Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I need to see a wiring scematic, that shows the wiring connections for the drive belt clutch
    Problem Solver:
  • 5 Answers
If you have the owners manual it should be in the back. If you don't have it, go to the Sears website and download it for free.
Posted on Apr 25, 2009
Drive belt configurataion
There shoud be a belt scematic under the foot well plate.
Sep 23, 2013 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
Front window switch came apart
that really sucks the clips that hold the pins on the wires are probably brocken if thats the case you can get a pig tai or even a new conector from the diealer or junk yard youl need the wireing scematics to replace the pins in the proper order most chevys have similar conectors with diferent wireing colors if you get it at the junk yard you can get the scematics for that rig and match them with yours hop this helped
Jul 22, 2012 | 1995 Chevrolet G20
Husqvarn lgt2654 wont pull
Make sure the drive belt is routed right. Go to partstree.com click on
husqvarna and put in your model number and click on the drive scematic and it will show the routing of the belt.
Jun 23, 2012 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Replacing alternator on 2001 sebring..cant locate belt tensioner
The tensioner will be one pulleys that can be rotated on its armature to remove tension to the belt.
Removal & Installation 2.4L Engine To Remove:
  1. Disconnect the negative battery cable from remote negative terminal on shock tower.
  2. Remove the drive belt cover.
  3. Disconnect the wiring from the generator.
  4. Raise and safely support the vehicle.
  5. Remove the accessory drive belt splash shield and then remove the belt.
  6. Lower the vehicle.
  7. Remove the MAP sensor from the intake manifold.
  8. Remove the generator mounting bolts and the generator from the engine.
To Install:
  1. Install the generator and tighten the bolts to 20 ft-lbs (28 Nm).
  2. Install MAP sensor.
  3. Raise and safely support the vehicle.
  4. Install the accessory drive belt and splash shield.
  5. Lower the vehicle.
  6. Connect the wiring to the generator.
  7. Install the belt cover.
  8. Connect the negative battery cable.
2.7L Engine To Remove:
  1. Disconnect the negative battery cable from the remote terminal.
  2. Raise and safely support the vehicle.
  3. Remove the accessory drive belt splash shield.
  4. Loosen the accessory drive belt.
  5. Remove the generator lower mounting bolt.
  7. Disconnect the wiring from the generator.
  8. Disconnect the electrical connector from the A/C pressure switch and clutch coil.
  9. Remove the engine oil dipstick.
  10. Remove the generator upper mounting bolts.
  11. Remove the generator.
To Install:
  1. Install the generator on the engine. Loosely install the upper bolts.
  2. Install the engine dipstick tube.
  3. Connect the A/C pressure switch and clutch coil electrical connectors.
  4. Connect the wiring to the generator.
  5. Raise and safely support the vehicle.
  6. Install the lower generator mounting bolt and tighten to 20 ft-lbs (28 Nm).
  7. Install the accessory drive belt and splash shield.
  8. Lower the vehicle.
  9. Tighten the upper mounting bolts to 20 ft-lbs (28 Nm).
  10. Connect the negative battery cable.
Feb 03, 2011 | Chrysler Sebring Cars & Trucks
Received a * used* Swisher ZT 2660 26hp in October of 2010 has 50 hours on the meter. First 2 or 3 cuts all went fine last cut of the year when the mower would contact grass / leaves the blades would...
Is the belt slipping? If it's slipping you'll notice it, because it'll smoke pretty soon. If, as you watch it under varying load, it slows down with the blades then the belt is fine.
If it's not the belt then it's going to be the electric clutch that drives the belt. Get your voltmeter out and tap into the wires that go to the clutch, watch it as the mower runs. Anything under about 13V and the clutch may slip. If the voltage is good then the clutch is worn out. They don't cost too much, I'm pretty sure they're well under $100 still.
Make sure the wires that plug into the clutch are making a good connection. You want to check the voltage between the switch and clutch so that you're also checking the switch- if it's got a little crud in it, or a bad connection farther up the line, it can cause the clutch to slip, and you'll see this as the voltage dropping.
lp
Jan 10, 2011 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Hi, I have a LXW18JEZRW-1 model regridgerator and the relay got burned. I called the technician and told me that the relay and the protector needs to be replaced. He took the damaged parts off and left. He...
there should be a scematic located on compressor terminal cover. one wire will be for common designated c the other two are for start winding s and run winding r . Do not cross up wires to start winding and run winding as this will burn out compressor. follow scematic and all should be well.
Dec 25, 2010 | Refrigerators
I need to download the scematics to replacing broken timming belt on a 1991 lancer eci multi 12 valve
1.5L
1.8L also showing balance/silent shaft timing marks. Note the slack(lower) part of the balance shaft belt.
Nov 23, 2010 | Mitsubishi Lancer Cars & Trucks
Have a Greenfield Evolution 2000 mower , the forward drive clutch is slipping badly on hills is ok on the flat, what is required to fix this problem. Can the clutch pads be replaced or are complete clutch...
The Greenfield clutch (drive belt) is adjusted by spring pressure pulling a long rod that has serations on it. Either the belt has run out of adjustment (= new belt needed) or the adjuster has stuck. Lift up the seat and push the adjusting rod that has a big spring attached to see if you can move it towards the front. Look at the pulley beside the rod, if the belt has stretched too far, the pulley will be hard up against its slot. The pulley moves towards the front to tighten the belt. I just push with my leg to get another "click" out of the adjusting rod. New belts are cheap too.
Oct 31, 2010 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
138 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
