Question about Brother XL-5130 Mechanical Sewing Machine
The casing behind the bobbin came out...2 pieces...
I do not have a manual and cannot get them to stay in.......I need the info right away........am going on a concert tour and have to get sewing done.
thank you thankyou
karen
supermom_3414@yahoo.com
  • 37 Answers
You can go to www.brother-usa.com and get an online manual. You can print it out or just save to your computer and reference. It should tell you how to get the casing set right. Good luck.
Posted on Apr 19, 2009
MY THREAD GETTING WRAPPED AROUND THE BOBBING WHEN TRYING TO SEW THE TOP THREAD WRAPPING AROUND THE BOBBING CASE AND DRAGGING CAUSING THE TOP THREAD TO BREAK ?
It sounds like the lower shuttle is out of place. You should be able to take out the bobbin case and unlatch the shuttle. It will probably be in 2 pieces. Clean out the dust behind it and replace the shuttle pieces. You may have to fiddle with it a little to get them back in place. Then you can test it by manually turning the wheel. Make sure the bobbin is placed into the bobbin case and that the bobbin turns in the direction that you pull the thread.
Good luck.
Nov 11, 2014 | Brother Disney PE-180D Computerized Sewing...
I released the bobbin case to get bunched up thread out now need a diagram of how it goes back together,,I have 2 loose pieces
I can only give a general answer; you did not state what make and model you have.
Generally with bobbin cases, there is a flat part somewhere, as well as the "wings." The flat part goes under the needle, and at least one of those "wings" is designed to rest against something in the bobbin basket that holds it to prevent the case from rotating during sewing.
If you cannot find your user's manual that TELLS you how it's supposed to go in, you can generally get a replacement manual that you can download--either from the manufacturer itself, or there are a number of places that will provide one either for free or for a nominal charge.
Sep 12, 2014 | Sewing Machines
Bobbin case bound up with thread and popped out of position
Ensure needle/needle bar is fully up at its highest point, replace the bobbin case with its open end seated at the back, the rotary hook tip should be just underneath it, just check further that it resides nicely along the groove of the rotary hook, re install the needle plate cover and tighten the 2 holding screws so that the bobbin case can be nicely in place, manually and slowly hand wheel the needle down several time to ensure the bobbin case is not unseated/needle is not knocking the bobbin case. Hope this can help/otherwise there are adjustments that need your local technician to do it.
Jan 10, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
Bobbin case
I would recommend using an authentic bobbin case and bobbins for your Bernina. Your dealer will have them. Just be sure to tell them the model you have.
FWIW, you can remove the shuttle hook and bobbin case by turning the 2 little black levers at the bottom right and left in the bobbin area, Once you do that, the circular piece that holds the bobbin mechanism in place can drop down and the bobbin case and shuttle hook can be removed as one unit. You should probably do this frequently to brush out the lint and debris and to oil the "shelf" where the hook resides. Oiling the hook shelf should be done about every 8 hrs of sewing.
Here's the manual for your machine:
The aurora 440 QE sewing machine for everyone and every application
Nov 29, 2017 | Bernina Sewing Machines
Top thread gets caught on crescent piece holding in bobbin case
If you have the manual take a better look at how to put the bobbin in the case,
sounds like you are putting it in wrong,
make sure you put the bobbin in with the thread com-ming off the bobbin in the right direction (left or right) if not put in the right way you will get what you are saying
ALSO: bring up the bobbin thread your self by turning the hand wheal and bring the thread a few inches to the back of the needle and hold when starting to sew the first 2-5 stitches.
when you do not hold the thread the machine will pull the thread in the bobbin area and cause problems.
you will get use to holding and it will get easier.
hope this helps
Sep 03, 2009 | Kenmore 15208 Mechanical Sewing Machine
Bobbin case is disassembled. how do I put it back together?
It should be in your manual.... but if you don't have one, I'm gonna try this out. I don't know the official names, so bear with me.
There should be two plastic arm-lookin things that are turnable. Make sure these are turned outwards.
You should have three silver pieces. The one you need first is a half-moon looking thing with a knob comin out of the middle. (it also has some holes in it)
If you turn the big knob on the right hand side, there should be a moving piece on the inside of the bobbin case.
The half moon needs to fit in with that piece. Don't force anything cause we don't want the machine to break. >< The knob thing needs to be facing the outside, otherwise it's not gonna go in at all.
