Slow motion of pictures
My pictures look like freezing style when dragging an image or windows
  • mrninja
    mrninja May 11, 2010
    is everything acting slow? do you get pop-ups?
    Scholar:
  • 85 Answers
This usually happens when the display card is not up to date. You need to install drivers for it. Tell me the make and model of your computer and I will try to give you the link after searching for that.
Posted on Jul 27, 2009
What setting do i use when taking a movement picture ex. like kicking a ball
Any settings you want, as long as you present the image YOU want.
A fast shutter speed will freeze the action. A slow shutter speed will convey a sense of motion. You might also try panning with the action.
Your local library or bookstore should have books giving plenty of pictures showing the two approaches.
Oct 25, 2016 | Cameras
Sony Bravia KDL52W4100 52 inch TV that is ghosting
This is a good picture and the tapping confirms some thing I have seen, this model is involved in a recall of sorts--the most common issue with it is around the T-Con board.
It can be bad connections on it or where it connects to the screen unit, it can also be inside the display panel (screen unit) where it cannot be got at
If it reacts to tapping any good shop will find if bad or loose connection outside of the display panel--if inside there is not a way to get in there, entire panel would in that case have to be replaced which usually means its cheaper to buy a new set.
have a expert or a shop look to see if outside the display panel or not.
Dec 21, 2012 | Sony Televison & Video
My computer keeps freezing when I try to copy or drag a file
let me say you first that this is a common problem with windows 7. i am not blaming windows 7 for it if your computer is not compatible run it.even the computers having very good configuration is facing this problem.so it is my suggestion if you like rather switch over to windows xp sp 3 which will not cause these problems.actually windows 7 needs too much of graphics and thus it makes those computers slow which does not provide it with enough graphics and enough ram(i would like to say that computers with 500GB hard disk and 4GB ram also suffers this problem.)
Apr 03, 2012 | Microsoft Windows 7 Home Premium
How do you take a picture of a fast movement?
It depends on the effect you want.
  • To freeze motion, you need either a fast shutter speed, or a fast flash in a dark environment. In less than bright light you may not be able to get a fast enough shutter speed to stop the action. Increasing the camera's sensitivity to light by increasing the ISO will help some.
  • You can blur the motion by using a slower shutter speed and a stable camera. Set a slow shutter speed and put the camera on a tripod or other stable surface, and you can get things like streaking car taillights and star trails. How slow a shutter speed depends on the speed of the subject.
  • You can pan with the subject. Move the camera with the subject, and keep it moving even while the display blanks out while taking the picture. This will keep the subject sharper while blurring the background to lend a sense of motion to the picture.
  • It's either to freeze motion if the subject is moving straight toward or away from you than if it's moving across your field of vision.
Sep 10, 2010 | Canon PowerShot S2 IS Digital Camera
How do get youtube to go in slow motion
if you have windows, then you can use windows movie maker. add your video to the folder, then click the effects link on the sidebar, scroll down, and you should find 'slow'. drag it to your clip. hope this helps
May 18, 2010 | Computers & Internet
Toshiba regza 32hl67 losing its' picture and motion is slow
I have a toshiba regza 32hl67 LCD tv which is only 2 1/2 years old. The picture on this unit just started to go the other day (screen darkens but images are still visible and the motion/movement is very slow). I contacted Toshiba and they just said to unplug the tv for 3 minutes to reset the tv. This doesnt work. I am VERY upset with Toshiba, after paying $800 for a tv that only lasted 2 1/2 years. If anyone has had similar issues and know how to fix it, please let me know. Thanks
Apr 26, 2010 | Televison & Video
How do I insert date on prints on my sony dsc-w50
You can use the supplied Picture Motion Browser (PMB) software to insert the Date on the images and then print the images with date.
Follow these steps to insert the date using PMB software:
  1. Start the Picture Motion Browser software.
  2. In the Picture Motion Browser window, browse to the folder directory that contains the images.
  3. Click to select the desired image.
  4. On the menu bar , click Manipulate .
  5. On the Manipulate drop-down menu, click View/Edit Media File .
  6. In open window, click the Edit icon.
  7. In the Edit drop-down menu, click Insert Date .
  8. In the Insert Date window, next to Display format , click the down arrow .
  9. Click to select the desired date or time format.
  10. Next to Color , click to select the desired color for the inserted date or time.
  11. Next to Position , click the down arrow .
  12. Click to select the position on the image you want the date or time to be inserted.
  13. Click the OK button.
  14. Close the image window.
  15. In the Picture Motion Browser dialog box, click the Save button to save the image with the inserted date or time.
  16. Click the Yes button to replace the original image with the newly-created image displaying the date or time.
Aug 30, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Whenever i am trying to play video then the picture is ok in minimized mode but as i swith to full screen mode the picture starts playing in slow motion,Also while dragging the window the window moves in...
Most videos are a set size for viewing if you enlarge the viewing of them. They will run slower and be pixelated because it has more work to do to play it It is normal for this to happen.
You could try "VLC Player" and see if it makes a difference
I use it for all videos and music files
Jan 30, 2009 | Asrock P4I45GV R5 Motherboard
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
