I have a zenith P60W36A Clicks on and off
I have a zenith P60W36A I love this tv and i really want to fix it. I am good with tvs and i know how to deal with them. But i can not find out whats wrong with this one. It turns on and clicks right off, i know its a safety thing for the tv but i cant find whats wrong.
  • Jay Abed
    Jay Abed Jan 11, 2010
    Problem was found in y sustain PCB.
SOURCE: hyundai plasma model HP-4200
Hello ****, I have the same problem. However. I manage to get the TV on by pulling the cable out and then plug it back in again several times. A couple of times just after you have heard the first click and the a couple of times just when you hear the second click. Sudenly the TV decided to work again. I think it must be a problem with one of the two relays that sits next to each other near the centre of the TV. If you take the back of and then plug the power back in you will see the two lights next to those relays come on and then die out when the relays let go. This is what hapens if the TV doesnt work. If the TV works those lights/LED's will stay green and the relays will hold on and feeding the TV screen. I will probably try to see if I can buy replacement relays and replace these. If I can get hold of them, then probably I would take the existing relays appart to see if I could see any fault. If those relays ar ok and the replacement relays appear in the same manor like the old ones I would look for problems before those relays. Maby order a new circut board from Samsung.
Con
Posted on Oct 20, 2008
phongnv
  • 56 Answers
SOURCE: Does not turn on at first only clicks and flaskes
Where did you bought the TV from? Your TV still under warranty. Give Vizio a call, they will take care of it.
Posted on Feb 18, 2009
  • 44 Answers
SOURCE: tv turns on clicks but never comes on just clicks
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsun. Know to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio conections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 02, 2009
  • 8 Answers
SOURCE: tv won't turn on...just clicks & clicks & clicks
replace caps on the power supply, put 1000microfarad, 16v caps
Posted on Jul 19, 2009
  • 92 Answers
SOURCE: My Samsung LCD TV will not turn on, it just clicks
A Replacement Power Supply.
Parts: £80 - £110 depending on the model.
Labour: £40 (ish) little bit more with a 90 day warranty etc.
Type your model number into www.chsinteractive.co.uk for the price on a PSU.
Good Luck.
Posted on Sep 07, 2009
Zenith Z42PX2D Plasma tv
Something short circuit with its circuit board. you must have through knowledge in electronics, and work experience to do repair work to this Plasma TV. As you know, plasma TVs are the latest technology devices, and a mere knowledge in electronics will not help. It will be best to get this set repaired by any experienced service technician or by the authorized service center for Zenith at your town. [Short circuit protection circuit energized, and latched the relay, not to supply voltage to damaged circuit board is the problem] The click sound you heard was the latch sound of the protection relay.
Aug 14, 2012 | Zenith Televison & Video
Green at bottom left corner I have a Zenith B27A74R 27 can i still get parrts to fix this tv I really love this tv
Hello
Green pach at the corner may have due to many reasons. The first one is due to the degaussing posistor resistor. If it have got open this fault may occur, the second one is open degaussing coil, fitted around to your TVs picture tube. The posistor faulure is usual. The other reasons are due to magnetc induction from nearby. To ensure that whether it is due to posistor failure or not, you just switch on the tv, switch if off. Turn its position to an other, say just 90 degree. Turn it on agin and see there is color patches comes on more parts of its screen, the posistor said above is working well, if not it is out. Replacing it is the only remedy.
The fault may be due to the magnetic induction from ouside. Be sure not to get any external speaker boxes or any materials that can cuse magnetic effects, nearby your TV. Turn the TVs loation to an other position and notice the effect.
This is due to some magnetic field there to deflect its electron beam to improper locations inside your picture tube.
To replace the posistor you have to open the back cover of your tv. The posistor is small resistor, cased in a black envelop, and look like a black small box, and can be located in the main power supply input section in your TVs power supply regulator sections. It usuall have 2 soldering connections, some may have three. Replacing it with similar type and number will solve your problem.
