Question about Samsung HP-S4253 Television
Color bleed thru problems
I've got a 40 inch Samsung Plasma TV model # HP-S4253. I bought it Jan 07. When it's been on about an hour, a bluish/purplish color bleed thru appears along the bottom and right side. It only shows up on white areas or light colored areas (i.e. in text, faces, yard lines on football fields). I've heard that this is fairly common and can be fixed by an adjustment of some kind. Do you have any information that I can use. My TV is still in warrenty but there are no service centers near where I live. Thanks
  • zoknix Nov 25, 2007
    I have the same problem that you do. I get a bluish bleed through along the left side of the TV on mostly white colors (yard lines, white jerseys is when I see it). Was there ever a fix put out for this? Thx!!
  • brians_house Nov 29, 2007
    I've got the same problem. The upper left corner of my HPS4253 has several blue colored pixels constantly. However, they seem to be worse when the picture in that particular area is lighter in color.
    I'm currently working with Samsung on having a technician come out to my house to look at it because it has happened within one year of purchasing my television.
I finally was able to get my TV to a service center and it is an adjustment that they have to make. My TV has been returned and is much better but still shows some blue. They are going to pick it up and try again next week. I'll let you know the final outcome. P.S. It was covered on my warrenty.
Posted on Dec 02, 2007
  • 179 Answers
This set only has a 12 month parts and labor warranty so you need to call 1 800 samsung or the dealer you bought it from..the problem with adjusting the v_set and v_scan voltages is it may last for 6 months and then you would still need a new plasma panel..better to have a samsung authorized tech check it
Posted on Dec 01, 2007
  • ken black Dec 02, 2007
    push to have the panel replace..if they adjusted it and it is still there at all the panel is bad..you may have to call samsung directly.
SOURCE:
Plasma tv repair
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on ... samsung plasma tvnot working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56. by Matthew ...
Plasma TV Repair Tutorial - Common Symptoms ... - YouTube
? 7:13
https://www.youtube.com/watch?v=gnkyAGyI7GA
Oct 9, 2013 - Uploaded by ShopJimmy.com
Plasma TV Repair Tutorial - Common Symptoms & Solutions - How to Fix .... Samsung 50" Lcd tv model#Lf501EM6f Im not sure if its plasma or ...
WHAT Plasma TV BOARD CAUSES NO PICTURE REVIEW ...
? 4:10
https://www.youtube.com/watch?v=DC_75FfrR9w
Nov 8, 2012 - Uploaded by Tampatec
WHAT COMMON PART / TV Board IS BAD ON SAMSUNG Plasma ... a gamble. it the cost of repair is over 300 just buy a new 50 inch tv for 600.
Samsung 50" Tv Power Supply Boar...$34.00eBaySAMSUNG UN60EH6002FXZA...$23.00TV Parts Guy42% price dropSamsung 50" Pn50c550 Pn50c45...$18.99eBay
Dec 21, 2015 | Samsung PN60F5500 60-Inch 1080p 600Hz 3D...
My Samsung HD-S4253 42" plasma TV will not turn
did you ever find a solution? Mine is doing the same as of yesterday
Richard [email protected]
Sep 11, 2011 | Samsung HP-S4253 Television
Samsung HD Plasmhp-s4253 has developed some color issues. The
I had this same problem and one of my component cables was slightly unseated. Slight push back in and got all my wonderful blues back!! Thanks tvtek for this suggestion!
Nov 12, 2009 | Samsung HP-S4253 Television
Plasma tv
bad y buffers , your model may have only one y buffer and you may need a Y main too. voltage checks can confirm VS and VA voltages marked on board plugs and tag inside TV
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Jul 26, 2009 | Samsung HP-S4253 Television
Sammsung s4253 plasma tv audio garbled on digital channels
I had the same problem with my S4253 using Directv. I then turned off the Dolby Digital on the sound settings on the Directv satellite box. Problem went away.
Oct 04, 2008 | Samsung HP-S4253 Television
Blue Bleeding on Plasma Screen
I don't really know this model of Tv. but i know this model of
Samsung panel. If u remove the back cover of the tv and look at the power supply at the left and top left you will need to make voltage adjustments. At the top right of the plasma panel you will see a sticker with voltage for adjust the VS VE VSET on the power supply 110 to 100, 205 to 190 and 195 to 188. And this should clear up the blue rash on screen.
May 02, 2008 | Samsung HP-S4253 Television
Samsung HP-S4253 black screen, with sound
Its the broadcasting company and there "new technology" Have had an over the air box to get local HD channels and lost my PBS station, turned out to be a new signal incompatibility. The same is with my HP-S4253. Must not have the latest SW to process the new signals
Feb 19, 2008 | Samsung HP-S4253 Television
Problem with samsung plasma tv
hello ive just bought a samsung plasma off my friend and its about a year old and yesterday i set it up and get a fine picture untill about a hour or so of being on it starts geting blue sparkles round the outside of the tv mainly on the left side and seems stronger when sport is on ive tryed doing different things but nothing seems to work?i have also bin told that plasma tvs have to have gas put in them every so often is this true?i dont no which samsung model it is but it is 42inch and is full hd ready and is black with the round circle on the front of the tv can you help me?
Dec 19, 2007 | Samsung HP-S4253 Television
Televison & Video Logo
278 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
