Question about Dell Inspiron 9400 Notebook
I have an inspiron 9400 that won't boot and says PBR...2 error occured disc write error. Even when I try to boot from the cd it stops at "set up is starting windows" and neve does. Can you help me?
  • 102 Answers
Disk writer is faulty change it
Posted on Jul 17, 2009
My Dell Inspiron 6400 (Windows XP Home) won't reboot. It's giving me a "Loading PBR for descriptor 1 ... done" line on a black screen. What can I do to fix it. Can I salvage my content / files
Before you use the Recovery CD you need to backup your data because to restoring your laptop will wipe your data off the hard disk.
To backup your data when you cannot boot up your laptop, remove the hard drive and connect it to an USB hard drive adapter. Connect this hard drive/USB adapter into the USB port of a working computer. The computer will see it as an external storage device, you can then open the folders and backup your data.
You can then fit the hard drive back into the Dell laptop and boot up with the Dell recovery CD to reinstall Windows etc.
Mar 04, 2013 | Dell Inspiron 6400 Laptop Computer Core 2...
My dell inspiron 545S won't load. gives me error #25
It' most likely that your hard disk drive is defective. Try to boot from a CD\DVD disc, if it does, you have a problem with your hard drive.
Feb 15, 2013 | Dell Inspiron 545 (884116037743) PC...
Screen says" Loading PBR for descriptor
And again and again and drives you up the wall.OK-boot sector is corrupted, or hard drive is going south.What you can try is system restore.On boot see which button is designated for that-usually f10 or f12.Start tapping that button and follow instructions. If that failed, the only option is to reinstall OS.If you have a lot of stuff that you want to save, install Windows in different folder, say WindowsA.All your stuff will be saved on the Hard drive-My Documents.Good luck and keep us posted.
Jun 14, 2011 | Computers & Internet
A disk read error occurred press ctl+alt+delete to restart
May I know whether the Hard Drive is listed in the BIOS? Try reinstalling the Windows using the Windows OS disc.
Jul 04, 2010 | Dell Inspiron B130 Notebook
Tried to reboot from the factory setting F11, came back with Loading PBR 2...done. A disk read error occured Press Ctrl Alt Del to restart, did that but the same message appears.
this a error for Primary Boot record 2..and for some reason it could not get past this stage ..I guess yo will have to install it the classic way from a bootable disk ..and to install the drivers after by downloading them from the factory site ...THis will assure a 100% success in installing the operation system and will be faster than trying to fis the error..I got this problem before...
Or better just get to the dell support site ...and get a recovery disk ..My advice is to install the operation system manually and than to use the recovery disk to install the drivers all at once ..
If you do not have a installation (bootable) disk ...just try to download and burn (with nero ) a image from the Pirate bay torrent site ..
you will need a utorrent program for downloading image file from the site ...to locate one ..just make a search for it ..there are many available ...
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INS_PNT_6000&os=WW1&osl=en&catid=&impid=
here are the drivers you will need in case you manage to install a clean OS from the disk ..
remember before using a bootable disk go to bios and set the boot order to have the cd/dvd as the first boot device and save changes with F10..
after that just restart with the disk inside..confirm the action and go for it ...
Jun 16, 2010 | Dell Inspiron 6000 Notebook
Loading pbr 2 done message
battery had all lights lit. Took it out and now the front battery display light is flashing. I have a new mother board could there be a problem with recognition?
Mar 13, 2010 | Dell Inspiron 6000 Notebook
INSPIRON 9400 DOESNT BOOT - BLACK SCREEN - PLS ADVISE
make sure there is no CD/DVD left in the drive bay when you boot your laptop. Remove usb flash drives also.
Regards!
Jul 17, 2009 | Dell Inspiron 9400 Notebook
Loading PBR for descriptor 2...done
Boot to the Diagnistics FN+POWER at boot, run hard drive diagnostics. The PBR Descriptor 2 message is part of the normal boot process (directing the boot loader to Primary Boot Recond 2, the C: Drive) but usually flashes on an off so fast most people never notice it. Since the boot process is not going past the re-direct it is indicative of a bad hdd (Since the re-image process crashed)
Most likely you are looking at a hard drive replacement.
Regardless you are going to need an XP CD (you'll have to reinstall windows or run recovery console at a minimum)
Apr 01, 2009 | Dell Inspiron 6400 Notebook
Not going in window xp
You will have to try and boot from the Operating System CD and Run a Check Disk
from the repair utility chkdsk /r/f/p or try a factory restore on boot Press and hold: Control key + F11
Nov 17, 2008 | Dell Computers & Internet
Problems with Dell Inspiron 9400 Video Memory conflict -
This solution is totally incorrect. He is having the problem that many of us face with the GeForce Go 7900 GS and the Inspiron 9400. There is a known issue with eventual overheating and the video card going bad. This is specific to the single-pipeline chip, in which their is a new dual-pipeline style that fixes the cooling/overheating issue that eventually fries the video chip. Dell has not 100% took ownership of this. I am on my fourth fried video card (thank god for the 3-year warranty I got) in which they have previously replaced with the single-pipeline style. This time they are finally replacing the laptop with either a new Inspiron 9400 (better be dual-pipeline chip) or a NEW equivalent laptop.
Mar 27, 2008 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 Notebook Logo
184 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
