Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
I would push the prime button 3 or 4 times it starts then quiet
I have a lawnboy selfpropelled 4 cycle, 5.5hp, silver series. I prime it , it starts then dies, wont stay running
  • 3 more comments
  • Anonymous Apr 23, 2009
    same as above. i prime the engine with the bulb and it will start but only for a few seconds and then dies.
  • Anonymous May 03, 2009
    same problem. But I changed the oil, cleaned the carb, changed the oil filter and now the darn thing won"t even start.
  • Polo Vazquez May 05, 2009
    I have the same problem too, My mower startsand after 2 to 3 min it dies.I can get it to start after priming the darn thing but it does the same process over again.Any ideas?
  • deberhoades May 07, 2009
    My carborator shined when I opened it up.
    I replaced the oil.
    Drained the gas tank and put fresh gas in.
    Replaced the air filter.
    STILL It will crank only if I prime it, then instantly shut down.
    Now what. It feels like the throttle is not working or something is not giving it gas.
  • Anonymous May 11, 2009
    Same Lawnboy. 2 yrs old. Pristine carb, never let gas stand over winter. Changed oil, air filter and spark plug religiously. Problem: Starts easily. Runs appx. 3-5 minutes. Abruptly shuts off like the safety lever is released. No warning, no sputtering. Excellent power, idle speed, not surging...then instantly shuts off. I am suspecting a temp related failure in the high voltage side of the solid state ignition coil. I don't think this is fuel related. Will be trying fix this week when parts store opens Mon.
I took my carburetor off and blew it out with compressed air. Runs great now. Make sure to get all of it. Little screw on bottom has a hole in it too!
Posted on May 11, 2009
Potentially the solid state ignition (part number 34443C).
  • csm2 May 14, 2009
    This is csm2 again following up on my 11 May Guest comment (now I'm a member (csm2). I replaced solid state ignition (3444D (was rev C)) and this fixed the problem. Just mowed my 1/3 acre w/ no problems. I strongly recommend you do the spark test when in the warm fail condition and, if no spark, look into replacing that part. Hard to find part. Had to try several mower shops before I found it. Best luck.
    Problem Solver:
  • 4 Answers
Try cleaning the carburetor out.
try cleaning the air filter out
try changing the oil
make sure there is gas
those are my suggestions
Posted on Apr 18, 2009
Lawnboy silver series is not etting y spr
ask qustion again be specific is rear drive not working let me no
Aug 26, 2014 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
Oil mixture for 1985f series 2 cycle lawn-boy mower
Contact your dealer ! but 32:1 sounds correct. 8 ounces of Lawnboy oil to two gallons of gasoline ....is 32:1, 8 ounces of oil to one gallon of fuel is 16:1 for the real old lawnboys,
When Toro bought out OMC,and started using Tecumseh mowers,the ratio changed in the late 80's or early nineties ! IIRC :o)
Jun 11, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Have Lawnboy Kohler 149cc smart choke 6.5ft lbs engine bought last year won't start doesn't seem to be firing?
REMOVE THE SPARK PLUG, RECONNECT THE CABLE AND WHILE THE SPARK PLUG IS RESTING ON THE BLOC OPERATE THE STARTING PROCEDURE AND SEE IF THE PLUG IS SPARKING.
May 09, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
I need a part numnber for a coil for a Lawnboy Silver series mod# 10304
99-2916 may differ in appearance, but is a functional equivalent to prior parts including 684049.
Its 50+ dollars from Searspartsdirect.com
You might want to use both numbers and search Ebay for something cheaper!
Jun 22, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
My lawnboy 10304 runs about one minute and shuts down. Any ideas?
It sounds like it is 2 stroke.
Carefully remove the carb bowl, by undoing the brass bolt.
Examine the brass bolt for a small pin-hole in the side.
Use a piece of corn-broom NEVER anything else !!! and poke the hole(S) to make sure they are clear.
Blow out with air if available.
You can use this method to clean out all the carb orifices carefully.
Hope it helps,
Andy.
Jun 15, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
What is the 2 cycle oil to gas mixture for a 2 cycle lawnboy
20:1 gas to oil is a good place to start. Some mowers thin down to 80:1. If you can tell me the model of the mower I can be more specific, but starting at 20:1 will assure you have adequate protection for the engine. If it's exhausting lots of oil smoke after it has warmed up; you can cut back a little each time until you have minor oil smoke.
at 20:1 you need to add 6.4 ounces of oil to one gallon of gas.
Here's a nifty calculator for various ratios:
http://www.csgnetwork.com/oilfuelcalc.html
Enter 1 gallon of gas, then change the ratio number and then press calculate and the number of ounces per gallon will be displayed.
Mar 29, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
1,727 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
