Question about Hoover U8171-900 / U8172-900 / U8173-900 / U8174-900 Savvy Bagless Upright Vacuum
Part terminology and replacement help
I need a part for my hoover savvy vaccum. It is the part that allowes the handle to lock the handle in the up osition when you are finished with the vaccum. I do not knwo what is it called and do not have a user manual ot find that name. The vaccum is model U8172-900. Can you help me with this item.
  • 281 Answers
Call tti floorcare 1800-321-1134. have your model number and the plant number ready you will need it
Posted on Apr 23, 2009
I knocked my savvy over and the cannister came out. misplaced the manual.need instrucytions how to reinstall the cannister.
aline the canister with the machine, handle facing out and push it in. if you go to hoover.com you can download the manuel for this machine. just remember not to put the dash in when entering the model num.
hope this helps
Jul 31, 2009 | Hoover U8181-900 Savvy Upright Vacuum
Hoover savvy will not move
the reset button is in the handle, under the cover for the switch. remove the two screws and pop apart. you need to pull up the little post under the lever switch, and push it back down. hope this works for ya.
Jul 01, 2009 | Hoover U8145-900 Savvy Bagless Upright...
On my Hoover Savvy U8174-900 on carpet setting, the brush spins when I pull the vacuum towards me, but stops when I push it forward. Belt is tight and fine.
Hoover savvys have two very common problems that cause this. The first and most obvious is the belt that you checked already. Many times the belt is tight but those particular belts have teeth and should you lose any teeth on the brushroller OR the belt it can cause this.
The other problem this is a symptom of is a bad switch in the handle. It sounds odd but the switch assy in these machines controls 2 motors, one that causes vacuum another that causes the belt to turn! Often time that switch assembly is bad and the smaller motor that drives the belt does not run when the handle is in a certain position. This causes your brush to stop but since the louder bigger vaccum motor is still operating you never hear the small one quit. I would run this again and listen for a difference in sound. In this case you will buy a replacement circut board that is installed in the handle (i usually replace the entire handle assy, the small extra cost is worth the dependability as nobody can seem to determine for sure what makes them go bad)
You can get the parts from any hoover service center, use their dealer locator to find the nearest one. Be sure to take the old parts in and compare when buying new, hoover makes running changes to their product so 2 machines with the same model number can be different.
Aside from a stray bad or pinched wire you're more than surely dealing with one of those two items. I'd focus on the first paragraph as that is by far most common and least expensive.
Best of Luck!!
Jun 09, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
A noise coming from the motor when I`m ready to vaccum
if it were m i would take it back and insit on a new one.something new shouldn't have to be fixed thatd why we buy it new
Dec 31, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Vaccum Cleaner
you probably broke the belt so check that. if the mains cord is damaged, you should replace it
Sep 18, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover Savvy self propulsion not working
The switch contacts are burned out and the switch must be replaced. This link sells the whole handle with switch but, check your serial number to be sure to get the right one. If you can use a Philips head screwdriver, you can do this easily.
http://buyitnow64.stores.yahoo.net/hovarepaswki2.html
Aug 21, 2008 | Hoover U8171-900 / U8172-900 / U8173-900 /...
How to fix wheels on hoover vaccum cleaner
i cant get the back wheels off my mach 3 hoover vacuum can anyone help?
Jul 14, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover savvy no suction on carpet setting
Check to make sure you hear the vac. motor is running when in that position. The switch in the handle could be bad if it is not.
Apr 29, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover U8171-900 / U8172-900 / U8173-900 / U8174-900 Savvy Bagless Upright Vacuum Logo
216 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