Before that be sure that there is no external magnetic field disturbs your TV. Ok.
Oct 25, 2010 | Zenith B27A74R 27" TV
Simply will not turn on..it clicks but does not go on
ive seen this tv manufactured under different names if fact they still use those parts in new tvs.check the capacitors, on the power supply i think they are 10v 680uf change to 16 v 1000uf. now here is thing that i didnt hope happened to your tv, there are caps on the main board if you see any blown just replace the board.
Sep 11, 2010 | Zenith Z37LZ5D 37 in. LCD TV
Does anyone know were to get instruction manual IQ3557CC
I am not sure which TV you have. You can get an operator manual from;
http://www.retrevo.com/support/Zenith-IQA36M46W-TVs-manual/id/277ci277/t/2/
for a large TV. Click on the "Get Manual" icon for download. The menu will probably be a close match.
Mar 27, 2009 | Zenith Televison & Video
Won't turn on - relay clicks, power supply squeals, relay clicks, etc,
The television has a protection circuit. Sound like you know something about electronics so that is cool.
I suspect the HOT or High Voltage Transformer. If you want to operate on it, they typically will short externally from moisture or plastic high voltage breakdown. The TV starts, shorts as it cannot come to full high voltage, then shuts down. If your brave, you can unsolder the HOT which is the part that is on the main board or that comes from the top of the picture tube wire into a dark or spaceship type object.look underneath, sometimes they short underneath and you can scrap the carbon and get it to at least start up and work. Do not leave this as a fix as it can be a fire hazard.
The HOT is the most common. They are around 20-60 bucks. 34" TV. I am assuming this one without looking it up it is NOT a flat screen, as most do not squeal like that nor do they have to de-gausse like the old ones. I just looked it up and yes it is not a flat screen. Old school, so that is more thank likely the problem.
Mar 02, 2009 | Zenith C34W37 34" TV
need check B+, standby power supply, and Horizontal defletion and components
Oct 23, 2008 | Zenith C34W37 34" TV
Zenith A32B43W color problem
Classic symptoms! Most of the last TV's made by the old, original Zenith company (Rauland division) had bad picture tubes even when new. This probably had something to do with their going out of business and being taken over by a much better Korean company (LG Electronics AKA Goldstar). Another lovely thing they did before biting the big one was to only sell a complete chassis as a repair part. If your TV is older and has a small white paper tag inside somewhere on the picture tube (usually near the larger brand and type number label) with the code "EIA 1101" on it, discard it. I have NEVER seen one of these work correctly! If the CRT is made by someone else, there may be slight hope. Even if the TV is not very old, if it was really made by Zenith, and not LG, the possibility of repair is slim simply because of the change of ownership. I was sad to see Zenith die such a horrible death. They used to be fairly good, but somehow never made the transition to color TV. After 1954 they were essentially moribund.
Oct 15, 2007 | RCA F32450 32" TV
YELLOW STAIN KEEPS GETTING BIGGER AS DOE'S BLUE CORNER SHADOWS
tv needs light engine if you ever replaced one id leave your house screaming too call zenith and tell them you want it fixed free asap dont ever buy a glass panel tv especially zenith the panels are lg
Dec 06, 2006 | Zenith D60WLCD 60" Rear Projection...
Tv blew up
sounds like the typical power supply or sweep problem in the zenith chassis. depending on how old this set is will determin if its even worth trouble shooting or taking it in to be looked at by a pro. If your not experienced with tv repair i would call a repair shop or take it in as tv sets have high voltage stored in them even after they have been unplugged for a while. If youve tinkered with tvs in the past or know someone who does zenith tvs are made for a complete chassis exchange. you can Call PTS Corp at 1 800 844 7872 and see how much an exchanged referbished chassis would cost and go from there. Good Luck
May 24, 2006 | Zenith A27A23W 27" TV
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
Electro Med Services...
