Question about Black & Decker 22" Electric Hedge Trimmer
Where does the "w" shaped spring mechanism go in the B&D handle?
I opened up my b&D electric heldgetrimmer and the "W" shaped spring mechanism popped out. I am not sure where this goes now. Can you help? It has something to do with the push button, but it is real had to tell where it goes. Is there a manual for B&D trimmers out there? I just need a diagram.
3 Suggested Answers
  • 313 Answers
SOURCE: B & D flip handle electric corded mower
do you mean the orange lever came off. if thats the case you need the switch housing assy & a spring. the lever was held by the plastic housing pin or pig. some times the plastic pin worn out before it breaks.
Posted on Jun 14, 2008
boscia
  • 163 Answers
SOURCE: Need New Auxillary Handle - Only Place that lists one says it is "obsolete' - no replacement
try www.jackssmallengines.com
Posted on Nov 29, 2008
What part do I need? It opens from the inside. The handle is not snapped.
Are you saying the inside door handle isnt snapped,but the door wont open by pulling on the inside door handle or is it the outside door handle thats not working??Both the inside and outside door handle has a spring and other components on the backside of the handle which cant really be seen unless you remove the whole door handle assembly.One of these components are most likely broken or the rod that attaches between each handle and the locking mechanism(part that locks into the door striker to keep the door closed and releases it too)might have come loose from the back of the handle.The outside handle is usually mounted to the door by pop rivets or bolts/nuts.The inside handle is usually mounted with screws,but it really depends on what kind of car youre driving.Youll probably have to remove the handle to inspect it for damage.Open the door and watch the locking mechanism for movement while youre pulling on the door handle.If it doesnt move when you pull on the handle,the handle is definitely broke or the rod has come loose from the back of the handle.
Mar 09, 2015 | Cars & Trucks
Trying to put the back crank windows back in my Chevy II Nova
If it's a C shaped spring, just put the spring on the handle and pound the handle onto the shaft. The shaft is tapered and will spread the spring open until it snaps into the slot on the shaft.
Sep 04, 2011 | Chevrolet Chevy Cars & Trucks
How do I install a new Handle/Latch assembly on the door of a Whirlpool LHW0050PQ 4 Wash Machine...have to remove present one as broken---pull handle door catch does not release---have to release putting a...
I had to replace part No 8182408 - the washing machine door handle. There is a plastic bar in the middle of the assembly that broke because the door was opened too hard.
There are two springs, the latch, and the plastic piece that brings it all together. The smaller spring is the key, call it the L spring. It is shaped like an L and goes around the ends of the latch. The other spring is the larger and straight and goes around the tops of the plastic piece. The straight spring goes in with the crossbar facing on the outside of the washer. The latch with the L spring fits in between the plastic crossbar with the U shaped end pressing against the latches inside bar. The antenna of the L spring needs to wrap around the plastic bar and fit inside the straight spring bar. This applies pressure on the latch to stay closed. When the handle is pulled, it releases the pressure and allows you to open the door. The Metal bar is used to hold all the pieces together and once you have the alignment right, put it back into the door with the straight spring antenna tucked in the spots on the door, as well as the metal bar ends. Screw in the two spots that holds the assembly in place and you will be set. The door should open and shut easily.
Apr 22, 2011 | Whirlpool Washing Machines
I need to replace the door handle on my '96 honda civic, how do i get it off?
Pop off the speaker grill and remove the three screws securing the panel to the door frame. You do not have to remove the screws holding the speaker to the panel. Remove the window crank. There is a "U" shaped retaining spring holding the handle to the spindle. It can be removed with a special tool or just by pressing in on the panel and loosening the clip with a small flat blade screwdriver. Remove the screws in the arm rest and above the interior door handle lever.
Pull the panel from the door - be careful of the speaker wires - carefully undo the quick connect.
From the top corner, pull down on the plastic sheet.
Remove the square white plastic box that is used as a guide for the control bars.
Locate the exterior handle mechanism. There are 2 10mm bolts that hold the handle to the door frame. Remove them with a ratchet and extension.
Pop the retaining clip (it's green for the left door) free from the lock cylinder control rod, then pull the rod from the back of the lock cylinder.
Covering the back of the lock cylinder is a metal plate. Holding the plate to the cylinder is another "U" shaped spring clip that can be pulled down with a flat blade screwdriver.
After removing this clip, the metal plate will seperate from the cylinder. The culinder can then be pulled free from the inside and the handle from the outside.
Reverse the procedure to reinstall.
Its possible that need check the Honda-Civic-1996-1998-Service-Manual-Part-III
Hope help with this (remember comment and rated this post).
