Question about Lexmark X4270 All-In-One InkJet Printer
Printer not printing
The printer will not print. It says: Memory Full How do I clkear the memory or get it to print? Thanks, Suzanne
    President:
  • Lexmark Master
  • 2,022 Answers
Just cancel all the pending job form the cancel button and switch off complete your printer for 5 minute and swith it on again. bye
Posted on Oct 01, 2007
SOURCE:
Lexmark Optra S1250 Printer - Message "38 Memory Full". I tried to power on the printer without the printer cable attached.
You may have a document (or multiple copies of the same document ) stuck in the print queue. Turn off your printer, then pull the plug. Got to the control panel (or equivalent) on your computer and check the Lexmark print status for content and delete it, if possible. Reconnect the data cable to the printer, then reconnect power and turn it on to initialize. Cue up the print job again and go.
Feb 16, 2018 | Lexmark Office Equipment & Supplies
What does "100 %" stacked mean?
it means that the printing order for the memory for the printer is full
go to control panel , go to printers and hardware , click on printer right click and it will show a section see what is printing
high light each line and delete that takes away the priority of the stack until there is nothing left to print and the printer should again print at the next selection you make
How the program works is this
there is a small memory in the printer and a large one in the pc
when you have data that is to be printed, the pc sends the data until the printer memory is full at which stage the printer starts to print. new data is sent as memory space becomes available until the document is printed
when different data is requested to be printed or there is a hiccup in the process the pc looses the priority in the print list ( page number or new document)and so backs up that memory and becomes blocked
by going into the pc in the printer hard ware and deleting the printing waiting to be processed your are unblocking the process and allowing the pc to again move data to be printed
Nov 08, 2015 | Brother Office Equipment & Supplies
Error messg 016-700 Memory Full
Try this, it may be a large print job held in memory.
Press 80-0-1327 to clear the message, cancel the current print job, and conduct the next print job, if any. · Press Cancel to cancel the print job.· Press Menu to open Stored Print and delete the holding job. · To avoid this error in the future, do the following:· Delete unnecessary fonts, macros, and other data in printer memory. · Install additional printer memory.
Oct 01, 2014 | Dell 2135cn All-In-One Laser Printer
WHEN PRINTING HP LaserJet P3005n Printer A MESSAGE TONNER REFILS, BUT TONNER FULL
Toner cartridge memory counts how many print outs passing through it, once memory sensed yield count crossed, printer will say that "low toner" , after couple of prints it will says to "replace the cartridge". If you refilled this cartridge with out replacing the memory printer will treats its old cartridge only.. Replacing the memory will solves your problem.
Ideal memory chip...
Sep 05, 2012 | HP LaserJet P3005n Printer
Dell 2135 full memory error message cannot print PDF files.
All three replies are incredibly stupid, but especially Frank's. The issue is simply that you're trying to print something that has too much complexity in it for the printer's pre-installed memory to store the final rendering of before printing. The way a laser printer works, unlike an ink jet, it has to take the entire page to be printed and render the final output in memory before the page can be fed through since it doesn't go line by line. If you're trying to print something that has a very complex page in it, such as a full 8x10 photo, the base amount of memory may not be enough. Dell sells a 256MB add-on memory chip you can put in the printer to get around this. Unfortunately the only other way around the issue would be to reduce the complexity of the page; perhaps try printing the PDF scaled down to 70% so the printed output is a lot smaller but also takes up less of the page, meaning the printer may be more likely to be able to fit the page into the existing memory.
Nov 24, 2010 | Dell 2135cn All-In-One Laser Printer
Memory is full
Print out a printer config page.
Verify the memory size stated on the config page.
Goto your computer open the print driver and see what the memory is set at. Make sure they are the same size.
Jul 27, 2009 | HP LaserJet 3055 All-In-One Printer
Error light keeps on flashing blue light at the
These are your possibilities based on your error.
Front cover is open
Close the front cover of the printer.
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
does not start printing, press the Go button.
Memory full
The printer memory is full and the printer cannot print full pages of a document. See
Solving print problems on page 97.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document. See
Jun 14, 2009 | Brother HL-2170W Laser Printer
How do I clear data from my RAM disk on Dell 3100cn printer
The RAM for the printer is temporary.
turn off the printer and unplug the printer from the outlet. wait for 20 sec. plug the printer in and turn it on.
you can select in the printer properties page of the printer to print immediately instead of spool and print from the last page first. that will eliminated the ob store in the RAM.
Mar 28, 2009 | Dell 3100cn Laser Printer
My Canon mp730 memory holds a fax- how do I retrieve it?
just press the start/print button on the machine and it should print it out for you.
pressing delete would clear the memory.
Aug 07, 2008 | Canon S200 InkJet Printer
Memory full
Start - Printers and faxes - (right-click your printer) - Properties - Printing preferences - Advanced - Check box 'low memory module'...
Nov 26, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Lexmark X4270 All-In-One InkJet Printer Logo
41 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
