Question about HP Compaq nx7300 Notebook
Cannot detect the battery
The laptop is switched off, you plug it in to charge. it charges for about 3 min then switches off. You start up - the message reads: No batery present. the battery is fairly new.
  • 3 Answers
Sounds like the charger is the incorrect Voltage for the laptop/battery.
Did you buy a generic battery or brand specific one?
Check that the charger voltage and the voltage on the battery AND laptop all match
Posted on May 25, 2009
Acer Aspire 4830T laptop battery behaving vaguely
Do you still have the old battery. If so charge it, and see if it charges properly. If so then you have a bad battery.
Mar 18, 2017 | Acer Aspire Timeline X 4830T 14 Inch...
Hi, have a shoprider TE-889XL. Unit has new batteries and has had both the speed and throttle potentiometer replaced over the last 3 years to cure erratic throttle. Now with fully charged batteries it...
On older units this is a fairly common issue with loose, burned contacts at the battery terminal, battery harness plugs and circuit breaker. Check, clean and lube all the power connectors with a petroleum jelly. Don't use WD-40. Then retighten the connectors.
Another issue may be a bad key switch. Intermittent contacts can often be detected by wiggling the key when it starts acting up.
Oct 23, 2013 | Pride New Mobility Victory XL 4 Wheel...
I have samsung corby GT -S3653 it's battery backup is only 20 min and during call it automatically switch off
If the cell phone battery is more than 3 - 4 years old thenthe battery could be worn out. Rechargeable batteries have a finite number of chargeand discharge cycles and will lose their charge capacity over time, i.e. won'tcharge to 100% and gradually the charge reduces until the battery won't chargeup at all. OR The battery shows a 100% charge but when the adapter isdisconnected the battery drops off to zero capacity in a very
Apr 13, 2012 | Cell Phones
MD781 battery wont charge...will run with the power cord plugged in, I replace the battery first thinking that may be the trouble. Still wont charge...it would run for a short while on the battery when...
Hi
Can you please try to leave laptop switched off
plug in laptop and leave until the light on front goes green or at least 2/3 hrs
then unplug power cord
switch on laptop and use it or leave it until it looses all power and switches off
then recharge until green
when battery is fully charged always un plug and use on battery power
until it reaches about 10% before recharging
some people even remove their battery to preserve it if they always use power cord
if this does not sort the problem please come back to us
many thanks
Feb 23, 2011 | Gateway MD7818u Notebook
When my acer aspire 5734z laptop is plugged in the charger indicator flashes and the battery indicator shows blue.it stays at 0% and says plugged in,not charging.if i unplug the charger it shuts down. need...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Feb 11, 2011 | Computers & Internet
I have got acer aspire 5520 the problam is when i charge my laptop it says the battery is full so i unplug charger then it stays on 99 percent then after about 20 mins it will go off and when i switch back...
it sounds like your laptop's battery has a reduced charge cycle. I recomend charging it to full then letting it die 3 -5 times. (to completely die means that it wont turn on at all. usually this takes a couple of times turning on to be sure.) this should reset the internal memory there by restoring its charge capacity.
Jan 04, 2010 | Acer Aspire 5520-5908 Notebook
My aspire one d-250 battery doent charge
My problem was: Although the Batt Light shows the "charging" the desktop indicators show the battery is at 100%. If you dscinnect the power supply the computer dies.
SOLUTION: I found this worked on both occasion it happened to me occasions.
1. Shut down the netbook.
2. Remove battery for +- 15 min.
3. Replace battery.
4. Do not switch on netbook, ie boot up, until charge light goes to green ie indicates fully charged.
Dec 28, 2009 | Acer Aspire One PC Notebook
My ps3 keeps saying ne detected controllers when one is plugged in, there are 4 red lights flasing on the controller which is plugged into the console, after 20 minutes still no controller detected, any...
You need to press the ps switch and see if it says charging.When the lights flash on the controller it means they are charging the batteries.
The only way I know of to fix this problem is to switch off the PS3 from the switch in the back.Then turn it back on.The PS3 will assign the controllers.
Aug 01, 2009 | Sony Playstation 3 (PS3) Console
MOTOROLA Z3 NOT CHARGING
have the firmware reflash on the phone this should correct the issue that you have had with the phone.
Nov 30, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
HP Compaq nx7300 Notebook Logo
269 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
