Question about Hotpoint Aquarius WF000 Front Load Washer
Keeps going to f-03
My hotpoint washing machine keeps going into f-03. was told once before to turn it off and then back on
  • 744 Answers
  • F03 - Wash thermistor open/short circuit
If this error persists it's usually best to call fro service unless you are familiar with this kind of work.
Posted on Apr 18, 2009
Water retention within machine
there should be a small plate to the front or back at the base that you open and you will be surprised what will come out. you might need to remove the lint trap and it will be gunged up with soap, fabric conditioner, grease it will need washing and in future probably once twice a year use a washing machine cleaner that you use as if you have a load and turn machine on. hope this will help i am not a technician just a housewife who have had this problem and was told to do this and it worked.
Mar 19, 2011 | Hotpoint Washing Machines
Hotpoint washing machine, model WF630, Error F-03???
Error code F03 is indicating a problem with the wash thermistor, it could be open or short circuit.
Check connections on thermistor and heater element.
Hope this helps.
Dec 15, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
May 30, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
Child lock
Try turning the dial back to off, and then try it again.
Make sure the door is shut properly.
Don't interrupt a prog once it has started., if you do , it will start to do funny things.
Nov 20, 2008 | Hotpoint VBSR3100D Top Load Washer
HOTPOINT KEEPS FLASING F-03
The error code F03 indicates that the wash thermistor is open or short circuit.
Check heater element and thermistor,if ok, then you need to call an engineer.
Sep 22, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD860 problem
washer wf860 showing f07 error. why
Mar 04, 2008 | Hotpoint Washing Machines
Hotpoit belt
hook the belt around the motor spindle first then get the belt as far round the pully as you can once at that stage hold the belt firmly as you can on the pully and turn the pully round making sure that the belt does not slip off keep turning the puully round till the belt is fully on once on spin the drum around by hand to make sure that it is on the pully square with motor spindle. job done. if this helped please leave feed back.
Feb 20, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint ultima tumble dryer error code f-03
i have a hotpoint ultima ctd80 which i have had the last 2 years, it has shown error codes f11, f10 and f15, every time i fix this problem by first switching off and unplugging appliance then removing small cover from back (middle with 2 screws) then larger panel that the smaller panel overlapped. once you remove these you will see the heating elements, remove the 2 screws at the back off this, remove cover carefully then at the top you will see two things (not very technical lol i am a woman), with a pin press the pin in the one with a hole, mine makes a clicking sound when i do it, not sure if it meant to but works for me. put all parts back together and thats the job done. make sure both fillters and water emptied regular, hope this helps and saves you a fortune on call outs
Jan 26, 2008 | Hotpoint Ultima WF860 Front Load Washer
Displays F-03
NTC fault its electronic and needs engineer
But try this for most electronical faults first switch off mains wait 20secs and switch back on this resets most gadgets and gizmos if it doesn't work it was a free try.
Nov 07, 2007 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint Ultima WF860 stops every time with 1 second to go
This problem is caused by the heating element not working.The machine won`t spin & finish because the machine knows it hasn`t heated the water during the wash programe but clock will still count down.this is what we were told by a hotpoint engineer.the callout charge is £89.98 from hotpoint this includes parts & labour. 27/7/07
Nov 05, 2006 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
255 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
