Question about Hitachi 43FWX20B 43" Rear Projection Television
I have a Hitachi 43FWX20B. The green component of the picture is highly distorted. This happened suddenly yesterday. The Magic Focus does not have any effect.
  • pshafer2 Apr 19, 2009
    I should have mentioned that the Magic Focus stops during the green phase and the error code "5" appears. Does this add any useful information?
    Thanks. I'll give it a try. I am a retired Electrical Engineer with 35 years experience in the Semiconductor industry. I still know which end of a soldering iron gets hot.
  • 10,594 Answers
Symptom shows that it is problem of Convergence Out IC failure and that part will be replaced for correct picture results.
If you wish to repair TV yourself then you should have electronics knowledge, TV repair experience and should know how to solder parts on circuit board.
You can download Service Manual copy for free form HERE. Please download all 16 files and use WinRaR software to unzip file. You will get PDF file of service manual.
Required part STK394-160 quantity 02 are available in Part Store.
If you are not comfortable with TV repair then call local TV repair shop fo fix.
Hit "add a comment" button for further query / info.
Thanks.
Posted on Apr 18, 2009
  • Shahid Electronics
    Shahid Electronics Apr 19, 2009
    information?
    Yes, error code 5 shows that magic focus has not been adjusted as system control tried to move green convergence but did not receive correct signal through sensors mounted at sides of screen, due to failure of above said ICs.
    Please replace STK394-160 as above mentioned.
    Thanks.
Hitachi 43fwx20b Convergence Problems
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 25, 2010 | Hitachi 43FWX20B 43" Rear Projection...
Will not focus
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Feb 02, 2010 | Hitachi 57F500 57" Rear Projection...
Hitachi 43fwx20b magic focus the 3 colors are not adjust.
First have the convergence IC's replaced these are the two large black IC's mounted on an metal heat sink.
Oct 24, 2009 | Hitachi 43FWX20B 43" Rear Projection...
One half of picture is distorted
to create the total geometry in the tv is needed a system called Convergence.Convergence amplifiers are damaged in this unit, magic focus cannot work because magic focus works to level computer and controls the amplifiers damaged. this repair is for a technician because an adjustment is needed after the amplifier's replacement.
Oct 09, 2008 | Hitachi 61SBX59B 61" Rear Projection...
Blurry picture
can you be more specific? magic focus doesn't fix etc etc?
Jun 02, 2008 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 43FDX01B (convergence) problem
hi i have same prob iv bin told its a convergence chip an thay r £150 ! thay go bout evry 6 years an its comon .. any way there coming 2 fix mine 2day so ill let u know if it sorts it out my mail is mjoutlaw@hotmail.co.uk thanx
Jan 30, 2008 | Hitachi 51F500 51" Rear Projection...
Horizontal hour glass picture
The convergence Ics need replaced. In Hitachi, resistors and sometimes a coil needs replaced as well. The convergence/deflection PCB is available, but, the cost of that board is higher than having a servicer come to your home and repair the unit to component level. If you are not familar with this circuit, then call a servicer. Have them replace both ICs not just one. Make sure they are repairing to component level and not replacing the board. Hope this helps.
Dec 16, 2006 | Hitachi 43FWX20B 43" Rear Projection...
Bad picture
convergance ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Oct 26, 2006 | Hitachi 57SWX20B 57" Rear Projection...
Hitachi 43FWX20B 43" Rear Projection Television Logo
54 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
