Question about Garden
No forward or backward movement
I was mowing my lawn, turned the mower off, then got back on and cranked it. Cranked fine, but when I went to start mowing again, it won't move forwards or backwards.
I did earlier smell something like a belt burning or something, but I figured that it was someone burning something rubber...
  • Anonymous Mar 28, 2014
    The mower will start but when you engage to start mowing it does not want to go forward or backward. The belts seem ok what else could it be?
    Sergeant:
    Champion:
  • 255 Answers
Change your drivebelt
shack
Posted on Apr 19, 2009
Why wont my cub cadet 1050 go forward or backwards
the transmission drive belt may have came off.
May 24, 2013 | Cub Cadet Garden
Gt 245 lawn tractor won't go forward or backward
Check the drive belts first. and make sure the hydro release lever is in the correct position. If it is not- you can push the lawn tractor and have the rear wheels turn. It sometimes doubles as a "Forward" "Neutral" "Reverse" lever on other brands of lawn tractor.
The belts should be in their guides and pulley grooves- check to make sure it does not have a hidden break by having the engine off, and pulling on the belt.
Lastly, check to make sure the hydro itself is not out of oil or low on oil. It uses low viscosity "HyGard" oil. Capacity if you drain the old oil out and refill is 4.6 quarts. Look for a leak if the level is low.
If it still does not move, make sure the levers are set so you are in forward motion positions, and push- if the rear wheels move there is a problem in the hydro unit.
Apr 07, 2012 | Garden
I have a craftsman LT 1000 lawn mower that runs the battery down while it sits and it will not charge the battery while mowing even though the guage says that it is charging.
Something within the machine is discharging the battary, it does not sound like the engine is not charging, there is a tool called a negative shunt, it connects to the negative pole on the battary and enables you to connect a multi meter, this will tell you if there is a charge going out of the battary when the machine is switched off, you can then disconnect components to see which one is causeing the problem, a good mower shop should have such a tool .
Mar 08, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My 42" Husqvarna (model #917.279240
Remove the center dust caps from the rear axles, start the tractor up and put it in gear and observe the axles, if one of them is spinning freely inside the wheel, you have lost the 1/4" square key that pins the wheel to the axle. Replace the key and you can go back to mowing. Hope this helped Tim
May 15, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Tractor will not go in forward gear, only reverse.
Try rocking the mower forward and backward while you try to shift it.
Aug 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
Jun 06, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
370 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
