Question about Cycling
I can not fix the stem i took it off to change position but it keeps moving and I can't keep it still after putting it on again.
  • Ed
    Ed May 11, 2010
    Did you take the stem bolt completely out?
    Is the plug still on the end of the stem bolt?
    Ed
    Problem Solver:
  • 15 Answers
You might check Sheldon Brown's bike fixit page on the internet for possible solutions.
Posted on Apr 19, 2009
I need to change the date
Changing the date for the FT500WVB watch is easy. Just pull out the stem of the watch to its first stop. Then turn the stem counter clockwise a couple of twists and the displayed date will increment (that is increase) by one day and you will hear a little click. Keep twisting the stem counterclockwise and the date will increase by one each time with a little click. Stop when you reach the correct date and push the stem back in to its fully seated rest position. Note- be careful not to change the date when the watch displays a time between 9pm and 1 am as setting the date in this time range may cause the watch to increment the date at noon rather than midnight.
Note also that if you want to set the time you just pull out the stem to its second stop position and twist the stem to advance the position of the hands of the watch. Then when the time is set, push the stem back in to its lowest rest position. So remember- first stem stop sets the date and second stem stop sets the time. That's it.
Mar 25, 2014 | Casio Forester FT500WV-3BV Wrist Watch
My watch keeps stoping but my battery is new
If your watch keeps time for a while, then stops and starts erratically, you most likely have one of several common problems.
1. You might have a bad battery. Sounds silly, but watch batteries have a limited shelf life, and if you installed a battery that's already been in a blister pack for a few years, the battery itself could be the problem.
2. Your "set stem" is not completely pushed in. Quartz watches are designed to stop ticking when the set stem is pulled out. They'll start up again when you push the stem completely in. There's a little finger or spring-loaded prong to keep the stem in or out. Sometimes, that little prong can break off from natural use. When that happens, the stem will work itself out enough to stop the watch from ticking. Natural movement on your hand will push it back in, and the movement will take off again. Check to see that you feel a firm "click" when you push the stem all the way in. Sometimes, when changing a battery, the movement will shift inside the case just enough that the stem doesn't quite catch in the locked, "full-in" position.
3. Your battery has a bad connection. Make sure that the positive and negative terminals of the battery are in good contact with the appropriate surfaces. I have used a tiny piece of aluminum foil at times to increase pressure on the watch battery so that it makes better contact.
4. Your watch movement has dirt in it that is jamming the gears. Modern quartz watches are amazing devices--a tiny amount of force from the pulse motor operates an intricate gear system that moves all the watch hands and day/date wheels. Even a tiny speck of dust in the wrong place on a gear can gum up the works and cause a watch to start and stop. Usually this will happen at set time intervals or at the same time every day, because that's when a particular gear tooth comes into play.
Closely related to this is an actual bent or broken gear tooth. Same symptoms.
A watchmaker can test the gear train by placing your watch in a special testing machine that spins the gears much faster than usual. If the watch hangs up from time to time, it's suggestive of problems in the gear train. Sadly, fixing the problem by cleaning the watch may cost more than replacing the entire watch.
These are the most common causes for this behavior. Hands that rub up against one another, or a defective quartz crystal are two other potential causes, but this should serve as a fairly good checklist for obvious problems.
Mar 09, 2012 | Watches
How do you get the rubber tire off the rim?
Get the rim / tire of the frame. Let all the air out of the tube, Using two flat blade screw drivers, put them between the rim and tire about 3 inches apart, (be careful not to puncture the tube) Pry the tire over the rim, leave one in place and move the other about 3 more inches and pry the tire over the rim again, keep moving around the rim until the side is off. Reach in and pull the tube out, fish the stem through the hole. Finish pulling the tire off the rim, you can use liquid soap to help make things easy. Put the rim back together the same way. Hope this helps Fix Ya up.
Jun 18, 2011 | Mongoose Cycling
Westclox model LTX271 instructions for setting day
mcdevito75 here, The stem on your westclox has 2 positions, First pull the stem out to set the time of day, keep cycleing the watch until you come to 1 day before the day you want. NOW! push the stem back in. NOW! slip a finger nail just under the crown and gently, gently kift the crown to it"s first position, it may take a little practice so be patient, once in it's first position you can change the DATE easily, change the DATE to 1 DATE before the DA you want, push the syem back in and pull the stem back out and set the day/date and time of day. Your watch is set and will change on time a little past mid nite.
Jul 22, 2010 | Bulova Watch
How to set a month on seiko ska401
mcdevito75 here, The month you mean the date (number of the day in the month) your Seiko should show the day / date Here"s how.--- To change the day (Monday, Tues. etc) simply pull out the stem and turn the hands around until you reach the day, now push the stem in all the way, and gently slip your fingernail under the stem and gently lift the stem to it"s first notch or position, Seiko watches have a 2 position stem to make changeing the date, (number) easy so you don"t have to keep turning the hands around and around, with the stem out to it"s first notch or position simply turn the stem either toward you or away to change the date, (number) when done push the stem back in and your done.
Jun 23, 2010 | Watches
My Geneve watch, model "Seapearl" is only two months old. It keeps good time but the date is behind by 1 day. How do I adjust the date? I have tried to pull the stem but it will not move.
The stem (or crown) is sometimes screwed in to improve the water resistance of the watch. Try turning the crown anticlockwise before pulling it out.
It may be necessary to take the hour hand past midnight to get the date to change. This will be the case if there is only one "out" position.
If there are two "out" positions then one will be for the date and one for the time.
Jan 16, 2010 | Watches
I have a pre-owned but mint condition 18K two-tone Cartier Panther watch with the date in the 5'o'clock position. The date currently reads the 18th, but today is the 11th. Is it safe to pull out the stem...
hello,
first give the answer carefully
is you have a problem to set your clock.......
if yes..
then watch these video and tell me is you have the same problem
IF ANY DOUBT
contact me
Jul 11, 2008 | Cartier Watches
Setting Day/date on Helbros wrist watch
As an extra tip, to advance the date a little faster, you can turn the stem and rotate the hours past midnight and keep going until you pass 2 AM, then you can wind backwards, going past about 8:30 and you will hear a 'click', then you can go past 12 am again and the date will change. This makes it a little quicker to advance the date several days.
May 13, 2008 | Watches
Cycling Logo
143 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