Apr 21, 2010 | 1996 Honda Civic
How do i remove door panel to get window runner
The panel is usually a pop button type retainers holding the panel on, Obviously all screws will have to be removed ie; grab handle, internal door opening lever, and the window winder,
TIP remove window winder handle with a shoe lace or a lenght of thin material , it's a horseshoe shaped spring clip holding the winder handle on and pulling the shoe lace or material in the opposite direction of clip will easily remove clip (don't loose ) Good luck
Apr 10, 2010 | 2003 Nissan Se R
Fuel filler door my Jaguar X (2002) will not unlock
Most cars have an emergency fuel filler door release somwhere in the trunk. Look for some kind of pull cord close to the area of the outside fill door.
Oct 15, 2009 | 2002 Jaguar X-Type
The handle on my Maytag Quiet series 100
I had the same problem with my QS 100. I disconnected power first via the breaker then removed the 11 screws. I couldn't loosen the two electrical connections, but the door pulled far enough away to inspect the handle mechanism. The plastic handle fell out of whole handle assembly rather easily because two molded plastic pins protuding from either side had broken off and were loose inside. There was also a pair of molded plastic v-shaped forks right on the panel to hold the handle assembly and these were damaged but they just to seem to act as guides only (as the handle assembly is held in by two of the screws that were removed). Replacing the v-shaped forks would require a whole new door which I am NOT doing. It looks like I can a replacement handle in the same color with new pins (I am reading they may now be metal) for about ##15. Pretty easy to disassemble and inspect, only about 15 minutes.
May 29, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Rear door handle sticks and won't open sometimes. when i do get it open, if i slam it it will open again. After driving for awhile it stops opening again. maybe a spring. the actual lever on the handle...
Typically spring is the failed part. Unfortunately if the WD-40 doesn't work then need to order or find replacement at a junk yard. There are 2 bolts that secure the hatch handle to the door but you'll need to remove the interior trim panel to get to it. Also the 2 screws/bolts that secure the hatch handle to the door can be fragile as well and may break-off - so unscrew with extreme caution. There is a a "Rube Goldberg" kind of set-up to get this whole mechanism to actually work. The wire-hanger type of metal that appears to link to the actual latch area can easily be popped off the 1-side of the hatch handle once you are able to remove the hatch handle from the door (after the 2 bolts are removed).
Mar 16, 2009 | 2003 Hyundai Santa Fe
Both front doors on my "93" Corsica won't open.
You have to open the Window all the way And I Assume your looking Down Threw the Glass opening to View the Linkage,
their is a Spring for the Return of the latch, While looking at the Latching system, Look for the Spring that When you "Try" to open the Door it's Suppose to Compress, Most likely the Spring is Not Fully Releasing,
You may try WD40, And work the handles for a few mins and Then Try to Unlock the door for it to open, OR you can Try a LONG Screw drive to Slide the Spring to fully Non compressed state and then Make sure the Door Lock is in the Open State before you try the handles..
Feb 03, 2009 | 1995 Chevrolet Corsica
Back door on my mitshibshi will not open 2002
Here was my solution for a "frozen" back door of a 2002 Mitsubishi Montero Limited
Nothing can be done from the interior of the Montero. The license plate holder will need to be removed carefully using a screwdriver.
There a re 4 tabs that need to pop out. All you need to do is pop them out. Do not force the plate holder to separate away too much from the door or the retainer (marked by red arrow) would break off. When you get the 4 tabs to pop out, slide the entire plate holder up to remove from the retainer. You do not need to detach the lamp wiring. Just move the plate holder to the right
I used WD40 but I'm sure there are other better and longer lasting spray lubricant out there. Spray through the hole generously from all angles. Let it sit for a while and then spray again some more.
The white tab from the handle that goes in the hole normally is being pushed up by a spring activated rod that sits horizontally against it. That spring gets rusted over time.
You will need a stiff wire, about 8"-10" in length.  A wire hanger worked well for me. Bend approx. 1/2" of one end, just as pictured below.
Put the hook though the hole and move the rod mentioned earlier up and down to loosen up it's spring. This rod is not easily visible. You basically just need to assume where it is after understanding the mechanics of the handle movement. It may take some time but be patient. You will see that you are getting somewhere when the handle starts moving back down to its normal position. Keep working on it 'till it's totally back where it should be. And when it is, lubricate it some more.
Heads up. There were many times that I thought I wasn't gonna be able to fix it and wanted to just put everything back and live with an inoperable back door. But I decided to stay with it and it paid up.
An extra step I did after I put the plate holder back was I put a light silicone sealant across the top to prevent rain/water from seeping in to the spring mechanism again. Good luck!
It would be nice to know if the time spent posting this information have helped anybody. Feel free to e-mail me and let me know!
Eddie jhedi@comcast.net
Nov 09, 2008 | 2002 Mitsubishi Montero
Black & Decker 22" Electric Hedge Trimmer Logo
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
