Question about Ryobi Cultivator
Ryobi 410r; Primer bulb is cracked and is leaking all the gas
Ryobi Cultivator
Where can I find a replacement part?
Where can I get the part number?
  • ttrogdont Apr 28, 2009
    my primer bulb is cracked but it is not leaking all the gas out of the tank. I can still crank the engine since it is warm outside. The tiller runs good but I am concerned as to if the crack will allow dirt/dust/etc. enter the engine. Unlike other engines, where the bulb is held in place by a plate with screws, the 410r has no plate just a frame work that looks like it might be holding small carb parts in place. How do I replace the bulb safely?
  • 35 Answers
Hello, my Ryobi 410r tiller/cultivator needed new fuel line so I bought the fuel line, return and a new bulb primer. Unfortunately, I can't remember what hose goes where!!! Specifically, I've...
The primer pulls fuel through the carbruetor
So take your return line from the carb. and hook it to the inlet side of the primer and the other side
of the primer bulb transtions into the fuel tank.
You know when you have hooked it up right when you press the primer it fills with fuel and dumps back into the tank.
Jun 16, 2011 | Ryobi Garden
Fuel oil mixture ratio for ryobi 410r cultivator
I have a 410R still looks like new.
it has on it gas & oil = 40. to 1 for mixture.
mine never gets used so it is still new.
Jun 23, 2010 | Ryobi Cultivator
Ryobi cultivator won't start. Just had the gas lines replaced
it could be a pin hole leak in the primer bulb.
Jun 21, 2010 | Ryobi Cultivator
Needs new primer
You are searching for part number 181558. It is a snap in primer bulb with a piece of fuel line.
Oct 02, 2009 | Ryobi Cultivator
Gas tank leaks on a 410r how do we take it off.
remove the screws holding the recoil cover off I would think and go here for parts and use your model numbers to find your unit.
www.ereplacementparts.com/ryobi-tiller-parts-c-7931_15702.html
Jul 01, 2009 | Ryobi Cultivator
There are two hose/line openings in the gas tank of my Ryobi 410r cultivator. Where and which do these two lines go to? Which of them goes to the primer bulb? Also, there are two lines to/from the primer...
IT SOUNDS LIKE A TWO CYCLE ENGINE TO ME. THE HOSE GOING TO THE PRIMER BULB GOES TO THE HOSE THAT SITS ON THE TOP OF THE TANK AND DOEST GO IN FAR AT ALL AND IS USUALLY THE BACK. THE OTHER HOSE GOES IN THE NID PART OF THE TANK OR THE PART THAT THE GAS IS AT ITS HIGHEST POINT IN THE TANK WHEN THE UNIT IS IN THE POSITION MOST LIKE IT IS WHEN IN USE USUALLY THIS HOSE HAS A SMALL FILTER IN THE TANK. THIS SYSTEM OPERATES ON PRESSURE. WHEN YOU PUMP THAT BULB, IT PRESURIZES THE TANK FORCING GAS UP THROUGH THE OTHER LINE TO THE CARB. IF YOU ARE SYING THERE IS A 3RD HOSE HMMM, THAT PROBABLY GOES TO THE MIDDLE PART OF THE CARB
REGARDS
Jun 30, 2009 | Ryobi Cultivator
Unable to start Ryobi 410r cultivator
After starting close the choke , push the lever back in
Vitally
Jun 02, 2009 | Ryobi Cultivator
Need Replacement Gas Line for Ryobi 410r
They have the parts your looking for at www.lawnmowerpartstore.com
Apr 12, 2009 | Ryobi Cultivator
Ryobi Cultivator 410r
The linefrom the tank with the filter goes to the mixture inlet on carb. The fuel return goes to the suction side of bulb. The bulb outlet line goes to the tank. Hopes this helps
Mar 19, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Ryobi Cultivator Logo
1,906 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
