It could be an unrelated issue.
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 11, 2017 | Microwave Ovens
New Whirlpool MH1160XSQ0 OTR Microwave, never used. (been in storage for 4 years). Lights, fan touchpad seems to be working normally. Gives 3 beeps when start button is pressed and then nothing happen
They have no battery that I'am aware of, the problem is in the keypad control board. The long storage tends to cause issues if the parts have not been energized for a long time, capacitors start to deform overtime and they are the most likely to fail.
Jun 13, 2012 | Whirlpool Microwave Ovens
My food no longer rotates while cooking,and it makes a clicking noise.
this is usually a bad turn table motor. if you remove the screws out of the bottom of the otr(over the range) it will hinge down and back and you will see the motor in the middle of the otr. your local parts house should have this item in stock or be able to order it for you
Apr 24, 2010 | GE Advantium 120 Convection/Microwave Oven
Microwave making dull thumping noise when NOT in use
I called a technician out today. Seems like the problem is the circuit board. It wasn't working properly and the sound is the fan. The fan is supposed to turn on when the microwave is in use and off when it is not. In this case, the fan continued even when the microwave was not in operation. A new circuit board has been ordered and will replace the old one when it arrives. For now, I can still use the microwave, but I have to unplug it everytime I finish heating something up. A little inconvenient, but at least it'll still heat my food up in the meantime.
Jun 24, 2009 | GE JVM2070 Microwave Oven
OTR Amana microwave- No power, lights, clock or sounds.
Either your magnetron, cooling fan, or the magnetron thermostat is failing.
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Amana / Whirlpool customer service is here.
Please contact them to find your nearest authorized service center.
Jun 06, 2009 | Amana Radarange Microwave Oven
Whirlpool OTR microwave no oven 'fan'
FIRST ,,MICROWAVE OVENS ARE REALLY SAFTY MINDED AND THATS A GOOD THING....THERE ARE USUALLY THREE DOOR SWITHCES NEXT THE KEYBOARD--THE ONE ON TOP AND THE ONE ON BOTTOM ARE PRIMARY AND SECONDARY SWITCHES,,YOUR PROBLEM SOUNDS LIKE ONE OF THESE IS NOT MAKING CONNECTION..YOU MIGHT BE ABLE TO PRESS 'DOWN" WITH A LITTLE PRESSURE ON THE DOOR AFTER CLOSING TO SEE IF THE FAN WILL START,,,IF YOU NOTICE --THERE ARE 2 LATCHES(HOOKS) COMING OUT OF THE DOOR,,WHEN THE DOOR IS CLOSED,THOSE LATCHES ARE SPRING LOADED AND MAKE CONTACT ON THOSE SAFTY SWITCHES....THIS IS NOT A CUSTOMER REPAIR--MICRO'S ARE JUST TO DANGEROUS WHEN YOU TAKE THE COVER OFF--IF THIS DOES BRING THE FAN BACK ON--YOU GOT A BAD DOOR SWITCH AND SHOULD BE A REASONABLE REPAIR
THE OTHER SOLUTION STILL WOULD BE A CONNECTION PROBLEM ON THE KEYBOARD ITSELF-THE WIRES JUST PLUG ON THE CIRCUIT BOARD BEHIND THE KEYBOARD---STILL A EASY REPAIR--GOOD LUCK TUNICA
Oct 30, 2008 | Microwave Ovens
Microwave Ovens Logo
197 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