Once you get the half-moon thing in there, you have two more left. There's a big circle. WOO! CIRCLES! ANYWHO, The big silvery circle.. it has a knotch in it, and a little pokey-outie thing comin' out of it.
It needs to be positioned so that the knotch (on the inside of the circle) is up and the pokey-outie piece (on the outer side of the circle) is on the bottom. On your machine, there should be a place where the pokey-outie piece would fit perfectly into a little hole-type-thing. Put it in. :O
Now it's time to move those little black plastic arms towards the center. On your circle, there should be little grooves that they fit right on top of. ^_^
The only silver piece left should be the actual bobbin case deal. This should be a smaller circle with a movable arm and a silver thing pokin' out of it. (I told you, I'm bad at names!) Before you put this guy in, we need to have your plastic bobbin threaded. (I'm assuming this has already been done, correct me if I'm wrong.... they also have pre-threaded bobbins for sale, but hey, whatever works.)
Your bobbin needs to fit inside this last piece. (my first bobbin didn't, and I freaked out and ran to my dad... LOL) You need to make sure there is a trail of thread coming out of your bobbin that's about two to three inches long. Place your bobbin in the silver guy and there /should/ be a little niche where you can play with the thread and pull it through the silver guy's parts. (Your thread may break, don't worry, just try again)
When you move the thread around, it should come out where the little arm that sticks out is. Keep the 2-3 inch trail goin' on, you'll need it. Remember that first half-moon silver guy? Well, we're gonna stick our little assembly onto his pokey-outie piece.
The silver arm-thing on our assembly needs to go into the knotch that's in our circle, and push in so it clicks. (Sometimes mine clicks twice...) Make sure you have that trail of thread, and go ahead and flip the white plastic up, because you're DONE assembling it.
I'm going to assume you have your top thread in already (again, correct me if I'm wrong..) make sure that your top thread is through the hole in the needle, otherwise we're thoroughly screwed. Pull that thread until you have another 2-3 inch tail, and twist the big white knob on the right side of your machine (same one as before...) TOWARDS you. KEEP HOLDING your top thread, otherwise it'll disappear into the abyss that is your bobbin assembly.
When you turn the knob towards you, your needle should dip down into the abyss and come back up- with your bottom thread! HUZZAH! it SHOULD be a loop around your top thread. (I'd use contrasting colors for practice.. so you know what it'll look like)
The manual says to "grab the bottom thread" but seriously, I can't get me fingers down in there, so I just slide some scissors under the foot and between the two sides of the loop, and just slide 'em left. usually works just fine. Unless my tail for the bottom thread is too short, cause then it'll be hard to grab. You should be good to go!
I know this is pic heavy and kind of long, but I like to provide as much info as possible! Let me know if it helped!!
Jul 19, 2009 | Brother LS-2125 Mechanical Sewing Machine
I have a 15212 model sewing machine & have hardly used it. When sewing the other day a few stitches went out of the fabric and got stuck. I opened the shuttle assembly, cleared the tangled thread and...
Sorry to say but one of your steps is incorrect. Look at it again, take a deep breath and gom
over everything slooowly. If this really doesn't work then Im afraid it's a technician you need :) .
Apr 27, 2017 | Kenmore 15202 Mechanical Sewing Machine
Bobbin Thread Doesn't Join the Upper Thread
Have you lowered the presser foot lever? It is the lever behind the needle that makes the foot go down. Do you put the bobbin in the machine from the top of the machine or from the front? In either case, you need to make sure the bobbin thread has clicked into the tension slot in the bobbin case. The bobbin case is the part of the machine that the bobbin sits in. It will have some kind of narrow cut out with a thin metal shaped piece half covering the opening. The thread has to go down into the cut out piece and click down beside the metal piece. You will hear a faint "click" when it is in place. Very hard to describe, but easy to show someone! Write back if this is not helpful to you. Also tell us your machine model.
May 04, 2009 | Sewing Machines
HELP ASAP!
The bobbin case is in the wrong position to lock into the shuttle holder.Try instead of holding the the release lever of the bobbin case open, instead position the bobbin case finger to the up position and insert the bobbin case by pushing it in with your thumb. You should feel or hear it snap into position. You may have to rotate it slightly to get the finger in the proper position.
Nov 17, 2007 | Brother XL-5340 Mechanical Sewing Machine
Brother XL-5130 Mechanical Sewing Machine Logo
82 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
