Question about Garden
New Starter draggs when cranking 16.5 HP Briggs & Straton engine
Replaced the starter and the battery. The engine still drags when cranking like it is out of time. Replaced key in fly wheel and checked all connections from battery.
  • Anonymous Apr 26, 2009
    I have the same problem; replaced the battery, had the starter check, then called briggs they said the compression release needs to be replaced and its located behind the cam shaft. I never heard of a compression release on a mower but if thats true, it's the stupidest idea they have come up with yet.
  • Keith Parker May 11, 2010
    Has it ran at all..this year???
Have a lawn tractor with a 15.5 hp briggs and stratton engine, truns over very slowly flooding the carburetor and filling the cylinder with gas. have changed the battery and checked connections at the...
you could try a higher cranking battery but cost alot it could be your starter is dragging to might need new starter to you would have measure the voltage at the starter if its a old lawnmower my geuss would be starter espessally if yove have to hook a car battery to it
Sep 07, 2013 | Garden
Briggs and stratton model 29000 starter problems
Try turning your engine by hand counter clockwise to see if it isn't under cylinder pressure..if it turns try to start...if still nothing and your battery is good you most likely have a bad solenoid..it connects the power from the battery to the starter..follow your heavy wire usually red from the positive side of your battery and from the starter..you will find it at their ends connected to two large post..it has small wires attached...that is the solenoid.. a quick way to see if it is bad is to put the switch on the run position then take a screw driver and cross it on both post,, making a direct connection bypassing the coil,,,It should crank and start your engine..if it does you need a new coil...easy job depending where yours is located..normally just below the ignition switch..under the hood or dash board..good luck..
Mar 17, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
I have a B/S 22 HP engine and when I try and start it I hear the selonoid pulling in but the engine will not turn. I can do this several time and finally it will start and runs very well. It took the
Is the noise you hear actually the solenoid popping or the starter gear jumping into the flywheel?? You say it finally starts so I am guessing the starter is engaging and actually bumping the flywheel a little. If that is the case it is probably a dragging starter or weak battery. First thing is to be sure the battery is fully charged then see if it will turn over easily. If not you may have a started problem.
Mar 31, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I have a sears craftsman tractor,18 hp electric start. No. 917.254860. engine no. 422707,type no. 1522.01. briggs and stratton. engine won,t turn over. Replaced plugs,coil,carborator rebuilt to specs. New...
From your description it seems that the starter is not engaging to turn over the engine. First ensure all the connections of the thicker cables to the battery, starter and tractor frame are clean and tight. If starter motor is turning but still not engaging it will mean that the pinion on the starter motor is binding on the shaft. You can buy a new starter pinion gear from your local B & S agent.
To replace pinion, remove starter motor from engine, remove old pinion and put on new one and reattach starter to engine. If fuel & spark are right you should be up amd running.
Sep 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Starter motor can't turn engine through compression stroke
valves are out of adjustment. reset them and it will do fine.
Apr 07, 2017 | Yard Machines Garden
Why wont the car turn over like it is suposed to? it kinda draggs like a dead battery but i put a new one in and replaced the starter also could it have jumped timming ??
Only if you tried drag racing the car - not that you'd win with a Taurus. Dragging as you describe is usually caused by a defective battery or starter, but you've replace those. I'd now look at the condition of the primary wiring (thick red wires) from the battery to the starter and the starter relay. Also check the ground connections to the block and the chassis (thick black wires). Corroded connections can drop a lot of voltage at high current. Take'em apart, clean and polish them, squirt some wd40 (prevents corrosion) on them and put them back together. Hope this helps, if not, then maybe someone else on Fixya can help.
Feb 20, 2010 | 2001 Ford Taurus
Garden Logo
541 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
