Question about GE Refrigerators
WHISTLING NOISE DAY AND NIGHT IN FREEZER SECTION REFRIGERATOR GE MODEL GSS201BPDWW WHEN MOTOR IS WORKING
The whistling is caused by the air circulating fan located just behind the light. It is easily accessed by removing the light cover and the two small hex screws above the light. To stop the whistling I simply turned the freezer off and pulled the fan cover out slightly to reveal the fan blades. I then pushed the blades down, toward the bottom of the until the blades stopped and i could feel the shaft slightly protruding from the top of the blades. Repositioning the blade has stopped the incessant whistling. Hope this helps!
Posted on Aug 08, 2009
  • Steve Wilde Dec 24, 2011
    Even though my GE was slightly different model, just going in and messing with fan, andven slightly repositioning stopped the incessant lost MOANing from the freezer section! Thank you!
GE model GSS22SGRBSS freeser fan slows down
Same problem and think this unit is a piece of JUNK. In 5 years of service i have had to replace the Water shut off Valve twice, and the heater located on the bottom of the freezer which helps to keep the freezer defrosted. The fan has a whistling sound constantly, within 2 days of putting something in the freezer it is full of ice. Sorry pal, but as I said this model is a piece of junk.
Mar 15, 2010 | GE Refrigerators
Whistling sound from inside freezer compartment
is this a loud whistling, like a dying bird stuck in your freezer, or is this a lower pitched, sort of gentle whistling sound. If its the former, you likely have a faulty freezer fan motor. replace
if its the latter, sounds like you may have a issue with the door damper, which allows the air flow from the freezer into the refrigerator. However, assuming you dont have any cooling problems, you didnt mention if you do, it may simply be a normal occurance, as some makes and models open and close this damper door automatically, and when it is closed, can sometimes cause a low whistling noise
Feb 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have GE GSS22WPGT and there is a constant
you have condisation on your condensor fan and it is vibrating. when you defrosted the unit you melted all the ice in the freezer. once the unit got cold again you had the same problem. it happens when you open the freezer door. the only way to fix it is to repalvce the fan and fan motor, as well as the main board. this is a costly repair unless it is under warranty.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer fan noise
Remove the freezer panel to access the fan motor. Look for any obstruction around the fan or blade. Ice, misplaced wire etc.
Check the fan blade. Sometimes they slip down the shaft too far.
If you find none of these issues, replace the fan motor.
May 25, 2009 | GE GSH25JFR Side by Side Refrigerator
Freezer Humming. Making me Crazy.
the fan motor is probably going bad.its about a $50.00 part and its behind the back wall,grab the model number and go to an appliance parts store and order or pick one up.
Apr 25, 2009 | GE GSH25JFR Side by Side Refrigerator
WHISTLING NOISE-DAY AND NIGHT REFRIGERATOR MODEL # GSS201BPDWW
Pull the cover off to the fan and compressor housing and clean it. Clean coiling as well. Most coils are located under the unit. They make an appliance brush to reach between the coils that can be purchased at an appliance store.
Apr 18, 2009 | GE DBSR453EBWW Electric Dryer
Fridge is whistling
Mine was making a moaning, whistling noise coming from just above the ice maker. It happened when the fan speed changed. I learned on this site that the motherboard was probably defective.
Rather than go thru GE, we found a new one online for 66 bucks. I replaced it in about ten minutes and it's all fixed. Poor materials on the original, but this site was very helpful.
Jan 08, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Not cooling!
check the rear of the freezer you may find a build up of ice there if so you have a defrost problem chances are the heater is bad you can unplug ref and let thaw or you can tear into the rear (pretty easy) and defrost with hair dryer and look at theheater which is a glass tube usual only one at the bottom of the coils but some models have two one in the center you will most likely find them bad if they are not chrome looking then they are bad replace defrost thermostat also this is common rule.let me know what you find god luck
Jan 08, 2008 | GE GSH22SGRSS Side by Side Refrigerator
Refrigerators Logo
820 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
